| void | Synchronize () |
| | Copies the Material library on the root node of server to the client. More...
| void | LoadDefaultMaterials () |
| | Reads default materials on the process. More...
| void | LoadMaterials (const char *) |
| | Reads and specified materials. More...
| void | UpdateVTKObjects () override |
| | Overridden to control load from server file system. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMMaterialLibraryProxy () |
| | ~vtkSMMaterialLibraryProxy () override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
