| virtual vtkPVDataInformation * | GetDataInformation () |
| | Returns data information. More...
| virtual vtkPVTemporalDataInformation * | GetTemporalDataInformation () |
| | Returns data information collected over all timesteps provided by the pipeline. More...
| virtual vtkDataAssembly * | GetDataAssembly () |
| | If available, returns the data assembly associated with the data produced on this port. More...
| virtual const char * | GetDataClassName () |
| | Returns the classname of the data object on this output port. More...
| virtual vtkPVClassNameInformation * | GetClassNameInformation () |
| | Returns classname information. More...
| virtual void | InvalidateDataInformation () |
| | Mark data information as invalid. More...
| vtkSMSourceProxy * | GetSourceProxy () |
| | Provides access to the source proxy to which the output port belongs. More...
| virtual int | GetPortIndex () |
| | Returns the index of the port the output is obtained from. More...
| vtkSMSession * | GetSession () override |
| | Overridden to forward to the source proxy. More...
| vtkSMSessionProxyManager * | GetSessionProxyManager () override |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMOutputPort () |
| | ~vtkSMOutputPort () override |
| virtual void | GatherClassNameInformation () |
| | Get the classname of the dataset from server. More...
| virtual void | GatherDataInformation () |
| | Get information about dataset from server. More...
| virtual void | GatherTemporalDataInformation () |
| | Get temporal information from the server. More...
| void | SetSourceProxy (vtkSMSourceProxy *src) |
| void | SetCompoundSourceProxy (vtkSMCompoundSourceProxy *src) |
| virtual void | UpdatePipelineInternal (double time, bool doTime) |
| | An internal update pipeline method that subclasses may override. More...
| virtual void | SetPortIndex (int) |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
