proxy for a VTK source on a server More...
#include <vtkSMSourceProxy.h>
| enum | ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH } |
| typedef vtkSMProxy | Superclass |
Public Types inherited from vtkSMProxy | |
| enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
| enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
| Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
| void | UpdatePipelineInformation () override |
| Calls UpdateInformation() on all sources. More... | |
| virtual void | UpdatePipeline () |
| Calls Update() on all sources. More... | |
| virtual void | UpdatePipeline (double time) |
| Calls Update() on all sources with the given time request. More... | |
| virtual unsigned int | GetNumberOfOutputPorts () |
| Return the number of output ports. More... | |
| virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
| Return an output port. More... | |
| virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
| Return an output port, given the name for the port. More... | |
| virtual unsigned int | GetOutputPortIndex (const char *portname) |
| Returns the port index, given the name of an output port. More... | |
| virtual const char * | GetOutputPortName (unsigned int index) |
| Returns the output port name given its index. More... | |
| virtual void | CreateOutputPorts () |
| Creates the output port proxies for this filter. More... | |
| virtual void | CreateSelectionProxies () |
| Creates extract selection proxies for each output port if not already created. More... | |
| void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
| Set/Get the selection input. More... | |
| void | CleanSelectionInputs (unsigned int portIndex) |
| Clean all selection inputs for the given port. More... | |
| vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
| Returns the source proxy which provides the selected data from the given output port. More... | |
| unsigned int | GetNumberOfAlgorithmOutputPorts () |
| Returns the number of output ports provided by the algorithm. More... | |
| virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
| Returns the number of non-optional input ports required by the algorithm. More... | |
| vtkTypeUInt32 | GetGlobalID () override |
| Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More... | |
| void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| Marks the selection proxies dirty as well as chain to superclass. More... | |
| virtual int | GetOutputPortsCreated () |
| Returns if the output port proxies have been created. More... | |
| vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
| It is possible to provide some documentation for each output port in the configuration xml. More... | |
| vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
| vtkPVDataInformation * | GetDataInformation () |
| DataInformation is used by the source proxy to obtain information on the output(s) from the server. More... | |
| vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
| vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
| API to query selection input set using SetSelectionInput. More... | |
| unsigned int | GetSelectionInputPort (unsigned int portIndex) |
| virtual int | GetProcessSupport () |
| This returns information about whether the VTK algorithm supports multiple processes or not. More... | |
| virtual bool | GetMPIRequired () |
| This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More... | |
Public Member Functions inherited from vtkSMProxy | |
| Retrieve an annotation with a given key. More... | |
| Remove a given annotation based on its key to the proxy. More... | |
| Remove all proxy annotations. More... | |
| Return true if a given annotation exists. More... | |
| Return the number of available annotations. More... | |
| Return the nth key of the available annotations. More... | |
| Return the property with the given name. More... | |
| Return a property of the given name from self or one of the sub-proxies. More... | |
| Given a property pointer, returns the name that was used to add it to the proxy. More... | |
| Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
| Recreate the VTK object for this proxy. More... | |
| Convenience method equivalent to UpdateProperty(name, 1). More... | |
| Returns a new (initialized) iterator of the properties. More... | |
| Returns the number of consumers. More... | |
| Returns the consumer of given index. More... | |
| Returns the corresponding property of the consumer of given index. More... | |
| Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
| Returns a proxy this proxy depends on, given index. More... | |
| Returns the property holding a producer proxy given an index. More... | |
| Updates all property information by calling UpdateInformation() and populating the values. More... | |
| Similar to UpdatePropertyInformation() but updates only the given property. More... | |
| Marks all properties as modified. More... | |
| Use this method to set all properties on this proxy to their default values. More... | |
| Use this method to set all properties on this proxy to their default domains. More... | |
| Use this method to set all properties on this proxy to their default domain or values. More... | |
| Calls MarkDirty() and invokes ModifiedEvent. More... | |
| Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
| Returns the client side object associated with the VTKObjectID (if any). More... | |
| Saves the state of the proxy. More... | |
| The iterator is use to filter the property available on the given proxy. More... | |
| Loads the proxy state from the XML element. More... | |
| This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
| bool | GetIsSubProxy () |
| A proxy instance can be a sub-proxy for some other proxy. More... | |
| If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
| Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
| This method return the full object state that can be used to create that object from scratch. More... | |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
| Returns the number of property groups that the proxy contains. More... | |
| Update the value of one property (pushed to the server) if it is modified. More... | |
| Returns the type of object managed by the proxy. More... | |
| the type of object created by the proxy. More... | |
| Copies values of all the properties and sub-proxies from src. More... | |
| Returns if the VTK objects for this proxy have been created. More... | |
| Gathers information about this proxy. More... | |
| Log name is a name for this proxy that will be used when logging status messages. More... | |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| static vtkSMSourceProxy * | New () |
| static vtkSMSourceProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMProxy | |
| static vtkSMProxy * | New () |
| static vtkSMProxy * | SafeDownCast (vtkObject *o) |
| vtkSMSourceProxy () | |
| ~vtkSMSourceProxy () override | |
| virtual void | InvalidateDataInformation () |
| Mark the data information as invalid. More... | |
| void | CreateVTKObjects () override |
| Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More... | |
| virtual void | SetExecutiveName (const char *) |
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| Read attributes from an XML element. More... | |
| void | PostUpdateData (bool) override |
| Overwritten from superclass to invoke. More... | |
| void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override |
| Overridden to pass the logname to the internal ExtractSelection proxies. More... | |
| void | SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc) |
| Method to set an output port at the given index. More... | |
| void | RemoveAllOutputPorts () |
| void | SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy) |
| void | RemoveAllExtractSelectionProxies () |
Protected Member Functions inherited from vtkSMProxy | |
| vtkSMProxy () | |
| ~vtkSMProxy () override | |
| Invoke that takes a vtkClientServerStream as the argument. More... | |
| Add a property with the given key (name). More... | |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
| Cleanup code. More... | |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
| Add a sub-proxy. More... | |
| Remove a sub-proxy. More... | |
| Returns a sub-proxy. More... | |
| Returns the name used to store sub-proxy. More... | |
| Returns the number of sub-proxies. More... | |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
| Remove the property,proxy pair from the list of consumers. More... | |
| Remove all consumers. More... | |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
| Remove the property,proxy pair from the list of producers. More... | |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
| Parses the XML to create a new property group. More... | |
| Adds a property groups. More... | |
| Expose a subproxy property from the base proxy. More... | |
| Handle events fired by subproxies. More... | |
| Called to update the property information on the property. More... | |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
| Indicates if any properties are modified. More... | |
| vtkSMProxy (const vtkSMProxy &)=delete | |
| Get the last result. More... | |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
| SIClassName identifies the classname for the helper on the server side. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Friends | |
| class | vtkSMInputProperty |
| class | vtkSMOutputPort |
vtkSMSourceProxy manages VTK source(s) that are created on a server using the proxy pattern. In addition to functionality provided by vtkSMProxy, vtkSMSourceProxy provides method to connect and update sources. Each source proxy has one or more output ports (vtkSMOutputPort). Each port represents one output of one filter. These are created automatically (when CreateOutputPorts() is called) by the source. Each vtkSMSourceProxy creates a property called DataInformation. This property is a composite property that provides information about the output(s) of the VTK sources (obtained from the server)
Definition at line 49 of file vtkSMSourceProxy.h.
Definition at line 53 of file vtkSMSourceProxy.h.
| Enumerator | |
| SINGLE_PROCESS | |
| MULTIPLE_PROCESSES | |
| BOTH | |
Definition at line 215 of file vtkSMSourceProxy.h.
Reimplemented in vtkSMMultiplexerSourceProxy, vtkSMRepresentationProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMCompoundSourceProxy, vtkSMSelfGeneratingSourceProxy, vtkSMPVRepresentationProxy, vtkSMDataSourceProxy, vtkSMMultiServerSourceProxy, vtkSMWriterProxy, vtkSMPWriterProxy, vtkSMPSWriterProxy, vtkSMChartRepresentationProxy, vtkSMSpreadSheetRepresentationProxy, and vtkSMEnsembleDataReaderProxy.
Reimplemented in vtkSMRepresentationProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMPVRepresentationProxy, vtkSMWriterProxy, vtkSMChartRepresentationProxy, and vtkSMSpreadSheetRepresentationProxy.
It also creates output ports if they are not already created.
Reimplemented in vtkSMRepresentationProxy, and vtkSMWriterProxy.
Each output port is assigned a unique name (either using the xml configuration or automatically). The automatically assigned names are of the type Output0, Output1 etc.
Each output port is assigned a unique name (either using the xml configuration or automatically). The automatically assigned names are of the type Output0, Output1 etc. Returns VTK_UNSIGNED_INT_MAX (i.e. ~0u) when a port with given port name does not exist.
Each output port is assigned an unique name (either using the xml configuration or automatically). The automatically assigned names are of the type Output-0, Output-1 etc.
| vtkSMDocumentation* vtkSMSourceProxy::GetOutputPortDocumentation | ( | unsigned int | index | ) |
These methods provide access to the port specific documentation, if any. If no documentation is present, these methods will return 0.
| vtkSMDocumentation* vtkSMSourceProxy::GetOutputPortDocumentation | ( | const char * | portname | ) |
Each output port proxy corresponds to an actual output port on the algorithm.
Reimplemented in vtkSMCompoundSourceProxy.
If update is false the pipeline will not be updated before gathering the data information.
Definition at line 141 of file vtkSMSourceProxy.h.
| vtkPVDataInformation* vtkSMSourceProxy::GetDataInformation | ( | unsigned int | outputIdx | ) |
| void vtkSMSourceProxy::SetSelectionInput | ( | unsigned int | portIndex, |
| vtkSMSourceProxy * | input, | ||
| unsigned int | outputPort | ||
This is used to set the selection input to the extraction proxy for the output port identified by portIndex. If no extraction proxies are present, this method has no effect.
| vtkSMSourceProxy* vtkSMSourceProxy::GetSelectionInput | ( | unsigned int | portIndex | ) |
| void vtkSMSourceProxy::CleanSelectionInputs | ( | unsigned int | portIndex | ) |
| vtkSMSourceProxy* vtkSMSourceProxy::GetSelectionOutput | ( | unsigned int | portIndex | ) |
SINGLE_PROCESS means that this algorithm works only in serial, MULTIPLE_PROCESSES means that it will only useful in parallel (or it is useless in serial), BOTH means both :-) Default is BOTH. This ivar is filled from the xml configuration. This variable should not be used to determine if MPI is initialized. Instead use MPISupport for that.
It still may only run with a single process. An example of this is a reader that uses MPI IO routines.
| unsigned int vtkSMSourceProxy::GetNumberOfAlgorithmOutputPorts | ( | ) |
This value is cached after the first call.
Reimplemented from vtkSMRemoteObject.
Reimplemented in vtkSMRepresentationProxy.
protectedvirtual |
overrideprotectedvirtual |
Reimplemented in vtkSMPVRepresentationProxy, and vtkSMRepresentationProxy.
protectedvirtual |
Reimplemented in vtkSMPVRepresentationProxy, vtkSMWriterProxy, and vtkSMChartRepresentationProxy.
Provided for subclasses to add output ports. It replaces the output port at the given index, if any, The output ports will be resize to fit the specified index.
friend |
Definition at line 231 of file vtkSMSourceProxy.h.
friend |
Definition at line 232 of file vtkSMSourceProxy.h.
Definition at line 234 of file vtkSMSourceProxy.h.
Definition at line 236 of file vtkSMSourceProxy.h.
Definition at line 237 of file vtkSMSourceProxy.h.
Definition at line 250 of file vtkSMSourceProxy.h.
Definition at line 284 of file vtkSMSourceProxy.h.
Definition at line 285 of file vtkSMSourceProxy.h.
