| virtual void | SetProxies (unsigned int numElements, vtkSMProxy *proxies[]) |
| | Sets the value of the property to the list of proxies specified. More...
| bool | IsProxyAdded (vtkSMProxy *proxy) |
| | Returns if the given proxy is already added to the property. More...
| virtual void | RemoveAllUncheckedProxies () |
| | Removes all unchecked proxies. More...
| void | ClearUncheckedElements () override |
| | Use this method to clear unchecked values set of this property. More...
| unsigned int | GetNumberOfProxies () |
| | Returns the number of proxies. More...
| unsigned int | GetNumberOfUncheckedProxies () |
| | Returns the number of unchecked proxies. More...
| vtkSMProxy * | GetProxy (unsigned int idx) |
| | Return a proxy. More...
| vtkSMProxy * | GetUncheckedProxy (unsigned int idx) |
| void | Copy (vtkSMProperty *src) override |
| | Copy all property values. More...
| void | UpdateAllInputs () override |
| | Update all proxies referred by this property (if any). More...
| bool | IsValueDefault () override |
| | Returns true if the property's value is different from the default value. More...
| void | ResetToXMLDefaults () override |
| | For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
| virtual void | AddProxy (vtkSMProxy *proxy) |
| | Add/remove/set a proxy to the list of proxies. More...
| virtual void | SetProxy (unsigned int idx, vtkSMProxy *proxy) |
| virtual void | RemoveProxy (vtkSMProxy *proxy) |
| virtual void | RemoveAllProxies () |
| virtual void | AddUncheckedProxy (vtkSMProxy *proxy) |
| | Add an unchecked proxy. More...
| virtual void | SetUncheckedProxy (unsigned int idx, vtkSMProxy *proxy) |
| void | SetNumberOfProxies (unsigned int count) |
| | Set the number of proxies. More...
| void | SetNumberOfUncheckedProxies (unsigned int count) |
| int | IsInDomains () |
| | Returns true if all values are in all domains, false otherwise. More...
| int | IsInDomains (vtkSMDomain **domain) |
| | Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
| void | UnRegister (vtkObjectBase *obj) override |
| | Overloaded to break the reference loop caused by the internal domain iterator. More...
| vtkSMDomainIterator * | NewDomainIterator () |
| | Creates, initializes and returns a new domain iterator. More...
| vtkSMDomain * | GetDomain (const char *name) |
| | Returns a domain give a name. More...
| vtkSMDomain * | FindDomain (const char *classname) |
| | Returns the first domain which is of the specified type. More...
| template<class DomainType > |
| DomainType * | FindDomain () |
| | Same as FindDomain(classname), except the classname is deduced from the type. More...
| unsigned int | GetNumberOfDomains () |
| | Returns the number of domains this property has. More...
| void | AddDomain (const char *name, vtkSMDomain *dom) |
| | Properties can have one or more domains. More...
| virtual void | AddLinkedProperty (vtkSMProperty *targetProperty) |
| | Add a link to a property whose value should be synchronized with this property value. More...
| virtual void | RemoveLinkedProperty (vtkSMProperty *targetProperty) |
| | Remove a link to a property added with AddLinkedProperty() More...
| virtual void | RemoveFromSourceLink () |
| | Remove a link from the source property. More...
| void | ResetToDefault () |
| | Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
| virtual bool | ResetToDomainDefaults (bool use_unchecked_values=false) |
| | Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More...
| vtkSMProxy * | GetParent () |
| | Get the proxy to which this property belongs. More...
| virtual bool | IsStateIgnored () |
| bool | HasDomainsWithRequiredProperties () |
| | Returns true if the property has a domain with required properties. More...
| | The command name used to set the value on the server object. More...
| virtual void | SetImmediateUpdate (int) |
| | If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
| virtual int | GetImmediateUpdate () |
| virtual int | GetInformationOnly () |
| | Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
| virtual int | GetIgnoreSynchronization () |
| | If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
| virtual vtkSMProperty * | GetInformationProperty () |
| | Get the associated information property. More...
| virtual void | SetAnimateable (int) |
| | Get/Set if the property is animateable. More...
| virtual int | GetAnimateable () |
| virtual void | SetIsInternal (int) |
| | Get/Set if the property is internal to server manager. More...
| virtual int | GetIsInternal () |
| virtual void | SetNoCustomDefault (int) |
| | Sets whether the property should ignore custom default settings. More...
| virtual int | GetNoCustomDefault () |
| | Gets whether the property should ignore custom default settings. More...
| virtual void | SetPanelVisibility (const char *) |
| | Sets the panel visibility for the property. More...
| virtual char * | GetPanelVisibility () |
| | Returns the panel visibility for the property. More...
| virtual void | SetPanelVisibilityDefaultForRepresentation (const char *) |
| | Sets the panel visibility to default if the current representation type matches representation. More...
| virtual char * | GetPanelVisibilityDefaultForRepresentation () |
| | Returns which representation type the property will be shown by default for. More...
| virtual void | SetPanelWidget (const char *) |
| | Sets the name of the custom panel widget to use for the property. More...
| virtual char * | GetPanelWidget () |
| | Returns name of the panel widget for the property. More...
| virtual void | SetDisableSubTrace (const char *) |
| | Sets the tracing of sub property of this property. More...
| virtual char * | GetDisableSubTrace () |
| | Returns the tracing state of the properties of this property. More...
| | The label assigned by the xml parser. More...
| | The name assigned by the xml parser. More...
| virtual int | GetRepeatable () |
| | If repeatable, a property can have 1 or more values of the same kind. More...
| | The server manager configuration XML may define <Hints/> element for a property. More...
| void | Modified () override |
| | Overridden to support blocking of modified events. More...
| | vtkSMProxyProperty () |
| | ~vtkSMProxyProperty () override |
| void | WriteTo (vtkSMMessage *msg) override |
| | Let the property write its content into the stream. More...
| void | ReadFrom (const vtkSMMessage *msg, int msg_offset, vtkSMProxyLocator *) override |
| | Let the property read and set its content from the stream. More...
| int | ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override |
| void | SaveStateValues (vtkPVXMLElement *propertyElement) override |
| | Generic method used to generate XML state. More...
| virtual vtkPVXMLElement * | AddProxyElementState (vtkPVXMLElement *prop, unsigned int idx) |
| | Fill state property/proxy XML element with proxy info. More...
| int | LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override |
| | Updates state from an XML element. More...
| void | OnUpdateDataEvent () |
| | Called when a producer fires the vtkCommand::UpdateDataEvent. More...
| | vtkSMProperty () |
| | ~vtkSMProperty () override |
| virtual void | ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *) |
| | Internal. More...
| void | AddDependent (vtkSMDomain *dom) |
| | Internal. More...
| void | RemoveAllDependents () |
| | Removes all dependents. More...
| void | UpdateDomains () |
| | Calls Update() on all domains contained by the property as well as all dependent domains. More...
| virtual void | SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1) |
| | Save the property state in XML. More...
| virtual void | SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid) |
| | Save property domain. More...
| virtual void | SetInformationOnly (int) |
| virtual void | SetIgnoreSynchronization (int) |
| void | SetInformationProperty (vtkSMProperty *ip) |
| void | SetDocumentation (vtkSMDocumentation *) |
| void | SetParent (vtkSMProxy *proxy) |
| virtual void | SetStateIgnored (bool) |
| virtual void | StateIgnoredOn () |
| virtual void | StateIgnoredOff () |
| bool | SetBlockModifiedEvents (bool block) |
| | Block/unblock modified events, returns the current state of the block flag. More...
| virtual bool | GetPendingModifiedEvents () |
| | Returns if any modified evetns are pending. More...
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
property representing pointer(s) to vtkObject(s)
vtkSMProxyProperty is a concrete sub-class of vtkSMProperty representing pointer(s) to vtkObject(s) (through vtkSMProxy).
vtkSMProperty::UpdateDomains() is called by vtkSMProperty itself whenever its unchecked values are modified. In case of proxy-properties, the dependent domains typically tend to depend on the data information provided by the source-proxies added to the property. Thus, to ensure that the domains get updated if the data information changes, vtkSMProxyProperty ensures that vtkSMProperty::UpdateDomains() is called whenever any of the added proxies fires the vtkCommand::UpdateDataEvent (which is fired whenever the pipeline us updated through the ServerManager indicating that the data-information last used may have been invalidated).
Besides the standard set of attributes, the following XML attributes are supported:
- command : identifies the method to call on the VTK object e.g. AddRepresentation.
- clean_command : if present, called once before invoking the method specified by
command every time the property value is pushed e.g. RemoveAllRepresentations. If property can take multiple values then the command is called for for each of the values after the clean command for every push.
- remove_command : an alternative to clean_command where instead of resetting and adding all the values for every push, this simply calls the specified method to remove the vtk-objects no longer referred to e.g. RemoveRepresentation.
- argument_type : identifies the type for value passed to the method on the VTK object. Accepted values are "VTK", "SMProxy" or "SIProxy". Default is VTK.
- null_on_empty : if set to 1, whenever the property's value changes to empty i.e. it contains no proxies, the command is called on the VTK object with NULL argument useful when there's no clean_command that can be called on the VTK object to unset the property e.g. SetLookupTable(NULL).
- skip_dependency: obsolete and no longer supported. This was intended for vtkSMRepresentationProxy to distinguish between proxy connections that invalidate representation pipeline (e.g. input) and those that don't (e.g. LookupTable). vtkSMRepresentationProxy now handles this automatically.
- See also
- vtkSMProperty
Definition at line 69 of file vtkSMProxyProperty.h.
