| virtual bool | PrepareToLoad (const char *statefilename) |
| | Set the state file to load. More...
| virtual bool | HasDataFiles () |
| | Check if state file has any data files. More...
| virtual bool | Load () |
| | Do the state loading using the values for properties on this proxy to configure the state loading i.e. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMLoadStateOptionsProxy () |
| | ~vtkSMLoadStateOptionsProxy () override |
| bool | LocateFilesInDirectory (std::vector< std::string > &filepaths, int path, bool clearFilenameIfNotFound) |
| | Locates the files in the user specified directory and updates the paths in the state file XML. More...
| virtual void | SetStateFileName (const char *) |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
proxy for state loading options
vtkSMLoadStateOptionsProxy is the proxy used to setup options when loading a state file. These including choosing how to handle data files referenced in the state. This proxy supports multiple ways to let the user update the files being loaded in the state file.
To use this, create the ("options", "LoadStateOptions") proxy using the session's proxy manager and call PrepareToLoad with the state file to load. This will parse the state file and setup internal data structures. At this point, you can call HasDataFiles method to determine if the state file has any data files. This can be used to determine if the application should prompt the user with options, for example. One can change options using properties on the options proxy itself. Following PrepareToLoad, the proxy will present additional properties that allows the user to pick filenames for readers in the state file. Call Load to load the state file.
This proxy is not intended for reuse. Simply create a new one for each state to load.
Definition at line 45 of file vtkSMLoadStateOptionsProxy.h.
