proxy subclass responsible for linking settings proxies and settings classes on the VTK side.
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| | Overridden to link information properties with their corresponding "setter" properties. More...
| const char * | GetSourcePropertyName (vtkSMProxy *target, const char *targetProperty) |
| | Returns the name of the sourceProperty, if any, with which the target property is linked. More...
| void | AddLink (const char *sourceProperty, vtkSMProxy *target, const char *targetProperty, bool unlink_if_modified) |
| | Add/Remove links. More...
| void | RemoveLink (const char *sourceProperty, vtkSMProxy *target, const char *targetProperty) |
| void | SaveLinksState (vtkPVXMLElement *root) |
| | Save/Load the state for links registered with this settings proxy. More...
| void | LoadLinksState (vtkPVXMLElement *root, vtkSMProxyLocator *locator) |
| virtual void | SetIsSerializable (bool) |
| | Get/Set whether the settings proxy is serializable. More...
| virtual bool | GetIsSerializable () |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMSettingsProxy () |
| | ~vtkSMSettingsProxy () override |
| void | CreateVTKObjects () override |
| | Overridden from vtkSMProxy to install an observer on the VTK object. More...
| void | SetPropertyModifiedFlag (const char *name, int flag) override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
Settings proxies are session specific singleton proxies designed to track configuration options. Typically, properties on such settings proxies are linked to other proxies in the session so that changing a setting property will result in changing all linked proxies.
Settings proxies have several unique traits when compared with other properties:
- In
ReadXMLAttributes, if for a property an information_property attribute is specified i.e. vtkSMProperty::GetInformationProperty is not null, then a link is setup between that information property and the original property so that if the information property is modified, the original property is updated accordingly.
- Settings proxies may have an underlying vtkObject class that they instantiate locally. In which case, the proxy observes vtkCommand::ModifiedEvent on that VTK object and calls
vtkSMProxy::UpdatePropertyInformation on itself to ensure all information properties are updated if the vtkObject changes.
vtkSMSettingsProxy::ProcessPropertyLinks is called during proxy initialization (vtkSMParaViewPipelineController::PreInitializeProxy) to setup links between the proxy being initialized any of the settings proxies for that session. This is done by processing property hints on the proxy being initialized.
SettingsProxies and state files
By default, settings proxies are not saved in the XML state files by vtkSMSessionProxyManager::SaveXMLState. This is so since settings proxies are often used for application settings to preserve across sessions rather than visualization state. However, there are exceptions. For example, color palettes which are handled using a settings proxy are part of the visualization state and hence should be saved in the XML state. For such settings proxies, one can add the serializable="1" attribute in the proxy definition XML.
<SettingsProxy name="ColorPalette" label="Color Palette" serializable="1">
</SettingsProxy>
All settings proxies with this attribute will be saved in the XML state files.
Definition at line 71 of file vtkSMSettingsProxy.h.
