| void | SetViewProxy (vtkSMViewProxy *) |
| | Get/Set the view proxy for whom we are delivering the data. More...
| void | Deliver (bool interactive) |
| | Called to request delivery of the geometry. More...
| bool | DeliverStreamedPieces () |
| | EXPERIMEMTAL: Delivery when streaming is enabled. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMDataDeliveryManagerProxy () |
| | ~vtkSMDataDeliveryManagerProxy () override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
