| bool | MakeDirectory (const char *dir) |
| | Create directory. More...
| bool | DeleteDirectory (const char *dir) |
| | Remove a directory. More...
| bool | Rename (const char *oldname, const char *newname) |
| | Rename a file or directory. More...
| bool | List (const char *dir) |
| | List server side directory NEVER USED IN PARAVIEW, TODO ? More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMDirectoryProxy () |
| | ~vtkSMDirectoryProxy () override |
| bool | CallDirectoryMethod (const char *method, const char *path, const char *secondaryPath=NULL) |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
