| virtual bool | RescaleTransferFunction (const double range[2], bool extend=false) |
| | Rescale the "RGBPoints" for the transfer function to match the new range. More...
| virtual bool | RescaleTransferFunction (double rangeMin, double rangeMax, bool extend=false) |
| virtual bool | InvertTransferFunction () |
| | Invert the transfer function. More...
| virtual bool | MapControlPointsToLogSpace (bool inverse=false) |
| | Remaps control points by normalizing in linear-space and then interpolating in log-space. More...
| virtual bool | MapControlPointsToLinearSpace () |
| virtual bool | ApplyPreset (const char *presetname, bool rescale=true) |
| virtual bool | SaveColorMap (vtkPVXMLElement *xml) |
| | Save to ColorMap XML. More...
| virtual bool | IsScalarBarVisible (vtkSMProxy *view) |
| | Return true if the representation corresponding to the transfer function for the view is showing a Scalar-Bar (Color Legend). More...
| virtual vtkSMProxy * | FindScalarBarRepresentation (vtkSMProxy *view) |
| | Find and return the Scalar-Bar (Color Legend) representation corresponding to the transfer function for the view, if any. More...
| virtual bool | ComputeAvailableAnnotations (bool extend=false) |
| void | ResetRescaleModeToGlobalSetting () |
| | Reset the transfer function's AutomaticRescaleResetMode to the global TransferFunctionRresetMode setting. More...
| virtual bool | ApplyColorMap (const char *text) |
| | Load a ColorMap XML. More...
| virtual bool | ApplyColorMap (vtkPVXMLElement *xml) |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| static vtkSMTransferFunctionProxy * | New () |
| static vtkSMTransferFunctionProxy * | SafeDownCast (vtkObject *o) |
| static bool | InvertTransferFunction (vtkSMProxy *) |
| | Safely call InvertTransferFunction() after casting the proxy to the appropriate type. More...
| static bool | MapControlPointsToLinearSpace (vtkSMProxy *proxy) |
| | Safely call MapControlPointsToLinearSpace() after casting the proxy to the appropriate type. More...
| static bool | ApplyPreset (vtkSMProxy *proxy, const char *presetname, bool rescale=true) |
| static bool | ComputeAvailableAnnotations (vtkSMProxy *proxy, bool extend=false) |
| static bool | ConvertLegacyColorMapsToJSON (const char *inxmlfile, const char *outjsonfile) |
| | Converts legacy xml file to json. More...
| static bool | ExportTransferFunction (vtkSMTransferFunctionProxy *colorTransferFunction, vtkSMTransferFunctionProxy *opacityTransferFunction, const char *tfname, const char *filename) |
| | Export a transfer function to a json file. More...
| static bool | RescaleTransferFunction (vtkSMProxy *proxy, double rangeMin, double rangeMax, bool extend=false) |
| | Safely call RescaleTransferFunction() after casting the proxy to appropriate type. More...
| static bool | RescaleTransferFunction (vtkSMProxy *proxy, const double range[2], bool extend=false) |
| static bool | MapControlPointsToLogSpace (vtkSMProxy *proxy, bool inverse=false) |
| | Safely call MapControlPointsToLogSpace() after casting the proxy to the appropriate type. More...
| static bool | ApplyColorMap (vtkSMProxy *proxy, const char *text) |
| | Safely call ApplyColorMap(..) after casting the proxy to the appropriate type. More...
| static bool | ApplyColorMap (vtkSMProxy *proxy, vtkPVXMLElement *xml) |
| static bool | SaveColorMap (vtkSMProxy *proxy, vtkPVXMLElement *xml) |
| static bool | IsScalarBarVisible (vtkSMProxy *proxy, vtkSMProxy *view) |
| | Safely call IsScalarBarVisible(..) after casting the proxy to the appropriate type. More...
| static vtkSMProxy * | FindScalarBarRepresentation (vtkSMProxy *proxy, vtkSMProxy *view) |
| | Safely call FindScalarBarRepresentation(..) after casting the proxy to the appropriate type. More...
| static Json::Value | ConvertLegacyColorMapXMLToJSON (vtkPVXMLElement *xml) |
| | Method to convert legacy color map preset XML to JSON. More...
| static Json::Value | ConvertLegacyColorMapXMLToJSON (const char *xmlcontents) |
| static Json::Value | ConvertMultipleLegacyColorMapXMLToJSON (vtkPVXMLElement *xml) |
| | Method to convert legacy "ColorMaps" preset XML to JSON. More...
| static Json::Value | ConvertMultipleLegacyColorMapXMLToJSON (const char *xmlcontents) |
| static vtkSMProxy * | New () |
| static vtkSMProxy * | SafeDownCast (vtkObject *o) |
| | vtkSMTransferFunctionProxy ()=default |
| | ~vtkSMTransferFunctionProxy () override=default |
| void | RestoreFromSiteSettingsOrXML (const char *arrayName) |
| | Attempt to reset transfer function to site settings. More...
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
| double | LastRange [2] = { 0, 1 } |
| vtkSmartPointer< vtkTable > | HistogramTableCache |
| bool | NeedsUpdate |
| char * | VTKClassName |
| char * | XMLGroup |
| char * | XMLName |
| char * | XMLLabel |
| char * | XMLSubProxyName |
| int | ObjectsCreated |
| int | DoNotUpdateImmediately |
| int | DoNotModifyProperty |
| int | InUpdateVTKObjects |
| | Avoids calls to UpdateVTKObjects in UpdateVTKObjects. More...
| bool | PropertiesModified |
| | Flag used to help speed up UpdateVTKObjects and ArePropertiesModified calls. More...
| vtkPVXMLElement * | XMLElement |
| vtkSMDocumentation * | Documentation |
| vtkPVXMLElement * | Hints |
| vtkPVXMLElement * | Deprecated |
| vtkSMMessage * | State |
| int | InMarkModified |
| vtkWeakPointer< vtkSMProxy > | ParentProxy |
| vtkSMProxyInternals * | Internals |
| vtkSMProxyObserver * | SubProxyObserver |
| char * | SIClassName |
| vtkTypeUInt32 | GlobalID |
| vtkTypeUInt32 | Location |
| bool | Prototype |
| bool | ClientOnlyLocationFlag |
| | Identifies the session id to which this object is related. More...
| static bool | RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false) |
| | Locates all representations that are currently using this transfer function and then rescales the transfer function scalar range to exactly match the combined valid scalar ranges obtained from them all. More...
| virtual bool | RescaleTransferFunctionToDataRange (bool extend=false) |
| static bool | ApplyPreset (vtkSMProxy *proxy, const Json::Value &value, bool rescale=true) |
| | Apply a preset. More...
| virtual bool | ApplyPreset (const Json::Value &value, bool rescale=true) |
| static Json::Value | GetStateAsPreset (vtkSMProxy *proxy) |
| | Saves the transfer function state as a preset. More...
| virtual Json::Value | GetStateAsPreset () |
| static bool | UpdateScalarBarsComponentTitle (vtkSMProxy *proxy, vtkPVArrayInformation *arrayInfo) |
| | Update component titles for all scalar bars connected to this transfer function proxy. More...
| virtual bool | UpdateScalarBarsComponentTitle (vtkPVArrayInformation *arrayInfo) |
| static bool | ComputeDataRange (vtkSMProxy *proxy, double range[2]) |
| | Helper method used by RescaleTransferFunctionToDataRange() to compute range from all visible representations using the transfer function. More...
| virtual bool | ComputeDataRange (double range[2]) |
| static vtkTable * | ComputeDataHistogramTable (vtkSMProxy *proxy, int numberOfBins) |
| | Helper method used to compute a histogram with provided number of bins based on the data from all the visible representations using the transfer function. More...
| virtual vtkTable * | ComputeDataHistogramTable (int numberOfBins) |
| static vtkTable * | GetHistogramTableCache (vtkSMProxy *proxy) |
| | Helper method used to recover the last histogram computed by ComputeDataHistogram Returns the histogram as a vtkTable if available, nullptr otherwise. More...
| virtual vtkTable * | GetHistogramTableCache () |
| static void | ResetPropertiesToDefaults (vtkSMProxy *proxy, const char *arrayName, bool preserve_range=false) |
| | Helper method to reset a transfer function proxy to its defaults. More...
| virtual void | ResetPropertiesToDefaults (const char *arrayName, bool preserve_range) |
| static bool | GetRange (vtkSMProxy *proxy, double range[2]) |
| | Returns current transfer function data range. More...
| virtual bool | GetRange (double range[2]) |
