| virtual bool | IsActivated (vtkSMExtractsController *controller) |
| | Returns true if the trigger conditions are satisfied. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMExtractTriggerProxy () |
| | ~vtkSMExtractTriggerProxy () |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
trigger to control extract generation
vtkSMExtractTriggerProxy defines a trigger that is intended to use a control an extractor. Currently, this class directly implements a time-based trigger which relies on properties to indicate the start-time, end-time, and update frequency. Subclasses can be added to define new types of triggers.
Definition at line 32 of file vtkSMExtractTriggerProxy.h.
