vtkSMProxy Class Reference
proxy for a VTK object(s) on a server More...
#include <vtkSMProxy.h>
Inheritance diagram for vtkSMProxy:
Collaboration diagram for vtkSMProxy:
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Friends
class vtkSMProxyInfo
class vtkSMCameraLink
 These classes have been declared as friends to minimize the public interface exposed by vtkSMProxy. More...
class vtkSMCompoundProxy
class vtkSMCompoundSourceProxy
class vtkSMDeserializerProtobuf
class vtkSMInputProperty
class vtkSMMultiServerSourceProxy
class vtkSMNamedPropertyIterator
class vtkSMOrderedPropertyIterator
class vtkSMPreselectionPipeline
class vtkSMProperty
class vtkSMPropertyIterator
class vtkSMProxyObserver
class vtkSMProxyProperty
class vtkSMProxyRegisterUndoElement
class vtkSMProxyUnRegisterUndoElement
class vtkSMSessionProxyManager
class vtkSMSourceProxy
class vtkSMStateLoader
class vtkSMStateLocator
class vtkSMUndoRedoStateLoader
class vtkSMViewProxy
char * SIClassName
vtkSMProxy manages VTK object(s) that are created on a server using the proxy pattern. The managed object is manipulated through properties. The type of object created and managed by vtkSMProxy is determined by the VTKClassName variable. The object is managed by getting the desired property from the proxy, changing it's value and updating the server with UpdateVTKObjects(). A proxy can be composite. Sub-proxies can be added by the proxy manager. This is transparent to the user who sees all properties as if they belong to the root proxy.
A proxy keeps an iVar ConnectionID. This is the connection ID for the connection on which this proxy exists. Currently, since a ParaView client is connected to 1 and only 1 server. This ID is insignificant. However, it provides the ground work to enable a client to connect with multiple servers. ConnectionID must be set immediately after instantiating the proxy (if at all). Changing the ConnectionID after that can be dangerous.
Once a proxy has been defined, it can be listed in another secondary group
<ProxyGroup name="new_group">
< Proxy group = "group" name ="proxyname" />
</ProxyGroup>
When defining a proxy in the XML configuration file, to derive the property interface from another proxy definition, we can use attributes "base_proxygroup" and "base_proxyname" which identify the proxy group and proxy name of another proxy. Base interfaces can be defined recursively, however care must be taken to avoid cycles.
There are several special XML features available for subproxies.
See also
vtkSMProxyManager vtkSMProperty vtkSMSourceProxy vtkSMPropertyIterator
Definition at line 140 of file vtkSMProxy.h.
Definition at line 144 of file vtkSMProxy.h.
◆ ResetPropertiesMode
Enumerator
DEFAULT
ONLY_XML
ONLY_DOMAIN
Definition at line 369 of file vtkSMProxy.h.
◆ anonymous enum
anonymous enum
Flags used for the proxyPropertyCopyFlag argument to the Copy method.
Enumerator
COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE
COPY_PROXY_PROPERTY_VALUES_BY_CLONING
Definition at line 390 of file vtkSMProxy.h.
◆ vtkSMProxy() [1/2]
vtkSMProxy::vtkSMProxy ( )
◆ ~vtkSMProxy()
vtkSMProxy::~vtkSMProxy ( )
◆ vtkSMProxy() [2/2]
vtkSMProxy::vtkSMProxy ( const vtkSMProxy &  )
protecteddelete
static vtkSMProxy* vtkSMProxy::New ( )
virtual const char* vtkSMProxy::GetClassName ( )
Reimplemented from vtkSMRemoteObject.
Reimplemented in vtkSMMultiplexerSourceProxy, vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMLoadStateOptionsProxy, vtkSMOutputPort, vtkSMPVRepresentationProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMCompoundSourceProxy, vtkSMSelfGeneratingSourceProxy, vtkSMSaveScreenshotProxy, vtkSMTransferFunction2DProxy, vtkSMDataDeliveryManagerProxy, vtkSMRenderViewProxy, vtkSMSaveAnimationProxy, vtkSMImporterProxy, vtkSMContextViewProxy, vtkSMNewWidgetRepresentationProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMSaveAnimationExtractsProxy, vtkSMLiveInsituLinkProxy, vtkSMNewWidgetRepresentationProxyAbstract, vtkSMTransferFunctionProxy, vtkSMComparativeViewProxy, vtkSMPlotlyJsonExtractWriterProxy, vtkSMRecolorableImageExtractWriterProxy, vtkSMPythonViewProxy, vtkSMVRInteractorStyleProxy, vtkSMVRStylusStyleProxy, vtkSMExtractTriggerProxy, vtkSMComparativeAnimationCueProxy, vtkSMVRPythonInteractorStyleProxy, vtkPVRepresentationAnimationHelper, vtkSMCSVExporterProxy, vtkSMExporterProxy, vtkSMDataSourceProxy, vtkSMImageExtractWriterProxy, vtkSMNew2DWidgetRepresentationProxy, vtkSMVRMovePointStyleProxy, vtkSMMultiServerSourceProxy, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMVRGrabPointStyleProxy, vtkSMVRGrabTransformStyleProxy, vtkSMVRGrabWorldStyleProxy, vtkSMVRResetTransformStyleProxy, vtkSMVRSkeletonStyleProxy, vtkSMVRSpaceNavigatorGrabWorldStyleProxy, vtkSMVRTrackStyleProxy, vtkSMVRVirtualHandStyleProxy, vtkSMDirectoryProxy, vtkSMPWriterProxy, vtkSMContextItemWidgetProxy, vtkSMMaterialLibraryProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMRenderViewExporterProxy, vtkSMExtractWriterProxy, vtkSMPluginLoaderProxy, vtkSMPSWriterProxy, vtkSMDisplaySizedImplicitPlaneRepresentationProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMultiSliceViewProxy, vtkSMAnimationSceneProxy, vtkSMEnsembleDataReaderProxy, vtkSMDataExtractWriterProxy, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMGL2PSExporterProxy, vtkSMNullProxy, vtkSMTimeKeeperProxy, vtkSMVRControlSlicePositionStyleProxy, vtkSMOrthographicSliceViewProxy, and vtkSMVRControlSliceOrientationStyleProxy.
static int vtkSMProxy::IsTypeOf ( const char *  type)
virtual int vtkSMProxy::IsA ( const char *  type)
static vtkSMProxy* vtkSMProxy::SafeDownCast ( vtkObject *  o)
void vtkSMProxy::PrintSelf ( ostream &  os,
◆ SetAnnotation()
void vtkSMProxy::SetAnnotation ( const char *  key,
const char *  value
◆ GetAnnotation()
const char* vtkSMProxy::GetAnnotation ( const char *  key)
Retrieve an annotation with a given key.
If not found, this will return nullptr.
◆ RemoveAnnotation()
void vtkSMProxy::RemoveAnnotation ( const char *  key)
Remove a given annotation based on its key to the proxy.
◆ RemoveAllAnnotations()
void vtkSMProxy::RemoveAllAnnotations ( )
Remove all proxy annotations.
◆ HasAnnotation()
bool vtkSMProxy::HasAnnotation ( const char *  key)
Return true if a given annotation exists.
◆ GetNumberOfAnnotations()
int vtkSMProxy::GetNumberOfAnnotations ( )
Return the number of available annotations.
◆ GetAnnotationKeyAt()
const char* vtkSMProxy::GetAnnotationKeyAt ( int  index)
Return the nth key of the available annotations.
◆ SetLocation()
void vtkSMProxy::SetLocation ( vtkTypeUInt32  )
Get/Set the location where the underlying VTK-objects are created.
The value can be constructed by or-ing vtkSMSession::ServerFlags
◆ GetProperty() [1/2]
virtual vtkSMProperty* vtkSMProxy::GetProperty ( const char *  name)
inlinevirtual
Return the property with the given name.
If no property is found nullptr is returned.
Definition at line 193 of file vtkSMProxy.h.
◆ GetProperty() [2/2]
virtual vtkSMProperty* vtkSMProxy::GetProperty ( const char *  name,
int  selfOnly
Return a property of the given name from self or one of the sub-proxies.
If selfOnly is set, the sub-proxies are not checked.
◆ GetPropertyName()
const char* vtkSMProxy::GetPropertyName ( vtkSMProperty *  prop)
Given a property pointer, returns the name that was used to add it to the proxy.
Returns nullptr if the property is not in the proxy. If the property belongs to a sub-proxy, it returns the exposed name or nullptr if the property is not exposed.
◆ UpdateVTKObjects()
virtual void vtkSMProxy::UpdateVTKObjects ( )
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored).
If the object has not been created, it will be created first.
Reimplemented in vtkSMRenderViewProxy, vtkSMCompoundSourceProxy, vtkSMVRPythonInteractorStyleProxy, vtkSMMaterialLibraryProxy, vtkSMBoxRepresentationProxy, and vtkSMEnsembleDataReaderProxy.
◆ RecreateVTKObjects()
virtual void vtkSMProxy::RecreateVTKObjects ( )
Recreate the VTK object for this proxy.
This is a convenient mechanism to create a new VTK object with the same state as an existing one in its stead.
Reimplemented in vtkSMVRPythonInteractorStyleProxy.
◆ UpdateProperty() [1/2]
bool vtkSMProxy::UpdateProperty ( const char *  name)
inline
Update the value of one property (pushed to the server) if it is modified.
If the object has not been created, it will be created first. If force is true, the property is pushed even if it not modified. Return true if UpdateProperty pushes the property value.
Definition at line 235 of file vtkSMProxy.h.
◆ UpdateProperty() [2/2]
bool vtkSMProxy::UpdateProperty ( const char *  name,
int  force
◆ InvokeCommand()
void vtkSMProxy::InvokeCommand ( const char *  name)
inline
Convenience method equivalent to UpdateProperty(name, 1).
Definition at line 242 of file vtkSMProxy.h.
◆ GetVTKClassName()
virtual char* vtkSMProxy::GetVTKClassName ( )
Returns the type of object managed by the proxy.
◆ SetVTKClassName()
virtual void vtkSMProxy::SetVTKClassName ( const char *  )
the type of object created by the proxy.
This is used only when creating the server objects. Once the server object(s) have been created, changing this has no effect.
◆ NewPropertyIterator()
virtual vtkSMPropertyIterator* vtkSMProxy::NewPropertyIterator ( )
Returns a new (initialized) iterator of the properties.
◆ GetNumberOfConsumers()
unsigned int vtkSMProxy::GetNumberOfConsumers ( )
Returns the number of consumers.
Consumers are proxies that point to this proxy through a property (usually vtkSMProxyProperty)
◆ GetConsumerProxy()
vtkSMProxy* vtkSMProxy::GetConsumerProxy ( unsigned int  idx)
Returns the consumer of given index.
◆ GetConsumerProperty()
vtkSMProperty* vtkSMProxy::GetConsumerProperty ( unsigned int  idx)
Returns the corresponding property of the consumer of given index.
◆ GetNumberOfProducers()
unsigned int vtkSMProxy::GetNumberOfProducers ( )
Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline).
◆ GetProducerProxy()
vtkSMProxy* vtkSMProxy::GetProducerProxy ( unsigned int  idx)
Returns a proxy this proxy depends on, given index.
◆ GetProducerProperty()
vtkSMProperty* vtkSMProxy::GetProducerProperty ( unsigned int  idx)
Returns the property holding a producer proxy given an index.
Note that this is a property of this proxy and it points to the producer proxy.
◆ GetXMLName()
virtual char* vtkSMProxy::GetXMLName ( )
Assigned by the XML parser.
The name assigned in the XML configuration. Can be used to figure out the origin of the proxy.
◆ GetXMLGroup()
virtual char* vtkSMProxy::GetXMLGroup ( )
The group in the XML configuration that this proxy belongs to. Can be used to figure out the origin of the proxy.
◆ GetXMLLabel()
virtual char* vtkSMProxy::GetXMLLabel ( )
The label assigned in the XML configuration. This is a more user-friendly name for the proxy, although it's cannot be used to locate the proxy.
◆ UpdatePropertyInformation() [1/2]
virtual void vtkSMProxy::UpdatePropertyInformation ( )
Updates all property information by calling UpdateInformation() and populating the values.
Reimplemented in vtkSMCameraProxy, and vtkSMBoxRepresentationProxy.
◆ UpdatePropertyInformation() [2/2]
virtual void vtkSMProxy::UpdatePropertyInformation ( vtkSMProperty *  prop)
Similar to UpdatePropertyInformation() but updates only the given property.
If the property does not belong to the proxy, the call is ignored.
◆ MarkAllPropertiesAsModified()
virtual void vtkSMProxy::MarkAllPropertiesAsModified ( )
Marks all properties as modified.
This will cause them all to be sent to be sent on the next call to UpdateVTKObjects. This method is useful when the proxy is first created to make sure that the default property values in the properties is synced with the values in the actual objects.
◆ ResetPropertiesToXMLDefaults()
virtual void vtkSMProxy::ResetPropertiesToXMLDefaults ( )
Use this method to set all properties on this proxy to their default values.
This iterates over all properties on this proxy, thus if this proxy had subproxies, this method will iterate over only the exposed properties and call vtkSMProperty::ResetToXMLDefaults().
◆ ResetPropertiesToDomainDefaults()
virtual void vtkSMProxy::ResetPropertiesToDomainDefaults ( )
Use this method to set all properties on this proxy to their default domains.
This iterates over all properties on this proxy, thus if this proxy had subproxies, this method will iterate over only the exposed properties and call vtkSMProperty::ResetToDomainDefaults().
◆ ResetPropertiesToDefault()
virtual void vtkSMProxy::ResetPropertiesToDefault ( ResetPropertiesMode  mode = DEFAULT)
Use this method to set all properties on this proxy to their default domain or values.
This iterates over all properties on this proxy, thus if this proxy had subproxies, this method will iterate over only the exposed properties and call correct reset methods. The parameter allows to choose between resetting ONLY_XML, ONLY_DOMAIN or DEFAULT, ie. reset to domain if available, if not reset to xml. default value is DEFAULT.
◆ Copy() [1/3]
void vtkSMProxy::Copy ( vtkSMProxy *  src)
Copies values of all the properties and sub-proxies from src.
NOTE: This does NOT create properties and sub-proxies. Only copies values. Mismatched property and sub-proxy pairs are ignored. Properties of type exceptionClass are not copied. This is usually vtkSMInputProperty. proxyPropertyCopyFlag specifies how the values for vtkSMProxyProperty and its subclasses are copied over: by reference or by cloning (ie. creating new instances of the value proxies and synchronizing their values). This is no longer relevant since we don't support COPY_PROXY_PROPERTY_VALUES_BY_CLONING anymore.
◆ Copy() [2/3]
void vtkSMProxy::Copy ( vtkSMProxy *  src,
const char *  exceptionClass
◆ Copy() [3/3]
virtual void vtkSMProxy::Copy ( vtkSMProxy *  src,
const char *  exceptionClass,
int  proxyPropertyCopyFlag
◆ MarkModified()
virtual void vtkSMProxy::MarkModified ( vtkSMProxy *  modifiedProxy)
Calls MarkDirty() and invokes ModifiedEvent.
◆ GetDocumentation()
virtual vtkSMDocumentation* vtkSMProxy::GetDocumentation ( )
Returns the documentation for this proxy.
◆ GetHints()
virtual vtkPVXMLElement* vtkSMProxy::GetHints ( )
The server manager configuration XML may define <Hints/> element for a proxy.
Hints are metadata associated with the proxy. The Server Manager does not (and should not) interpret the hints. Hints provide a mechanism to add GUI pertinant information to the server manager XML. Returns the XML element for the hints associated with this proxy, if any, otherwise returns nullptr.
◆ GetObjectsCreated()
virtual int vtkSMProxy::GetObjectsCreated ( )
Returns if the VTK objects for this proxy have been created.
◆ IsDeprecated()
bool vtkSMProxy::IsDeprecated ( )
inline
Returns true if the proxy has a deprecation tag.
Definition at line 450 of file vtkSMProxy.h.
◆ InitializeAndCopyFromProxy()
void vtkSMProxy::InitializeAndCopyFromProxy ( vtkSMProxy *  source)
Given a source proxy, makes this proxy point to the same server-side object (with a new id).
This method copies connection id as well as server ids. This method can be called only once on an uninitialized proxy (CreateVTKObjects() also initialized a proxy) This is useful to make two (or more) proxies represent the same VTK object. This method does not copy IDs for any subproxies.
◆ MarkDirty()
virtual void vtkSMProxy::MarkDirty ( vtkSMProxy *  modifiedProxy)
Dirty means this algorithm will execute during next update.
This all marks all consumers as dirty.
Reimplemented in vtkSMRenderViewProxy, vtkSMSourceProxy, vtkSMRepresentationProxy, vtkSMComparativeViewProxy, and vtkSMMultiServerSourceProxy.
◆ GetClientSideObject()
vtkObjectBase* vtkSMProxy::GetClientSideObject ( )
Returns the client side object associated with the VTKObjectID (if any).
Returns 0 otherwise.
◆ GatherInformation() [1/2]
bool vtkSMProxy::GatherInformation ( vtkPVInformation *  information)
Gathers information about this proxy.
On success, the information object is filled up with details about the VTK object.
◆ GatherInformation() [2/2]
bool vtkSMProxy::GatherInformation ( vtkPVInformation *  information,
vtkTypeUInt32  location
◆ SaveXMLState() [1/2]
virtual vtkPVXMLElement* vtkSMProxy::SaveXMLState ( vtkPVXMLElement *  root)
Saves the state of the proxy.
This state can be reloaded to create a new proxy that is identical the present state of this proxy. The resulting proxy's XML hieratchy is returned, in addition if the root argument is not nullptr then it's also inserted as a nested element. This call saves all a proxy's properties, including exposed properties and sub-proxies. More control is provided by the following overload.
Reimplemented in vtkSMViewLayoutProxy, and vtkSMComparativeAnimationCueProxy.
◆ SaveXMLState() [2/2]
virtual vtkPVXMLElement* vtkSMProxy::SaveXMLState ( vtkPVXMLElement *  root,
vtkSMPropertyIterator *  iter
The iterator is use to filter the property available on the given proxy.
Reimplemented in vtkSMViewLayoutProxy, vtkSMMultiplexerSourceProxy, vtkSMComparativeAnimationCueProxy, and vtkSMSelfGeneratingSourceProxy.
◆ LoadXMLState()
virtual int vtkSMProxy::LoadXMLState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  locator
Loads the proxy state from the XML element.
Returns 0 on failure. locator is used to locate other proxies that may be referred to in the state XML (which happens in case of properties of type vtkSMProxyProperty or subclasses). If locator is nullptr, then such properties are left unchanged.
Reimplemented in vtkSMViewLayoutProxy, vtkSMRepresentationProxy, vtkSMMultiplexerSourceProxy, vtkSMComparativeAnimationCueProxy, vtkSMAnimationSceneProxy, and vtkSMSelfGeneratingSourceProxy.
◆ PrototypeOn()
void vtkSMProxy::PrototypeOn ( )
Allow user to set the remote object to be discard for Undo/Redo action.
By default, any remote object is Undoable. This override the RemoteObject ones to propagate the flag to the sub-proxy
◆ PrototypeOff()
void vtkSMProxy::PrototypeOff ( )
◆ SetPrototype()
void vtkSMProxy::SetPrototype ( bool  undo)
◆ UpdateSelfAndAllInputs()
void vtkSMProxy::UpdateSelfAndAllInputs ( )
This method call UpdateVTKObjects on the current pipeline by starting at the sources.
The sources are found by getting the Input of all the filter along the pipeline.
◆ GetIsSubProxy()
bool vtkSMProxy::GetIsSubProxy ( )
A proxy instance can be a sub-proxy for some other proxy.
In that case, this method returns true.
◆ GetParentProxy()
vtkSMProxy* vtkSMProxy::GetParentProxy ( )
If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy.
◆ GetTrueParentProxy()
vtkSMProxy* vtkSMProxy::GetTrueParentProxy ( )
Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found.
May return this instance, if this is not a subproxy of any other proxy.
◆ EnableLocalPushOnly()
void vtkSMProxy::EnableLocalPushOnly ( )
Allow to switch off any push of state change to the server for that particular object.
This is used when we load a state based on a server notification. In that particular case, the server is already aware of that new state, so we keep those changes local.
◆ DisableLocalPushOnly()
void vtkSMProxy::DisableLocalPushOnly ( )
Enable the given remote object to communicate its state normally to the server location.
◆ GetFullState()
const vtkSMMessage* vtkSMProxy::GetFullState ( )
This method return the full object state that can be used to create that object from scratch.
◆ LoadState()
void vtkSMProxy::LoadState ( const vtkSMMessage *  msg,
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented in vtkSMViewLayoutProxy.
◆ GetPropertyGroup()
vtkSMPropertyGroup* vtkSMProxy::GetPropertyGroup ( size_t  index) const
Returns the property group at index for the proxy.
◆ GetNumberOfPropertyGroups()
size_t vtkSMProxy::GetNumberOfPropertyGroups ( ) const
Returns the number of property groups that the proxy contains.
◆ SetLogName()
void vtkSMProxy::SetLogName ( const char *  name)
Log name is a name for this proxy that will be used when logging status messages.
This helps make the log more user friendly by making sure it uses names that the user can easily map to objects shown in the user interface.
This method will set the log name for this proxy and iterate over all subproxies and set log name for each using the provided name as prefix.
Furthermore, for all properties with vtkSMProxyListDomain, it will set log name for proxies in those domains to use the provided name as prefix as well.
Note
The use of this name for any other purpose than logging is strictly discouraged.
◆ GetLogName()
virtual char* vtkSMProxy::GetLogName ( )
Note
◆ GetLogNameOrDefault()
const char* vtkSMProxy::GetLogNameOrDefault ( )
A helper that makes up an default name if none is provided.
◆ GetPropertiesModified()
bool vtkSMProxy::GetPropertiesModified ( )
inline
Definition at line 609 of file vtkSMProxy.h.
◆ GetPropertiesWithDifferentValues()
virtual std::vector<std::string> vtkSMProxy::GetPropertiesWithDifferentValues ( vtkSMProxy *  otherProxy)
Return the property names that have values different from the otherProxy argument.
◆ ExecuteStream()
void vtkSMProxy::ExecuteStream ( const vtkClientServerStream &  msg,
bool  ignore_errors = false,
vtkTypeUInt32  location = 0
Invoke that takes a vtkClientServerStream as the argument.
◆ UpdateAndPushAnnotationState()
virtual void vtkSMProxy::UpdateAndPushAnnotationState ( )
protectedvirtual
◆ GetLastResult() [1/2]
virtual const vtkClientServerStream& vtkSMProxy::GetLastResult ( )
protectedvirtual
◆ GetLastResult() [2/2]
virtual const vtkClientServerStream& vtkSMProxy::GetLastResult ( vtkTypeUInt32  location)
protectedvirtual
◆ AddProperty()
virtual void vtkSMProxy::AddProperty ( const char *  name,
protectedvirtual
Add a property with the given key (name).
The name can then be used to retrieve the property with GetProperty(). If a property with the given name has been added before, it will be replaced. This includes properties in sub-proxies.
◆ MarkConsumersAsDirty()
virtual void vtkSMProxy::MarkConsumersAsDirty ( vtkSMProxy *  modifiedProxy)
protectedvirtual
Calls MarkDirtyFromProducer on all consumers.
◆ MarkDirtyFromProducer()
virtual void vtkSMProxy::MarkDirtyFromProducer ( vtkSMProxy *  modifiedProxy,
vtkSMProxy *  producer,
vtkSMProperty *  property
protectedvirtual
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer.
This provides the consumer with potentially useful insight about which producer the modification is coming from which can be useful e.g. vtkSMRepresentationProxy.
Default implementation simply calls this->MarkDirty(modifiedProxy).
Reimplemented in vtkSMRepresentationProxy.
◆ MarkInputsAsDirty()
void vtkSMProxy::MarkInputsAsDirty ( )
This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed.
While this does not mean that the pipeline will re-execute, it does indicate that the pipeline could execute and hence to ensure we update data information (and other state) correctly when PostUpdateData gets called, need to ensure the upstream pipeline on the proxy side realizes it may need update. This method simply toggles NeedsUpdate flag and propagate up the producer chain through input properties.
◆ SetXMLName()
virtual void vtkSMProxy::SetXMLName ( const char *  )
protectedvirtual
◆ SetXMLGroup()
virtual void vtkSMProxy::SetXMLGroup ( const char *  )
protectedvirtual
◆ SetXMLLabel()
virtual void vtkSMProxy::SetXMLLabel ( const char *  )
protectedvirtual
◆ SetXMLSubProxyName()
virtual void vtkSMProxy::SetXMLSubProxyName ( const char *  )
protectedvirtual
It is used to figure out the origin of the definition of that proxy. By default, it stay nullptr, only in-line subProxy do specify this field so when the definition is sent to the server, it can retrieve the in-line definition of that proxy.
◆ CreateVTKObjects()
virtual void vtkSMProxy::CreateVTKObjects ( )
protectedvirtual
◆ RemoveAllObservers()
void vtkSMProxy::RemoveAllObservers ( )
Cleanup code.
Remove all observers from all properties assigned to this proxy. Called before deleting properties. This also removes observers on subproxies.
◆ SetPropertyModifiedFlag()
virtual void vtkSMProxy::SetPropertyModifiedFlag ( const char *  name,
int  flag
protectedvirtual
Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself.
Here is a brief explanation of how modified flags are used:
  • 1. When a property is modified, the modified flag is set
  • 2. In UpdateVTKObjects(), the proxy visits all properties and calls AppendCommandToStream() on each modified property. It also resets the modified flag.
The reason why the modified flag is stored in the proxy instead of property is in item 2 above. If multiple proxies were sharing the same property, the first one would reset the modified flag in UpdateVTKObjects() and then others would not call AppendCommandToStream() in their turn. Therefore, each proxy has to keep track of all properties it updated. This is done by adding observers to the properties. When a property is modified, it invokes all observers and the observers set the appropriate flags in the proxies. Changes the modified flag of a property. Used by the observers
Reimplemented in vtkSMPVRepresentationProxy, vtkSMSettingsProxy, vtkSMChartRepresentationProxy, vtkSMSpreadSheetRepresentationProxy, and vtkSMEnsembleDataReaderProxy.
◆ AddSubProxy()
void vtkSMProxy::AddSubProxy ( const char *  name,
vtkSMProxy *  proxy,
int  overrideOK = 0
Add a sub-proxy.
If the overrideOK flag is set, then no warning is printed when a new subproxy replaces a preexisting one.
◆ RemoveSubProxy()
void vtkSMProxy::RemoveSubProxy ( const char *  name)
Remove a sub-proxy.
◆ GetSubProxy() [1/2]
vtkSMProxy* vtkSMProxy::GetSubProxy ( const char *  name)
Returns 0 if sub-proxy does not exist.
◆ GetSubProxy() [2/2]
vtkSMProxy* vtkSMProxy::GetSubProxy ( unsigned int  index)
◆ GetSubProxyName() [1/2]
const char* vtkSMProxy::GetSubProxyName ( unsigned int  index)
Returns the name used to store sub-proxy.
◆ GetSubProxyName() [2/2]
const char* vtkSMProxy::GetSubProxyName ( vtkSMProxy *  )
Returns 0 is the sub-proxy does not exist.
◆ GetNumberOfSubProxies()
unsigned int vtkSMProxy::GetNumberOfSubProxies ( )
Returns the number of sub-proxies.
◆ AddConsumer()
virtual void vtkSMProxy::AddConsumer ( vtkSMProperty *  property,
vtkSMProxy *  proxy
protectedvirtual
Called by a proxy property, this adds the property,proxy pair to the list of consumers.
◆ RemoveConsumer()
virtual void vtkSMProxy::RemoveConsumer ( vtkSMProperty *  property,
vtkSMProxy *  proxy
protectedvirtual
Remove the property,proxy pair from the list of consumers.
◆ RemoveAllConsumers()
virtual void vtkSMProxy::RemoveAllConsumers ( )
protectedvirtual
◆ AddProducer()
void vtkSMProxy::AddProducer ( vtkSMProperty *  property,
vtkSMProxy *  proxy
Called by an proxy/input property to add property, proxy pair to the list of producers.
◆ RemoveProducer()
void vtkSMProxy::RemoveProducer ( vtkSMProperty *  property,
vtkSMProxy *  proxy
Remove the property,proxy pair from the list of producers.
◆ PostUpdateData()
virtual void vtkSMProxy::PostUpdateData ( bool  using_cache)
protectedvirtual
This method is called after the algorithm(s) (if any) associated with this proxy execute.
Subclasses overwrite this method to add necessary functionality.
using_cache is set to true when the pipeline update was requested but skipped because the result was previously generated. This happens when using playing animations with cache enabled.
Reimplemented in vtkSMSourceProxy, and vtkSMRepresentationProxy.
◆ PostUpdateDataSelfOnly()
void vtkSMProxy::PostUpdateDataSelfOnly ( bool  using_cache)
This is called by PostUpdateData to only update state for this proxy without iterative over producers.
◆ WarnIfDeprecated()
bool vtkSMProxy::WarnIfDeprecated ( )
If a proxy is deprecated, prints a warning.
◆ LoadPluginIfEnsured()
bool vtkSMProxy::LoadPluginIfEnsured ( )
If a proxy need to ensure a plugin is loaded, make sure it is.
◆ UpdatePipelineInformation()
virtual void vtkSMProxy::UpdatePipelineInformation ( )
protectedvirtual
This method simply iterates over subproxies and calls UpdatePipelineInformation() on them.
vtkSMSourceProxy overrides this method (makes it public) and updates the pipeline information.
Reimplemented in vtkSMSourceProxy, and vtkSMImporterProxy.
◆ NewProperty() [1/2]
vtkSMProperty* vtkSMProxy::NewProperty ( const char *  name)
Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element.
◆ NewProperty() [2/2]
vtkSMProperty* vtkSMProxy::NewProperty ( const char *  name,
vtkPVXMLElement *  propElement
◆ LinkProperty()
void vtkSMProxy::LinkProperty ( vtkSMProperty *  inputProperty,
vtkSMProperty *  outputProperty
Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed.
◆ NewPropertyGroup()
vtkSMPropertyGroup* vtkSMProxy::NewPropertyGroup ( vtkPVXMLElement *  propElement)
Parses the XML to create a new property group.
This can handle <PropertyGroup/> elements defined in both regular Proxy section or when exposing properties from sub-proxies.
◆ AppendPropertyGroup()
void vtkSMProxy::AppendPropertyGroup ( vtkSMPropertyGroup *  group)
Adds a property groups.
◆ ReadXMLAttributes()
virtual int vtkSMProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
protectedvirtual
◆ SetupExposedProperties()
void vtkSMProxy::SetupExposedProperties ( const char *  subproxy_name,
Read attributes from an XML element.
◆ SetupSharedProperties()
void vtkSMProxy::SetupSharedProperties ( vtkSMProxy *  subproxy,
◆ ExposeSubProxyProperty()
void vtkSMProxy::ExposeSubProxyProperty ( const char *  subproxy_name,
const char *  property_name,
const char *  exposed_name,
int  overrideOK = 0
Expose a subproxy property from the base proxy.
The property with the name "property_name" on the subproxy with the name "subproxy_name" is exposed with the name "exposed_name". If the overrideOK flag is set, then no warning is printed when a new exposed property replaces a preexisting one.
◆ ExecuteSubProxyEvent()
virtual void vtkSMProxy::ExecuteSubProxyEvent ( vtkSMProxy *  o,
unsigned long  event,
void *  data
protectedvirtual
Handle events fired by subproxies.
◆ CreateSubProxiesAndProperties()
virtual int vtkSMProxy::CreateSubProxiesAndProperties ( vtkSMSessionProxyManager *  pm,
protectedvirtual
Reimplemented in vtkSMMultiplexerSourceProxy.
◆ UpdatePropertyInformationInternal()
virtual void vtkSMProxy::UpdatePropertyInformationInternal ( vtkSMProperty *  prop = nullptr)
protectedvirtual
Called to update the property information on the property.
It is assured that the property passed in as an argument is a self property. Both the overloads of UpdatePropertyInformation() call this method, so subclass can override this method to perform special tasks.
◆ RebuildStateForProperties()
void vtkSMProxy::RebuildStateForProperties ( )
vtkSMProxy tracks state of properties on this proxy in an internal State object.
Since it tracks all the properties by index, if there's a potential for the properties order to have changed, then this method must be called after the changes have happened so that vtkSMProxy can rebuild this->State. Currently, this is only relevant for vtkSMSelfGeneratingSourceProxy and similar that add new properties at run time.
◆ SetLogNameInternal()
virtual void vtkSMProxy::SetLogNameInternal ( const char *  name,
bool  propagate_to_subproxies,
bool  propagate_to_proxylistdomains
protectedvirtual
Internal method used by SetLogName
Reimplemented in vtkSMSourceProxy.
◆ SetSIClassName()
virtual void vtkSMProxy::SetSIClassName ( const char *  )
protectedvirtual
SIClassName identifies the classname for the helper on the server side.
◆ GetSIClassName()
virtual char* vtkSMProxy::GetSIClassName ( )
protectedvirtual
◆ ArePropertiesModified()
bool vtkSMProxy::ArePropertiesModified ( )
Indicates if any properties are modified.
◆ SetHints()
void vtkSMProxy::SetHints ( vtkPVXMLElement *  hints)
◆ SetDeprecated()
void vtkSMProxy::SetDeprecated ( vtkPVXMLElement *  deprecated)
◆ SetEnsurePluginLoaded()
void vtkSMProxy::SetEnsurePluginLoaded ( vtkPVXMLElement *  ensurePluginLoaded)
Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured.
◆ SetXMLElement()
void vtkSMProxy::SetXMLElement ( vtkPVXMLElement *  element)
◆ operator=()
void vtkSMProxy::operator= ( const vtkSMProxy &  )
protecteddelete
◆ vtkSMCameraLink
friend class vtkSMCameraLink
friend
Each of these classes use a small subset of protected methods. This should be kept as such.
Definition at line 682 of file vtkSMProxy.h.
◆ vtkSMCompoundProxy
friend class vtkSMCompoundProxy
friend
Definition at line 683 of file vtkSMProxy.h.
◆ vtkSMCompoundSourceProxy
friend class vtkSMCompoundSourceProxy
friend
Definition at line 684 of file vtkSMProxy.h.
◆ vtkSMDeserializerProtobuf
friend class vtkSMDeserializerProtobuf
friend
Definition at line 685 of file vtkSMProxy.h.
◆ vtkSMInputProperty
friend class vtkSMInputProperty
friend
Definition at line 686 of file vtkSMProxy.h.
◆ vtkSMMultiServerSourceProxy
friend class vtkSMMultiServerSourceProxy
friend
Definition at line 687 of file vtkSMProxy.h.
◆ vtkSMNamedPropertyIterator
friend class vtkSMNamedPropertyIterator
friend
Definition at line 688 of file vtkSMProxy.h.
◆ vtkSMOrderedPropertyIterator
friend class vtkSMOrderedPropertyIterator
friend
Definition at line 689 of file vtkSMProxy.h.
◆ vtkSMPreselectionPipeline
friend class vtkSMPreselectionPipeline
friend
Definition at line 690 of file vtkSMProxy.h.
◆ vtkSMProperty
friend class vtkSMProperty
friend
Definition at line 691 of file vtkSMProxy.h.
◆ vtkSMPropertyIterator
friend class vtkSMPropertyIterator
friend
Definition at line 692 of file vtkSMProxy.h.
◆ vtkSMProxyObserver
friend class vtkSMProxyObserver
friend
Definition at line 693 of file vtkSMProxy.h.
◆ vtkSMProxyProperty
friend class vtkSMProxyProperty
friend
Definition at line 694 of file vtkSMProxy.h.
◆ vtkSMProxyRegisterUndoElement
friend class vtkSMProxyRegisterUndoElement
friend
Definition at line 695 of file vtkSMProxy.h.
◆ vtkSMProxyUnRegisterUndoElement
friend class vtkSMProxyUnRegisterUndoElement
friend
Definition at line 696 of file vtkSMProxy.h.
◆ vtkSMSessionProxyManager
friend class vtkSMSessionProxyManager
friend
Definition at line 697 of file vtkSMProxy.h.
◆ vtkSMSourceProxy
friend class vtkSMSourceProxy
friend
Definition at line 698 of file vtkSMProxy.h.
◆ vtkSMStateLoader
friend class vtkSMStateLoader
friend
Definition at line 699 of file vtkSMProxy.h.
◆ vtkSMStateLocator
friend class vtkSMStateLocator
friend
Definition at line 700 of file vtkSMProxy.h.
◆ vtkSMUndoRedoStateLoader
friend class vtkSMUndoRedoStateLoader
friend
Definition at line 701 of file vtkSMProxy.h.
◆ vtkSMViewProxy
friend class vtkSMViewProxy
friend
Definition at line 702 of file vtkSMProxy.h.
◆ vtkSMProxyInfo
friend class vtkSMProxyInfo
friend
Definition at line 1032 of file vtkSMProxy.h.
◆ NeedsUpdate
bool vtkSMProxy::NeedsUpdate
Definition at line 884 of file vtkSMProxy.h.
◆ SIClassName
char* vtkSMProxy::SIClassName
Definition at line 968 of file vtkSMProxy.h.
◆ VTKClassName
char* vtkSMProxy::VTKClassName
Definition at line 972 of file vtkSMProxy.h.
◆ XMLGroup
char* vtkSMProxy::XMLGroup
Definition at line 973 of file vtkSMProxy.h.
◆ XMLName
char* vtkSMProxy::XMLName
Definition at line 974 of file vtkSMProxy.h.
◆ XMLLabel
char* vtkSMProxy::XMLLabel
Definition at line 975 of file vtkSMProxy.h.
◆ XMLSubProxyName
char* vtkSMProxy::XMLSubProxyName
Definition at line 976 of file vtkSMProxy.h.
◆ ObjectsCreated
int vtkSMProxy::ObjectsCreated
Definition at line 977 of file vtkSMProxy.h.
◆ DoNotUpdateImmediately
int vtkSMProxy::DoNotUpdateImmediately
Definition at line 978 of file vtkSMProxy.h.
◆ DoNotModifyProperty
int vtkSMProxy::DoNotModifyProperty
Definition at line 979 of file vtkSMProxy.h.
◆ InUpdateVTKObjects
int vtkSMProxy::InUpdateVTKObjects
Avoids calls to UpdateVTKObjects in UpdateVTKObjects.
UpdateVTKObjects call it self recursively until no properties are modified.
Definition at line 986 of file vtkSMProxy.h.
◆ PropertiesModified
bool vtkSMProxy::PropertiesModified
Flag used to help speed up UpdateVTKObjects and ArePropertiesModified calls.
Definition at line 992 of file vtkSMProxy.h.
◆ XMLElement
vtkPVXMLElement* vtkSMProxy::XMLElement
Definition at line 1009 of file vtkSMProxy.h.
◆ Documentation
vtkSMDocumentation* vtkSMProxy::Documentation
Definition at line 1011 of file vtkSMProxy.h.
◆ Hints
vtkPVXMLElement* vtkSMProxy::Hints = nullptr
Definition at line 1012 of file vtkSMProxy.h.
◆ Deprecated
vtkPVXMLElement* vtkSMProxy::Deprecated = nullptr
Definition at line 1013 of file vtkSMProxy.h.
◆ EnsurePluginLoaded
vtkPVXMLElement* vtkSMProxy::EnsurePluginLoaded = nullptr
Definition at line 1014 of file vtkSMProxy.h.
◆ State
vtkSMMessage* vtkSMProxy::State
Definition at line 1017 of file vtkSMProxy.h.
◆ InMarkModified
int vtkSMProxy::InMarkModified
Definition at line 1020 of file vtkSMProxy.h.
◆ ParentProxy
vtkWeakPointer<vtkSMProxy> vtkSMProxy::ParentProxy
Definition at line 1022 of file vtkSMProxy.h.
◆ Internals
vtkSMProxyInternals* vtkSMProxy::Internals
Definition at line 1024 of file vtkSMProxy.h.
◆ SubProxyObserver
vtkSMProxyObserver* vtkSMProxy::SubProxyObserver
Definition at line 1025 of file vtkSMProxy.h.
