| bool | Write (vtkSMExtractsController *extractor) override |
| | Implementation for vtkSMExtractWriterProxy API. More...
| bool | CanExtract (vtkSMProxy *proxy) override |
| bool | IsExtracting (vtkSMProxy *proxy) override |
| void | SetInput (vtkSMProxy *proxy) override |
| vtkSMProxy * | GetInput () override |
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMImageExtractWriterProxy () |
| | ~vtkSMImageExtractWriterProxy () override |
| void | CreateVTKObjects () override |
| bool | WriteImage (vtkSMExtractsController *extractor, const SummaryParametersT &cameraParams=SummaryParametersT{}) |
| | Save a single image. More...
| virtual bool | WriteInternal (vtkSMExtractsController *extractor, const SummaryParametersT ¶ms=SummaryParametersT{}) |
| | Called in Write(). More...
| virtual const char * | GetShortName (const std::string &key) const |
| | Used to convert a parameter name used in the SummaryParametersT to a shorter version suitable for use in filename. More...
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
