| const char * | GetPresetName (int preset) |
| | Get the preset name. More...
| const char * | GetPresetDisplayName (int preset) |
| | Get a display name for the preset. More...
| int | GetCurrentPreset () |
| | Get the current preset value. More...
| void | SetPreset (int preset) |
| | Set Preset onto properties. More...
| void | SetPreset (const char *name) |
| virtual bool | GetUsingScalarColoring () |
| | Returns true if scalar coloring is enabled. More...
| virtual bool | SetScalarColoring (const char *arrayname, int attribute_type) |
| | Enable/disable scalar coloring using the specified array. More...
| virtual bool | SetScalarColoring (const char *arrayname, int attribute_type, int component) |
| virtual bool | RescaleTransferFunctionToDataRange (bool extend=false, bool force=true) |
| | Rescales the color transfer function and opacity transfer function using the current data range. More...
| virtual bool | RescaleTransferFunctionToDataRange (const char *arrayname, int attribute_type, bool extend=false, bool force=true) |
| | Rescales the color transfer function and opacity transfer function using the current data range for the chosen data-array. More...
| virtual bool | RescaleTransferFunctionToDataRangeOverTime () |
| | Rescales the color transfer function and opacity transfer function using the current data range over time. More...
| virtual bool | RescaleTransferFunctionToDataRangeOverTime (const char *arrayname, int attribute_type) |
| | Rescales the color transfer function and opacity transfer function using the current data range over time for the chosen data-array. More...
| int | GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *view) |
| | Get an estimated number of annotation shown on this representation scalar bar. More...
| bool | SetRepresentationType (const char *type) override |
| | Overridden to ensure when picking representation types that require scalar colors, scalar coloring it setup properly. More...
| bool | GetVolumeIndependentRanges () |
| | True if ranges have to be computed independently on component 0 for the color and 1 for the opacity on the Volume representation. More...
| virtual bool | RescaleTransferFunctionToVisibleRange (vtkSMProxy *view) |
| | Rescales the color transfer function and the opacity transfer function using the current data range, limited to the currernt visible elements. More...
| virtual bool | RescaleTransferFunctionToVisibleRange (vtkSMProxy *view, const char *arrayname, int attribute_type) |
| int | IsScalarBarStickyVisible (vtkSMProxy *view) |
| | Checks if the scalar bar of this representation in view is sticky visible, i.e. More...
| virtual bool | SetScalarBarVisibility (vtkSMProxy *view, bool visible) |
| | Set the scalar bar visibility. More...
| virtual bool | HideScalarBarIfNotNeeded (vtkSMProxy *view) |
| | While SetScalarBarVisibility can be used to hide a scalar bar, it will always simply hide the scalar bar even if its being used by some other representation. More...
| virtual bool | IsScalarBarVisible (vtkSMProxy *view) |
| | Check scalar bar visibility. More...
| virtual vtkPVArrayInformation * | GetArrayInformationForColorArray (bool checkRepresentedData=true) |
| | Returns the array information for the data array used for scalar coloring, from input data. More...
| virtual vtkPVProminentValuesInformation * | GetProminentValuesInformationForColorArray (double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
| | Call vtkSMRepresentationProxy::GetProminentValuesInformation() for the array used for scalar color, if any. More...
| virtual vtkPVDataInformation * | GetRepresentedDataInformation () |
| | Returns information about the data that is finally rendered by this representation. More...
| virtual vtkPVProminentValuesInformation * | GetProminentValuesInformation (std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
| | Returns information about a specific array component's prominent values (or NULL). More...
| void | UpdatePipeline () override |
| | Calls Update() on all sources. More...
| void | UpdatePipeline (double time) override |
| | Calls Update() on all sources with the given time request. More...
| void | PostUpdateData (bool) override |
| | Overridden to reset this->MarkedModified flag. More...
| virtual void | ViewUpdated (vtkSMProxy *view) |
| | Called after the view updates. More...
| vtkTypeUInt32 | GetGlobalID () override |
| | Overridden to reserve additional IDs for use by internal composite representation. More...
| void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| | Marks the selection proxies dirty as well as chain to superclass. More...
| void | SetDebugName (const char *name) |
| const char * | GetDebugName () |
| void | UpdatePipelineInformation () override |
| | Calls UpdateInformation() on all sources. More...
| virtual unsigned int | GetNumberOfOutputPorts () |
| | Return the number of output ports. More...
| virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
| | Return an output port. More...
| virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
| | Return an output port, given the name for the port. More...
| virtual unsigned int | GetOutputPortIndex (const char *portname) |
| | Returns the port index, given the name of an output port. More...
| virtual const char * | GetOutputPortName (unsigned int index) |
| | Returns the output port name given its index. More...
| virtual void | CreateOutputPorts () |
| | Creates the output port proxies for this filter. More...
| virtual void | CreateSelectionProxies () |
| | Creates extract selection proxies for each output port if not already created. More...
| void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
| | Set/Get the selection input. More...
| void | CleanSelectionInputs (unsigned int portIndex) |
| | Clean all selection inputs for the given port. More...
| vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
| | Returns the source proxy which provides the selected data from the given output port. More...
| unsigned int | GetNumberOfAlgorithmOutputPorts () |
| | Returns the number of output ports provided by the algorithm. More...
| virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
| | Returns the number of non-optional input ports required by the algorithm. More...
| virtual int | GetOutputPortsCreated () |
| | Returns if the output port proxies have been created. More...
| vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
| | It is possible to provide some documentation for each output port in the configuration xml. More...
| vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
| vtkPVDataInformation * | GetDataInformation () |
| | DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
| vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
| vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
| | API to query selection input set using SetSelectionInput. More...
| unsigned int | GetSelectionInputPort (unsigned int portIndex) |
| virtual int | GetProcessSupport () |
| | This returns information about whether the VTK algorithm supports multiple processes or not. More...
| virtual bool | GetMPIRequired () |
| | This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMPVMoleculeRepresentationProxy () |
| | ~vtkSMPVMoleculeRepresentationProxy () override=default |
| | vtkSMPVRepresentationProxy () |
| | ~vtkSMPVRepresentationProxy () override |
| virtual bool | RescaleTransferFunctionToDataRange (vtkPVArrayInformation *info, bool extend=false, bool force=true) |
| | Rescales transfer function ranges using the array information provided. More...
| void | CreateVTKObjects () override |
| | Overridden to ensure that the RepresentationTypesInfo and Representations's domain are up-to-date. More...
| void | OnPropertyUpdated (vtkObject *, unsigned long, void *calldata) |
| void | SetPropertyModifiedFlag (const char *name, int flag) override |
| | Overridden to ensure that whenever "Input" property changes, we update the "Input" properties for all internal representations (including setting up of the link to the extract-selection representation). More...
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| | Overridden to process "RepresentationType" elements. More...
| std::string | GetDecoratedArrayName (const std::string &arrayname) |
| | In case of UseSeparateColorMap enabled, this function prefix the given arrayname with unique identifier, otherwise it acts as a passthrough. More...
| virtual bool | SetScalarColoringInternal (const char *arrayname, int attribute_type, bool useComponent, int component) |
| | Internal method to set scalar coloring, do not use directly. More...
| | vtkSMRepresentationProxy () |
| | ~vtkSMRepresentationProxy () override |
| void | MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) override |
| | When the representation is being marked dirty due to a producer i.e. More...
| void | AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override |
| void | RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override |
| void | RemoveAllConsumers () override |
| | Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
| void | OnVTKRepresentationUpdated () |
| void | OnVTKRepresentationUpdateSkipped () |
| void | OnVTKRepresentationUpdateTimeChanged () |
| virtual void | UpdatePipelineInternal (double time, bool doTime) |
| void | InvalidateDataInformation () override |
| | Mark the data information as invalid. More...
| int | LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override |
| | Overridden to restore this->Servers flag state. More...
| | vtkSMSourceProxy () |
| | ~vtkSMSourceProxy () override |
| virtual void | SetExecutiveName (const char *) |
| void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override |
| | Overridden to pass the logname to the internal ExtractSelection proxies. More...
| void | SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc) |
| | Method to set an output port at the given index. More...
| void | RemoveAllOutputPorts () |
| void | SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy) |
| void | RemoveAllExtractSelectionProxies () |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
