| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMTimeKeeperProxy () |
| | ~vtkSMTimeKeeperProxy () override |
| void | CreateVTKObjects () override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
| static bool | AddTimeSource (vtkSMProxy *timeKeeper, vtkSMProxy *proxy, bool suppress_input) |
| | Track timesteps provided by a source. More...
| virtual bool | AddTimeSource (vtkSMProxy *proxy, bool suppress_input) |
| static bool | RemoveTimeSource (vtkSMProxy *timeKeeper, vtkSMProxy *proxy, bool unsuppress_input) |
| | Remove a particular time source. More...
| virtual bool | RemoveTimeSource (vtkSMProxy *proxy, bool unsuppress_input) |
| static bool | IsTimeSourceTracked (vtkSMProxy *timeKeeper, vtkSMProxy *proxy) |
| | Returns true if the proxy has been added to time sources and not suppressed. More...
| virtual bool | IsTimeSourceTracked (vtkSMProxy *proxy) |
| static bool | SetSuppressTimeSource (vtkSMProxy *timeKeeper, vtkSMProxy *proxy, bool suppress) |
| | Set whether to suppress a time source that has been added to the time keeper. More...
| virtual bool | SetSuppressTimeSource (vtkSMProxy *proxy, bool suppress) |
| static double | GetLowerBoundTimeStep (vtkSMProxy *timeKeeper, double value) |
| | Returns a time value after snapping to a lower-bound in the current timesteps. More...
| virtual double | GetLowerBoundTimeStep (double value) |
| static int | GetLowerBoundTimeStepIndex (vtkSMProxy *timeKeeper, double value) |
| | Returns the index for the lower bound of the time specified in current timestep values, if possible. More...
| virtual int | GetLowerBoundTimeStepIndex (double value) |
| static void | UpdateTimeInformation (vtkSMProxy *timeKeeper) |
| | Iterates over all sources providing time and calls vtkSMSourceProxy::UpdatePipelineInformation on them. More...
| virtual void | UpdateTimeInformation () |
