| void | SetPropertyNames (vtkStringList *names) |
| | Set the names of properties to iterate over. More...
| void | Begin () override |
| | Go to the first property. More...
| int | IsAtEnd () override |
| | Returns true if iterator points past the end of the collection. More...
| void | Next () override |
| | Move to the next property. More...
| const char * | GetKey () override |
| | Returns the key (name) at the current iterator position. More...
| const char * | GetPropertyLabel () override |
| | Returns the XMLLabel for self properties and the exposed name for sub-proxy properties. More...
| vtkSMProperty * | GetProperty () override |
| | Returns the property at the current iterator position. More...
| virtual void | SetProxy (vtkSMProxy *proxy) |
| | Set the proxy to be used. More...
| virtual vtkSMProxy * | GetProxy () |
| | Return the proxy. More...
| virtual void | SetTraverseSubProxies (int) |
| | If TraverseSubProxies is false, only the properties belonging to the root proxy are returned. More...
| virtual int | GetTraverseSubProxies () |
iterates over a subset of a proxy's properties
vtkSMNamedPropertyIterator can be used to iterate over a subset of a proxy's properties. The subset is defined through a list of strings naming properties. The properties of the root proxies as well as sub-proxies are included in the iteration. For sub-proxies, only exposed properties are iterated over.
- See also
- vtkSMPropertyIterator
- This class was contributed by SciberQuest Inc.
Definition at line 42 of file vtkSMNamedPropertyIterator.h.
