| virtual bool | WriteAnimation (const char *filename) |
| | Save animation as images/video. More...
| void | UpdateDefaultsAndVisibilities (const char *filename) override |
| | Overridden to update visibility state of "FrameRate" property. More...
| bool | WriteImage (const char *filename) |
| | Capture image. More...
| bool | WriteImage (const char *filename, vtkTypeUInt32 location) |
| | This is same as WriteImage(const char*) except that one can specify the location at which to write the image. More...
| vtkSmartPointer< vtkImageData > | CaptureImage () |
| | Capture the rendered image but doesn't save it out to any file. More...
| std::string | GetFileFormatFilters () |
| | Convenience method to derive a QFileDialog friendly format string for extensions supported by this proxy. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMSaveAnimationProxy () |
| | ~vtkSMSaveAnimationProxy () override |
| virtual bool | WriteAnimationLocally (const char *filename) |
| | Write animation on local process. More...
| bool | Prepare () override |
| | Prepares for saving animation. More...
| bool | Cleanup () override |
| | This restores the state after saving the animation. More...
| virtual bool | EnforceSizeRestrictions (const char *filename) |
| | Change "ImageResolution" property as needed for the file format requested. More...
| vtkSMViewLayoutProxy * | GetLayout () |
| vtkSMViewProxy * | GetView () |
| vtkSMSaveScreenshotProxy * | GetScreenshotHelper () |
| vtkSMProxy * | GetAnimationScene () |
| | vtkSMSaveScreenshotProxy () |
| | ~vtkSMSaveScreenshotProxy () override |
| std::pair< vtkSmartPointer< vtkImageData >, vtkSmartPointer< vtkImageData > > | CapturePreppedImages () |
| | When StereoMode is set to VTK_STEREO_EMULATE, both eyes are captures. More...
| vtkSMProxy * | GetFormatProxy (const std::string &filename) |
| | Select the format proxy to match the given extension. More...
| std::string | GetStereoFileName (const std::string &filename, bool left) |
| | Adds a stereo filename suffix to the given filename. More...
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
