baseclass for all proxy-objects that have counter parts on server as well as client processes. More...
#include <vtkSMRemoteObject.h>
| bool | HasGlobalID () |
| virtual const vtkSMMessage * | GetFullState () |
| This method return the full object state that can be used to create that object from scratch. More... | |
| virtual void | EnableLocalPushOnly () |
| virtual void | DisableLocalPushOnly () |
| virtual void | SetLocation (vtkTypeUInt32) |
| virtual void | PrototypeOn () |
| virtual void | PrototypeOff () |
| bool | IsPrototype () |
| virtual void | SetPrototype (bool) |
| virtual void | LoadState (const vtkSMMessage *msg, vtkSMProxyLocator *locator) |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes | |
| vtkTypeUInt32 | GlobalID |
| vtkTypeUInt32 | Location |
| bool | Prototype |
| bool | ClientOnlyLocationFlag |
Friends | |
| class | vtkSMStateHelper |
| class | vtkSMStateLoader |
Abstract class involved in ServerManager class hierarchy that has a corresponding SIObject which can be local or remote.
Definition at line 37 of file vtkSMRemoteObject.h.
Definition at line 44 of file vtkSMRemoteObject.h.
Default constructor.
Destructor.
Reimplemented from vtkSMSessionObject.
Reimplemented in vtkSMProxy, vtkSMMultiplexerSourceProxy, vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMCollaborationManager, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMOutputPort, vtkSMLoadStateOptionsProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMCompoundSourceProxy, vtkSMSelfGeneratingSourceProxy, vtkSMSaveScreenshotProxy, vtkSMDataDeliveryManagerProxy, vtkSMPVRepresentationProxy, vtkSMPipelineState, vtkSMProxySelectionModel, vtkSMNewWidgetRepresentationProxy, vtkSMRenderViewProxy, vtkSMSaveAnimationProxy, vtkSMContextViewProxy, vtkSMSaveAnimationExtractsProxy, vtkSMLiveInsituLinkProxy, vtkSMProxyDefinitionManager, vtkSMComparativeViewProxy, vtkSMLink, vtkSMTransferFunctionProxy, vtkSMPythonViewProxy, vtkSMProxyLink, vtkSMComparativeAnimationCueProxy, vtkPVRepresentationAnimationHelper, vtkSMCSVExporterProxy, vtkSMExporterProxy, vtkSMDataSourceProxy, vtkSMPropertyLink, vtkSMImageExtractWriterProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMSelectionLink, vtkSMMultiServerSourceProxy, vtkSMExtractTriggerProxy, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCameraLink, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMDirectoryProxy, vtkSMPWriterProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMRenderViewExporterProxy, vtkSMExtractWriterProxy, vtkSMPluginLoaderProxy, vtkSMPSWriterProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMaterialLibraryProxy, vtkSMMultiSliceViewProxy, vtkSMAnimationSceneProxy, vtkSMDataExtractWriterProxy, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMGL2PSExporterProxy, vtkSMEnsembleDataReaderProxy, vtkSMNullProxy, vtkSMTimeKeeperProxy, and vtkSMOrthographicSliceViewProxy.
Reimplemented in vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMSelfGeneratingSourceProxy, vtkSMSaveScreenshotProxy, vtkSMDataDeliveryManagerProxy, vtkSMPVRepresentationProxy, vtkSMNewWidgetRepresentationProxy, vtkSMRenderViewProxy, vtkSMContextViewProxy, vtkSMComparativeViewProxy, vtkSMTransferFunctionProxy, vtkSMPythonViewProxy, vtkSMComparativeAnimationCueProxy, vtkSMImageExtractWriterProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMSelectionLink, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCameraLink, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMaterialLibraryProxy, vtkSMMultiSliceViewProxy, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMTimeKeeperProxy, and vtkSMOrthographicSliceViewProxy.
Get/Set the location where the underlying VTK-objects are created.
The value can be constructed by or-ing vtkSMSession::ServerFlags
Reimplemented in vtkSMProxy.
Override the SetSession so if the object already have an ID we automatically register it to the associated session.
Get the global unique id for this object.
If none is set and the session is valid, a new global id will be assigned automatically.
Reimplemented in vtkSMSourceProxy, vtkSMRepresentationProxy, and vtkSMCollaborationManager.
| const char* vtkSMRemoteObject::GetGlobalIDAsString | ( | ) |
| bool vtkSMRemoteObject::HasGlobalID | ( | ) |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it.
Allow user to set the remote object to be discard for Undo/Redo action.
By default, any remote object is Undoable.
Definition at line 83 of file vtkSMRemoteObject.h.
inlinevirtual |
This method will be used to fill the undo stack. If not overridden this will return NULL.
Reimplemented in vtkSMProxy, vtkSMCollaborationManager, vtkSMProxySelectionModel, vtkSMLink, and vtkSMPipelineState.
Definition at line 93 of file vtkSMRemoteObject.h.
inlinevirtual |
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented in vtkSMProxy, vtkSMViewLayoutProxy, vtkSMProxyDefinitionManager, vtkSMCollaborationManager, vtkSMMultiplexerSourceProxy, vtkSMProxySelectionModel, vtkSMProxyLink, vtkSMPropertyLink, vtkSMLink, vtkSMSelectionLink, vtkSMCameraLink, vtkSMLiveInsituLinkProxy, vtkSMMultiServerSourceProxy, and vtkSMPipelineState.
Definition at line 103 of file vtkSMRemoteObject.h.
Allow to switch off any push of state change to the server for that particular object.
This is used when we load a state based on a server notification. In that particular case, the server is already aware of that new state, so we keep those changes local.
Enable the given remote object to communicate its state normally to the server location.
inlinevirtual |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast.
Definition at line 129 of file vtkSMRemoteObject.h.
Subclasses can call this method to send a message to its state object on the server processes specified.
Subclasses can call this method to pull the state from the state-object on the server processes specified.
Returns true on successful fetch. The message is updated with the fetched state.
Set the GlobalUniqueId.
friend |
Definition at line 40 of file vtkSMRemoteObject.h.
friend |
Definition at line 41 of file vtkSMRemoteObject.h.
Definition at line 165 of file vtkSMRemoteObject.h.
Definition at line 169 of file vtkSMRemoteObject.h.
Definition at line 173 of file vtkSMRemoteObject.h.
Definition at line 176 of file vtkSMRemoteObject.h.
