is the representation corresponding to a scalar bar or color legend in a Render View.
| virtual vtkAbstractWidget * | GetWidget () |
| | Get the widget for the representation. More...
| virtual vtkSMProxy * | GetRepresentationProxy () |
| | Get Representation Proxy. More...
| bool | LinkProperties (vtkSMProxy *controlledProxy, vtkSMPropertyGroup *controlledPropertyGroup) |
| | Called to link properties from a Widget to controlledProxy i.e. More...
| bool | UnlinkProperties (vtkSMProxy *controlledProxy) |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMScalarBarWidgetRepresentationProxy () |
| | ~vtkSMScalarBarWidgetRepresentationProxy () override |
| void | CreateVTKObjects () override |
| | Overridden from vtkSMProxy to call BeginCreateVTKObjects() and EndCreateVTKObjects(). More...
| void | ExecuteEvent (unsigned long event) override |
| | Called every time the user interacts with the widget. More...
| | vtkSMNewWidgetRepresentationProxy () |
| | ~vtkSMNewWidgetRepresentationProxy () override |
| void | ProcessLinkedPropertyEvent (vtkSMProperty *controlledProperty, unsigned long event) |
| | Called everytime a controlled property's unchecked values change. More...
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
