helper proxy used to animate properties on the representations for any source.
| void | SetVisibility (int) |
| | Don't use directly. More...
| void | SetOpacity (double) |
| void | SetSourceProxy (vtkSMProxy *proxy) |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkPVRepresentationAnimationHelper () |
| | ~vtkPVRepresentationAnimationHelper () override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
