| vtkSMRepresentationProxy * | Pick (int x, int y) |
| | Convenience method to pick a location. More...
| vtkSMRepresentationProxy * | PickBlock (int x, int y, unsigned int &flatIndex) |
| | Convenience method to pick a block in a multi-block data set. More...
| bool | ConvertDisplayToPointOnSurface (const int display_position[2], double world_position[3], bool snapOnMeshPoint=false) |
| | Given a location is display coordinates (pixels), tries to compute and return the world location on a surface, if possible. More...
| virtual bool | IsSelectionAvailable () |
| | Checks if color depth is sufficient to support selection. More...
| virtual void | ZoomTo (vtkSMProxy *representation) |
| | Convenience method for zooming to a representation. More...
| void | SetupInteractor (vtkRenderWindowInteractor *iren) override |
| | A client process need to set the interactor to enable interactivity. More...
| vtkRenderWindowInteractor * | GetInteractor () override |
| | Returns the interactor. More...
| vtkRenderer * | GetRenderer () |
| | Returns the client-side renderer (composited or 3D). More...
| vtkCamera * | GetActiveCamera () |
| | Returns the client-side camera object. More...
| void | SynchronizeCameraProperties () |
| | This method calls UpdateInformation on the Camera Proxy and sets the Camera properties according to the info properties. More...
| virtual bool | LastRenderWasInteractive () |
| | Returns true if the most recent render indeed employed low-res rendering. More...
| void | Update () override |
| | Called vtkPVView::Update on the server-side. More...
| bool | GetNeedsUpdate () override |
| | We override that method to handle LOD and non-LOD NeedsUpdate in transparent manner. More...
| bool | StreamingUpdate (bool render_if_needed) |
| | Called to render a streaming pass. More...
| const char * | GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) override |
| | Overridden to check through the various representations that this view can create. More...
| vtkRenderWindow * | GetRenderWindow () override |
| | Returns the render window used by this view. More...
| vtkSMViewProxyInteractorHelper * | GetInteractorHelper () |
| | Provides access to the vtkSMViewProxyInteractorHelper object that handles the interaction/view sync. More...
| vtkFloatArray * | CaptureDepthBuffer () |
| | Access to the Z buffer. More...
| vtkFloatArray * | GetValuesFloat () |
| | Access to value-rendered array. More...
| bool | SelectSurfaceCells (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool select_blocks=false, const char *arrayName=nullptr) |
| | Makes a new selection source proxy. More...
| bool | SelectSurfacePoints (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool select_blocks=false, const char *arrayName=nullptr) |
| bool | SelectFrustumCells (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false) |
| bool | SelectFrustumPoints (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false) |
| bool | SelectPolygonPoints (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool selectBlocks=false) |
| bool | SelectPolygonCells (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool selectBlocks=false) |
| bool | ComputeVisibleScalarRange (const int region[4], int fieldAssociation, const char *scalarName, int component, double range[]) |
| | Returns the range for visible elements in the current view. More...
| bool | ComputeVisibleScalarRange (int fieldAssociation, const char *scalarName, int component, double range[]) |
| void | ResetCamera () |
| | For backwards compatibility in Python scripts. More...
| void | ResetCamera (double bounds[6]) |
| void | ResetCamera (double xmin, double xmax, double ymin, double ymax, double zmin, double zmax) |
| virtual const char * | IsSelectVisibleCellsAvailable () |
| | Similar to IsSelectionAvailable(), however, on failure returns the error message otherwise 0. More...
| virtual const char * | IsSelectVisiblePointsAvailable () |
| void | StartCaptureValues () |
| | Value raster capture controls. More...
| void | StopCaptureValues () |
| int | GetValueRenderingMode () |
| | Access to the current vtkValuePass rendering mode. More...
| void | SetValueRenderingMode (int mode) |
| virtual void | StillRender () |
| | Renders the view using full resolution. More...
| virtual void | InteractiveRender () |
| | Renders the view using lower resolution is possible. More...
| virtual bool | CanDisplayData (vtkSMSourceProxy *producer, int outputPort) |
| | Returns true if the view can display the data produced by the producer's port. More...
| virtual vtkSMRepresentationProxy * | CreateDefaultRepresentation (vtkSMProxy *, int) |
| | Create a default representation for the given source proxy. More...
| virtual vtkSMRepresentationProxy * | FindRepresentation (vtkSMSourceProxy *producer, int outputPort) |
| | Finds the representation proxy showing the data produced by the provided producer, if any. More...
| vtkView * | GetClientSideView () |
| | Returns the client-side vtkView, if any. More...
| int | WriteImage (const char *filename, const char *writerName, int magnification=1) |
| | Saves a screenshot of the view to disk. More...
| int | WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY) |
| virtual bool | HasDirtyRepresentation () |
| | Return true any internal representation is dirty. More...
| virtual bool | MakeRenderWindowInteractor (bool quiet=false) |
| | Creates a default render window interactor for the vtkRenderWindow and sets it up on the local process if the local process supports interaction. More...
| virtual void | SetEnable (bool) |
| | Enable/Disable a view. More...
| virtual bool | GetEnable () |
| virtual void | EnableOn () |
| virtual void | EnableOff () |
| vtkImageData * | CaptureWindow (int magnification) |
| | Captures a image from this view. More...
| vtkImageData * | CaptureWindow (int magnificationX, int magnificationY) |
| virtual bool | HideOtherRepresentationsIfNeeded (vtkSMProxy *repr) |
| | Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
| virtual void | RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility) |
| | Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMRenderViewProxy () |
| | ~vtkSMRenderViewProxy () override |
| void | RenderForImageCapture () override |
| | Overridden to call this->InteractiveRender() if "UseInteractiveRenderingForScreenshots" is true. More...
| void | UpdateLOD () |
| | Calls UpdateLOD() on the vtkPVRenderView. More...
| void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| | Overridden to ensure that we clean up the selection cache on the server side. More...
| bool | SelectFrustumInternal (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections, int fieldAssociation) |
| bool | SelectPolygonInternal (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections, int fieldAssociation, int modifier, bool selectBlocks) |
| vtkTypeUInt32 | PreRender (bool interactive) override |
| void | PostRender (bool interactive) override |
| bool | FetchLastSelection (bool multiple_selections, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, int modifier, bool selectBlocks) |
| | Fetches the LastSelection from the data-server and then converts it to a selection source proxy and returns that. More...
| void | CreateVTKObjects () override |
| | Called at the end of CreateVTKObjects(). More...
| bool | IsInSelectionMode () |
| | Returns true if the proxy is in interaction mode that corresponds to making a selection i.e. More...
| void | ClearSelectionCache (bool force=false) |
| void | NewMasterCallback (vtkObject *src, unsigned long event, void *data) |
| | vtkSMViewProxy () |
| | ~vtkSMViewProxy () override |
| virtual vtkImageData * | CaptureWindowInternal (int magnificationX, int magnificationY) |
| | Capture an image from the view's render window. More...
| virtual vtkTypeUInt32 | PreRender (bool vtkNotUsed(interactive)) |
| | This method is called before executing code that could cause a render on the underlying vtkPVView. More...
| virtual void | PostRender (bool vtkNotUsed(interactive)) |
| virtual bool | IsContextReadyForRendering () |
| | Subclasses should override this method and return false if the rendering context is not ready for rendering at this moment. More...
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| bool | GetLocalProcessSupportsInteraction () |
| | Convenience method to call vtkPVView::SafeDownCast(this->GetClientSideObject())->GetLocalProcessSupportsInteraction();. More...
| virtual vtkSMDataDeliveryManagerProxy * | GetDeliveryManager () |
| | Provides access to the delivery manager proxy, if any. More...
| virtual void | SetDefaultRepresentationName (const char *) |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
