| virtual void | OnStartInteraction () |
| | These method forward the representation state of the client side widget representation to the server. More...
| virtual void | OnEndInteraction () |
| virtual void | OnInteraction () |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMImplicitPlaneRepresentationProxy () |
| | ~vtkSMImplicitPlaneRepresentationProxy () override |
| void | SendRepresentation () override |
| | vtkSMWidgetRepresentationProxy () |
| | ~vtkSMWidgetRepresentationProxy () override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
