| void | UpdatePipeline () override |
| | Updates the pipeline and writes the file(s). More...
| void | UpdatePipeline (double time) override |
| virtual void | SetSupportsParallel (int) |
| | Flag indicating if the writer supports writing in parallel. More...
| int | GetSupportsParallel () |
| virtual int | GetParallelOnly () |
| | Flag indicating if the writer works only in parallel. More...
| virtual void | SetParallelOnly (int) |
| void | UpdatePipelineInformation () override |
| | Calls UpdateInformation() on all sources. More...
| virtual unsigned int | GetNumberOfOutputPorts () |
| | Return the number of output ports. More...
| virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
| | Return an output port. More...
| virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
| | Return an output port, given the name for the port. More...
| virtual unsigned int | GetOutputPortIndex (const char *portname) |
| | Returns the port index, given the name of an output port. More...
| virtual const char * | GetOutputPortName (unsigned int index) |
| | Returns the output port name given its index. More...
| virtual void | CreateOutputPorts () |
| | Creates the output port proxies for this filter. More...
| virtual void | CreateSelectionProxies () |
| | Creates extract selection proxies for each output port if not already created. More...
| void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
| | Set/Get the selection input. More...
| void | CleanSelectionInputs (unsigned int portIndex) |
| | Clean all selection inputs for the given port. More...
| vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
| | Returns the source proxy which provides the selected data from the given output port. More...
| unsigned int | GetNumberOfAlgorithmOutputPorts () |
| | Returns the number of output ports provided by the algorithm. More...
| virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
| | Returns the number of non-optional input ports required by the algorithm. More...
| vtkTypeUInt32 | GetGlobalID () override |
| | Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
| void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| | Marks the selection proxies dirty as well as chain to superclass. More...
| virtual int | GetOutputPortsCreated () |
| | Returns if the output port proxies have been created. More...
| vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
| | It is possible to provide some documentation for each output port in the configuration xml. More...
| vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
| vtkPVDataInformation * | GetDataInformation () |
| | DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
| vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
| vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
| | API to query selection input set using SetSelectionInput. More...
| unsigned int | GetSelectionInputPort (unsigned int portIndex) |
| virtual int | GetProcessSupport () |
| | This returns information about whether the VTK algorithm supports multiple processes or not. More...
| virtual bool | GetMPIRequired () |
| | This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMWriterProxy () |
| | ~vtkSMWriterProxy () override |
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| virtual void | SetFileNameMethod (const char *) |
| virtual char * | GetFileNameMethod () |
| | vtkSMSourceProxy () |
| | ~vtkSMSourceProxy () override |
| virtual void | InvalidateDataInformation () |
| | Mark the data information as invalid. More...
| void | CreateVTKObjects () override |
| | Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
| virtual void | SetExecutiveName (const char *) |
| void | PostUpdateData (bool) override |
| | Overwritten from superclass to invoke. More...
| void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override |
| | Overridden to pass the logname to the internal ExtractSelection proxies. More...
| void | SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc) |
| | Method to set an output port at the given index. More...
| void | RemoveAllOutputPorts () |
| void | SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy) |
| void | RemoveAllExtractSelectionProxies () |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
