| bool | HasExtract (const char *reg_group, const char *reg_name, int port_number) |
| | Overridden to handle server-notification messages. More...
| void | PushUpdatedStates () |
| | Push updated states from the client to the server in aggregate (originally, when the simulation was paused, multiple partial updates were pushed, resulting in the connection between client and server to sever). More...
| vtkSMSessionProxyManager * | GetInsituProxyManager () |
| | Provides access to the a dummy proxy manager representing the insitu visualization pipeline. More...
| void | SetInsituProxyManager (vtkSMSessionProxyManager *) |
| vtkSMProxy * | CreateExtract (const char *reg_group, const char *reg_name, int port_number) |
| void | RemoveExtract (vtkSMProxy *) |
| void | LiveChanged () |
| | Wakes up Insitu side if simulation is paused. More...
| vtkIdType | GetTimeStep () |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMLiveInsituLinkProxy () |
| | ~vtkSMLiveInsituLinkProxy () override |
| void | CreateVTKObjects () override |
| void | MarkStateDirty () |
| void | PushUpdatedState () |
| | Pushes XML state to the server if needed. More...
| void | InsituConnected (const char *initialial_state) |
| void | NextTimestepAvailable (vtkIdType timeStep) |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
