exporter used to export the spreadsheet view and supported chart views as to a CSV file.
| void | Write () override |
| | Exports the view. More...
| bool | CanExport (vtkSMProxy *) override |
| | Returns if the view can be exported. More...
| void | SetView (vtkSMViewProxy *view) |
| | Set the view proxy to export. More...
| virtual vtkSMViewProxy * | GetView () |
| const std::vector< std::string > & | GetFileExtensions () const |
| | Returns the suggested file extensions for this exporter. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMCSVExporterProxy () |
| | ~vtkSMCSVExporterProxy () override |
| | vtkSMExporterProxy () |
| | ~vtkSMExporterProxy () override |
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
