| virtual bool | Write (vtkSMExtractsController *extractor)=0 |
| | Generate the extract. More...
| virtual bool | CanExtract (vtkSMProxy *proxy)=0 |
| | Returns true if the provided proxy can be extracted/written by this writer. More...
| virtual bool | IsExtracting (vtkSMProxy *proxy)=0 |
| | Returns true this extract writer proxy is generating and extract from the provided proxy. More...
| virtual void | SetInput (vtkSMProxy *proxy)=0 |
| | This is convenience method that gets called by vtkSMExtractsController to set the extract writer to extract the given proxy. More...
| virtual vtkSMProxy * | GetInput ()=0 |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMExtractWriterProxy () |
| | ~vtkSMExtractWriterProxy () override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
