vtkSMPVRepresentationProxy Class Reference
representation for "Render View" like views in ParaView. More...
#include <vtkSMPVRepresentationProxy.h>
Inheritance diagram for vtkSMPVRepresentationProxy:
Collaboration diagram for vtkSMPVRepresentationProxy:
typedef vtkSMRepresentationProxy Superclass
- Public Types inherited from vtkSMRepresentationProxy
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
bool SetRepresentationType (const char *type) override
 Overridden to ensure when picking representation types that require scalar colors, scalar coloring it setup properly. More...
bool GetVolumeIndependentRanges ()
 True if ranges have to be computed independently on component 0 for the color and 1 for the opacity on the Volume representation. More...
void ViewUpdated (vtkSMProxy *view) override
 Called after the view updates. More...
void SetLastLUTProxy (vtkSMProxy *proxy)
 Set/get last LUT proxy. More...
void SetLastLookupTable (vtkSMProxy *proxy)
vtkSMProxy * GetLastLUTProxy ()
vtkSMProxy * GetLastLookupTable ()
void SetLastBlockLookupTable (const std::string &blockSelector, vtkSMProxy *proxy)
void SetLastBlocksLookupTable (const std::vector< std::string > &blockSelectors, vtkSMProxy *proxy)
vtkSMProxy * GetLastBlockLookupTable (const std::string &blockSelector)
std::vector< vtkSMProxy * > GetLastBlocksLookupTables (const std::vector< std::string > &blockSelectors)
virtual bool GetUsingScalarColoring ()
 Returns true if scalar coloring is enabled. More...
virtual bool GetBlockUsingScalarColoring (const std::string &blockSelector)
virtual std::vector< vtkTypeBool > GetBlocksUsingScalarColoring (const std::vector< std::string > &blockSelectors)
virtual bool GetAnyBlockUsingScalarColoring ()
vtkSMProxy * GetLUTProxy (vtkSMProxy *view)
 Returns the lut proxy of this representation in the given view. More...
vtkSMProxy * GetLookupTable (vtkSMProxy *view)
vtkSMProxy * GetBlockLookupTable (vtkSMProxy *view, const std::string &blockSelector)
std::vector< vtkSMProxy * > GetBlocksLookupTables (vtkSMProxy *view, const std::vector< std::string > &blockSelectors)
bool UpdateScalarBarRange (vtkSMProxy *view, bool deleteRange)
 Updates the ranges shown in the scalar bar. More...
std::vector< vtkTypeBool > UpdateBlocksScalarBarRange (vtkSMProxy *view, bool deleteRange)
virtual bool SetScalarColoring (const char *arrayName, int attributeType)
 Enable/disable scalar coloring using the specified array. More...
virtual bool SetBlockScalarColoring (const std::string &blockSelector, const char *arrayName, int attributeType)
virtual std::vector< vtkTypeBool > SetBlocksScalarColoring (const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType)
virtual bool SetScalarColoring (const char *arrayName, int attributeType, int component)
virtual bool SetBlockScalarColoring (const std::string &blockSelector, const char *arrayName, int attributeType, int component)
virtual std::vector< vtkTypeBool > SetBlocksScalarColoring (const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, int component)
virtual bool RescaleTransferFunctionToDataRange (bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range. More...
virtual bool RescaleBlockTransferFunctionToDataRange (const std::string &blockSelector, bool extend=false, bool force=true)
virtual std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRange (const std::vector< std::string > &blockSelectors, bool extend=false, bool force=true)
virtual bool RescaleTransferFunctionToDataRange (const char *arrayName, int attributeType, bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range for the chosen data-array. More...
virtual bool RescaleBlockTransferFunctionToDataRange (const std::string &blockSelector, const char *arrayName, int attributeType, bool extend=false, bool force=true)
virtual std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRange (const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, bool extend=false, bool force=true)
virtual bool RescaleTransferFunctionToDataRangeOverTime ()
 Rescales the color transfer function and opacity transfer function using the current data range over time. More...
virtual bool RescaleBlockTransferFunctionToDataRangeOverTime (const std::string &blockSelector)
virtual std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRangeOverTime (const std::vector< std::string > &blockSelectors)
virtual bool RescaleTransferFunctionToDataRangeOverTime (const char *arrayName, int attributeType)
 Rescales the color transfer function and opacity transfer function using the current data range over time for the chosen data-array. More...
virtual bool RescaleBlockTransferFunctionToDataRangeOverTime (const std::string &blockSelector, const char *arrayName, int attributeType)
virtual std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRangeOverTime (const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType)
virtual bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *view)
 Rescales the color transfer function and the opacity transfer function using the current data range, limited to the currernt visible elements. More...
virtual bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *view, const char *arrayName, int attributeType)
virtual bool SetScalarBarVisibility (vtkSMProxy *view, bool visible)
 Set the scalar bar visibility. More...
virtual bool SetBlockScalarBarVisibility (vtkSMProxy *view, const std::string &blockSelector, bool visible)
virtual std::vector< vtkTypeBool > SetBlocksScalarBarVisibility (vtkSMProxy *view, const std::vector< std::string > &blockSelectors, bool visible)
virtual bool HideScalarBarIfNotNeeded (vtkSMProxy *view)
 While SetScalarBarVisibility can be used to hide a scalar bar, it will always simply hide the scalar bar even if its being used by some other representation. More...
virtual bool HideBlocksScalarBarIfNotNeeded (vtkSMProxy *view)
virtual bool IsScalarBarVisible (vtkSMProxy *view)
 Check scalar bar visibility. More...
virtual bool IsBlockScalarBarVisible (vtkSMProxy *view, const std::string &blockSelector)
virtual std::vector< vtkTypeBool > IsBlocksScalarBarVisible (vtkSMProxy *view, const std::vector< std::string > &blockSelectors)
virtual vtkPVArrayInformation * GetArrayInformationForColorArray (bool checkRepresentedData=true)
 Returns the array information for the data array used for scalar coloring, from input data. More...
virtual vtkPVArrayInformation * GetBlockArrayInformationForColorArray (const std::string &blockSelector)
virtual std::vector< vtkPVArrayInformation * > GetBlocksArrayInformationForColorArray (const std::vector< std::string > &blockSelectors)
virtual vtkPVProminentValuesInformation * GetProminentValuesInformationForColorArray (double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Call vtkSMRepresentationProxy::GetProminentValuesInformation() for the array used for scalar color, if any. More...
virtual vtkPVProminentValuesInformation * GetBlockProminentValuesInformationForColorArray (const std::string &blockSelector, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
virtual std::vector< vtkPVProminentValuesInformation * > GetBlocksProminentValuesInformationForColorArray (const std::vector< std::string > &blockSelectors, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
int GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *view)
 Get an estimated number of annotation shown on this representation scalar bar. More...
int GetBlockEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *view, const std::string &blockSelector)
std::vector< int > GetBlocksEstimatedNumberOfAnnotationsOnScalarBars (vtkSMProxy *view, const std::vector< std::string > &blockSelectors)
int IsScalarBarStickyVisible (vtkSMProxy *view)
 Checks if the scalar bar of this representation in view is sticky visible, i.e. More...
int IsBlockScalarBarStickyVisible (vtkSMProxy *view, const std::string &blockSelector)
std::vector< int > IsBlocksScalarBarStickyVisible (vtkSMProxy *view, const std::vector< std::string > &blockSelectors)
std::pair< int, std::string > GetBlockColorArray (const std::string &blockSelector)
 Set/Get the block color array name. More...
std::vector< std::pair< int, std::string > > GetBlocksColorArrays (const std::vector< std::string > &blockSelectors)
int GetBlockColorArrayAssociation (const std::string &blockSelector)
std::string GetBlockColorArrayName (const std::string &blockSelector)
void SetBlockUseSeparateColorMap (const std::string &blockSelector, bool use)
 Set/Get if we should use a separate color map for this block. More...
void SetBlocksUseSeparateColorMap (const std::vector< std::string > &blockSelectors, bool use)
bool GetBlockUseSeparateColorMap (const std::string &blockSelector)
std::vector< vtkTypeBool > GetBlocksUseSeparateColorMaps (const std::vector< std::string > &blockSelectors)
- Public Member Functions inherited from vtkSMRepresentationProxy
virtual vtkPVDataInformation * GetRepresentedDataInformation ()
 Returns information about the data that is finally rendered by this representation. More...
void UpdatePipeline () override
 Calls Update() on all sources. More...
void UpdatePipeline (double time) override
 Calls Update() on all sources with the given time request. More...
void PostUpdateData (bool) override
 Overridden to reset this->MarkedModified flag. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by internal composite representation. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
virtual vtkPVProminentValuesInformation * GetProminentValuesInformation (std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Returns information about a specific array component's prominent values (or nullptr). More...
virtual vtkPVProminentValuesInformation * GetBlockProminentValuesInformation (std::string blockSelector, std::string assemblyName, std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
const char * GetRepresentationType ()
 Set the representation type. More...
bool IsVolumeRendering ()
 Convenient method to check if this representation is currently rendering volumes, using 2D Transfer function. More...
bool GetUsing2DTransferFunction ()
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMPVRepresentationProxy * New ()
static vtkSMPVRepresentationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMRepresentationProxy
static vtkSMRepresentationProxy * New ()
static vtkSMRepresentationProxy * SafeDownCast (vtkObject *o)
static bool SetRepresentationType (vtkSMProxy *repr, const char *type)
static const char * GetRepresentationType (vtkSMProxy *repr)
static bool IsVolumeRendering (vtkSMProxy *repr)
static bool GetUsing2DTransferFunction (vtkSMProxy *repr)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMPVRepresentationProxy ()
 ~vtkSMPVRepresentationProxy () override
 Overridden to ensure that the RepresentationTypesInfo and Representations's domain are up-to-date. More...
void OnPropertyUpdated (vtkObject *, unsigned long, void *calldata)
void SetPropertyModifiedFlag (const char *name, int flag) override
 Overridden to ensure that whenever "Input" property changes, we update the "Input" properties for all internal representations (including setting up of the link to the extract-selection representation). More...
 Overridden to process "RepresentationType" elements. More...
- Protected Member Functions inherited from vtkSMRepresentationProxy
 vtkSMRepresentationProxy ()
 ~vtkSMRepresentationProxy () override
void MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) override
 When the representation is being marked dirty due to a producer i.e. More...
void AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveAllConsumers () override
 Remove all consumers. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
void OnVTKRepresentationUpdated ()
void OnVTKRepresentationUpdateSkipped ()
void OnVTKRepresentationUpdateTimeChanged ()
virtual void UpdatePipelineInternal (double time, bool doTime)
void InvalidateDataInformation () override
 Mark the data information as invalid. More...
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
 Overridden to restore this->Servers flag state. More...
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void SetExecutiveName (const char *)
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSmartPointer< vtkSMProxy > LastLookupTable
 Used as a memory of what was the last LUT proxy linked to this representation. More...
std::unordered_map< std::string, vtkSmartPointer< vtkSMProxy > > LastBlocksLookupTables
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMPVRepresentationProxy combines surface representation and volume representation proxies typically used for displaying data. This class also takes over the selection obligations for all the internal representations, i.e. is disables showing of selection in all the internal representations, and manages it. This avoids duplicate execution of extract selection filter for each of the internal representations.
vtkSMPVRepresentationProxy is used for pretty much all of the data-representations (i.e. representations showing input data) in the render views. It provides helper functions redirecting to vtkSMColorMapEditorHelper for controlling transfer functions, scalar coloring, etc.
See also
Definition at line 35 of file vtkSMPVRepresentationProxy.h.
Definition at line 39 of file vtkSMPVRepresentationProxy.h.
◆ vtkSMPVRepresentationProxy()
vtkSMPVRepresentationProxy::vtkSMPVRepresentationProxy ( )
◆ ~vtkSMPVRepresentationProxy()
vtkSMPVRepresentationProxy::~vtkSMPVRepresentationProxy ( )
static vtkSMPVRepresentationProxy* vtkSMPVRepresentationProxy::New ( )
virtual const char* vtkSMPVRepresentationProxy::GetClassName ( )
Reimplemented from vtkSMRepresentationProxy.
Reimplemented in vtkSMPVMoleculeRepresentationProxy.
static int vtkSMPVRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMPVRepresentationProxy::IsA ( const char *  type)
static vtkSMPVRepresentationProxy* vtkSMPVRepresentationProxy::SafeDownCast ( vtkObject *  o)
void vtkSMPVRepresentationProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSMSourceProxy.
◆ SetLastLUTProxy()
void vtkSMPVRepresentationProxy::SetLastLUTProxy ( vtkSMProxy *  proxy)
inline
Definition at line 48 of file vtkSMPVRepresentationProxy.h.
◆ SetLastLookupTable()
void vtkSMPVRepresentationProxy::SetLastLookupTable ( vtkSMProxy *  proxy)
◆ GetLastLUTProxy()
vtkSMProxy* vtkSMPVRepresentationProxy::GetLastLUTProxy ( )
inline
Definition at line 51 of file vtkSMPVRepresentationProxy.h.
◆ GetLastLookupTable()
vtkSMProxy* vtkSMPVRepresentationProxy::GetLastLookupTable ( )
◆ SetLastBlockLookupTable()
void vtkSMPVRepresentationProxy::SetLastBlockLookupTable ( const std::string &  blockSelector,
vtkSMProxy *  proxy
inline
Definition at line 53 of file vtkSMPVRepresentationProxy.h.
◆ SetLastBlocksLookupTable()
void vtkSMPVRepresentationProxy::SetLastBlocksLookupTable ( const std::vector< std::string > &  blockSelectors,
vtkSMProxy *  proxy
◆ GetLastBlockLookupTable()
vtkSMProxy* vtkSMPVRepresentationProxy::GetLastBlockLookupTable ( const std::string &  blockSelector)
inline
Definition at line 58 of file vtkSMPVRepresentationProxy.h.
◆ GetLastBlocksLookupTables()
std::vector<vtkSMProxy*> vtkSMPVRepresentationProxy::GetLastBlocksLookupTables ( const std::vector< std::string > &  blockSelectors)
◆ GetUsingScalarColoring()
virtual bool vtkSMPVRepresentationProxy::GetUsingScalarColoring ( )
This checks whether a property named "ColorArrayName" exists and has a non-empty string. This does not check for the validity of the array.
◆ GetBlockUsingScalarColoring()
virtual bool vtkSMPVRepresentationProxy::GetBlockUsingScalarColoring ( const std::string &  blockSelector)
inlinevirtual
Definition at line 73 of file vtkSMPVRepresentationProxy.h.
◆ GetBlocksUsingScalarColoring()
virtual std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::GetBlocksUsingScalarColoring ( const std::vector< std::string > &  blockSelectors)
◆ GetAnyBlockUsingScalarColoring()
virtual bool vtkSMPVRepresentationProxy::GetAnyBlockUsingScalarColoring ( )
◆ GetLUTProxy()
vtkSMProxy* vtkSMPVRepresentationProxy::GetLUTProxy ( vtkSMProxy *  view)
inline
This method will return nullptr if no lut proxy exists in this view.
Definition at line 88 of file vtkSMPVRepresentationProxy.h.
◆ GetLookupTable()
vtkSMProxy* vtkSMPVRepresentationProxy::GetLookupTable ( vtkSMProxy *  view)
◆ GetBlockLookupTable()
vtkSMProxy* vtkSMPVRepresentationProxy::GetBlockLookupTable ( vtkSMProxy *  view,
inline
Definition at line 90 of file vtkSMPVRepresentationProxy.h.
◆ GetBlocksLookupTables()
std::vector<vtkSMProxy*> vtkSMPVRepresentationProxy::GetBlocksLookupTables ( vtkSMProxy *  view,
◆ UpdateScalarBarRange()
bool vtkSMPVRepresentationProxy::UpdateScalarBarRange ( vtkSMProxy *  view,
bool  deleteRange
If deleteRange is true, then the range stored for current representation proxy is deleted. This should be done when the scalar bar gets separated or becomes not visible. If deleteRange is false, then the range stored for current representation proxy is updated with the new range value.
◆ UpdateBlocksScalarBarRange()
std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::UpdateBlocksScalarBarRange ( vtkSMProxy *  view,
bool  deleteRange
◆ SetScalarColoring() [1/2]
virtual bool vtkSMPVRepresentationProxy::SetScalarColoring ( const char *  arrayName,
int  attributeType
This will set up a color and opacity transfer functions using vtkSMTransferFunctionProxy instance. If arrayName is nullptr, then scalar coloring is turned off. attributeType must be one of vtkDataObject::AttributeTypes.
◆ SetBlockScalarColoring() [1/2]
virtual bool vtkSMPVRepresentationProxy::SetBlockScalarColoring ( const std::string &  blockSelector,
int  attributeType
inlinevirtual
Definition at line 118 of file vtkSMPVRepresentationProxy.h.
◆ SetBlocksScalarColoring() [1/2]
virtual std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::SetBlocksScalarColoring ( const std::vector< std::string > &  blockSelectors,
int  attributeType
◆ SetScalarColoring() [2/2]
int  attributeType,
int  component
This will set up a color and opacity transfer functions using vtkSMTransferFunctionProxy instance. If arrayName is nullptr, then scalar coloring is turned off. if component name is -1, then the magnitude of the array is used. If component name is >=0, then the corresponding component is used.
◆ SetBlockScalarColoring() [2/2]
int  attributeType,
int  component
inlinevirtual
Definition at line 136 of file vtkSMPVRepresentationProxy.h.
◆ SetBlocksScalarColoring() [2/2]
int  attributeType,
int  component
◆ RescaleTransferFunctionToDataRange() [1/2]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRange ( bool  extend = false,
bool  force = true
Returns true if rescale was successful. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range. If force is false (true by default), then the transfer function range is not changed if locked.
blockSelector the block selector. extend Extend existing range instead of clamping to the new range (default: false). force Update transfer function even if the range is locked (default: true).
◆ RescaleBlockTransferFunctionToDataRange() [1/2]
virtual bool vtkSMPVRepresentationProxy::RescaleBlockTransferFunctionToDataRange ( const std::string &  blockSelector,
bool  force = true
inlinevirtual
Definition at line 163 of file vtkSMPVRepresentationProxy.h.
◆ RescaleBlocksTransferFunctionToDataRange() [1/2]
virtual std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::RescaleBlocksTransferFunctionToDataRange ( const std::vector< std::string > &  blockSelectors,
bool  force = true
◆ RescaleTransferFunctionToDataRange() [2/2]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRange ( const char *  arrayName,
int  attributeType,
bool  force = true
blockSelector the block selector. arrayName the name of the array. attributeType must be one of vtkDataObject::AttributeTypes. extend Extend existing range instead of clamping to the new range (default: false). force Update transfer function even if the range is locked (default: true).
◆ RescaleBlockTransferFunctionToDataRange() [2/2]
int  attributeType,
bool  force = true
inlinevirtual
Definition at line 192 of file vtkSMPVRepresentationProxy.h.
◆ RescaleBlocksTransferFunctionToDataRange() [2/2]
int  attributeType,
bool  force = true
◆ RescaleTransferFunctionToDataRangeOverTime() [1/2]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRangeOverTime ( )
◆ RescaleBlockTransferFunctionToDataRangeOverTime() [1/2]
virtual bool vtkSMPVRepresentationProxy::RescaleBlockTransferFunctionToDataRangeOverTime ( const std::string &  blockSelector)
inlinevirtual
Definition at line 211 of file vtkSMPVRepresentationProxy.h.
◆ RescaleBlocksTransferFunctionToDataRangeOverTime() [1/2]
virtual std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::RescaleBlocksTransferFunctionToDataRangeOverTime ( const std::vector< std::string > &  blockSelectors)
◆ RescaleTransferFunctionToDataRangeOverTime() [2/2]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRangeOverTime ( const char *  arrayName,
int  attributeType
Returns true if rescale was successful. field_association must be one of vtkDataObject::AttributeTypes,
◆ RescaleBlockTransferFunctionToDataRangeOverTime() [2/2]
virtual bool vtkSMPVRepresentationProxy::RescaleBlockTransferFunctionToDataRangeOverTime ( const std::string &  blockSelector,
int  attributeType
inlinevirtual
Definition at line 227 of file vtkSMPVRepresentationProxy.h.
◆ RescaleBlocksTransferFunctionToDataRangeOverTime() [2/2]
virtual std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::RescaleBlocksTransferFunctionToDataRangeOverTime ( const std::vector< std::string > &  blockSelectors,
int  attributeType
◆ RescaleTransferFunctionToVisibleRange() [1/2]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToVisibleRange ( vtkSMProxy *  view)
◆ RescaleTransferFunctionToVisibleRange() [2/2]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToVisibleRange ( vtkSMProxy *  view,
int  attributeType
◆ SetScalarBarVisibility()
virtual bool vtkSMPVRepresentationProxy::SetScalarBarVisibility ( vtkSMProxy *  view,
bool  visible
This will create a new scalar bar as needed. Scalar bar is only shown if scalar coloring is indeed being used.
◆ SetBlockScalarBarVisibility()
virtual bool vtkSMPVRepresentationProxy::SetBlockScalarBarVisibility ( vtkSMProxy *  view,
bool  visible
inlinevirtual
Definition at line 255 of file vtkSMPVRepresentationProxy.h.
◆ SetBlocksScalarBarVisibility()
virtual std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::SetBlocksScalarBarVisibility ( vtkSMProxy *  view,
bool  visible
◆ HideScalarBarIfNotNeeded()
virtual bool vtkSMPVRepresentationProxy::HideScalarBarIfNotNeeded ( vtkSMProxy *  view)
Use this method instead to only hide the scalar/color bar if no other visible representation in the view is mapping data using the scalar bar.
◆ HideBlocksScalarBarIfNotNeeded()
virtual bool vtkSMPVRepresentationProxy::HideBlocksScalarBarIfNotNeeded ( vtkSMProxy *  view)
◆ IsScalarBarVisible()
virtual bool vtkSMPVRepresentationProxy::IsScalarBarVisible ( vtkSMProxy *  view)
Return true if the scalar bar for this representation and view is visible, return false otherwise.
◆ IsBlockScalarBarVisible()
virtual bool vtkSMPVRepresentationProxy::IsBlockScalarBarVisible ( vtkSMProxy *  view,
inlinevirtual
Definition at line 282 of file vtkSMPVRepresentationProxy.h.
◆ IsBlocksScalarBarVisible()
virtual std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::IsBlocksScalarBarVisible ( vtkSMProxy *  view,
◆ GetArrayInformationForColorArray()
virtual vtkPVArrayInformation* vtkSMPVRepresentationProxy::GetArrayInformationForColorArray ( bool  checkRepresentedData = true)
If checkRepresentedData is true, it will also check in the represented data. Default is true. If none is found, returns nullptr.
◆ GetBlockArrayInformationForColorArray()
virtual vtkPVArrayInformation* vtkSMPVRepresentationProxy::GetBlockArrayInformationForColorArray ( const std::string &  blockSelector)
inlinevirtual
Definition at line 297 of file vtkSMPVRepresentationProxy.h.
◆ GetBlocksArrayInformationForColorArray()
virtual std::vector<vtkPVArrayInformation*> vtkSMPVRepresentationProxy::GetBlocksArrayInformationForColorArray ( const std::vector< std::string > &  blockSelectors)
◆ GetProminentValuesInformationForColorArray()
virtual vtkPVProminentValuesInformation* vtkSMPVRepresentationProxy::GetProminentValuesInformationForColorArray ( double  uncertaintyAllowed = 1e-6,
double  fraction = 1e-3,
bool  force = false
Otherwise returns nullptr.
◆ GetBlockProminentValuesInformationForColorArray()
virtual vtkPVProminentValuesInformation* vtkSMPVRepresentationProxy::GetBlockProminentValuesInformationForColorArray ( const std::string &  blockSelector,
bool  force = false
inlinevirtual
Definition at line 313 of file vtkSMPVRepresentationProxy.h.
◆ GetBlocksProminentValuesInformationForColorArray()
virtual std::vector<vtkPVProminentValuesInformation*> vtkSMPVRepresentationProxy::GetBlocksProminentValuesInformationForColorArray ( const std::vector< std::string > &  blockSelectors,
bool  force = false
◆ GetEstimatedNumberOfAnnotationsOnScalarBar()
int vtkSMPVRepresentationProxy::GetEstimatedNumberOfAnnotationsOnScalarBar ( vtkSMProxy *  view)
◆ GetBlockEstimatedNumberOfAnnotationsOnScalarBar()
int vtkSMPVRepresentationProxy::GetBlockEstimatedNumberOfAnnotationsOnScalarBar ( vtkSMProxy *  view,
inline
Definition at line 332 of file vtkSMPVRepresentationProxy.h.
◆ GetBlocksEstimatedNumberOfAnnotationsOnScalarBars()
std::vector<int> vtkSMPVRepresentationProxy::GetBlocksEstimatedNumberOfAnnotationsOnScalarBars ( vtkSMProxy *  view,
◆ SetRepresentationType()
bool vtkSMPVRepresentationProxy::SetRepresentationType ( const char *  type)
Currently this is hard-coded for Volume and Slice representation types.
◆ GetVolumeIndependentRanges()
bool vtkSMPVRepresentationProxy::GetVolumeIndependentRanges ( )
◆ IsScalarBarStickyVisible()
int vtkSMPVRepresentationProxy::IsScalarBarStickyVisible ( vtkSMProxy *  view)
should be visible whenever this representation is also visible. It returns 1 if the scalar bar is sticky visible, 0 other wise. If any problem is encountered, for example if view == nullptr, or if the scalar bar representation is not instanciated / found, it returns -1.
◆ IsBlockScalarBarStickyVisible()
int vtkSMPVRepresentationProxy::IsBlockScalarBarStickyVisible ( vtkSMProxy *  view,
inline
Definition at line 365 of file vtkSMPVRepresentationProxy.h.
◆ IsBlocksScalarBarStickyVisible()
std::vector<int> vtkSMPVRepresentationProxy::IsBlocksScalarBarStickyVisible ( vtkSMProxy *  view,
◆ ViewUpdated()
void vtkSMPVRepresentationProxy::ViewUpdated ( vtkSMProxy *  view)
◆ GetBlockColorArray()
std::pair<int, std::string> vtkSMPVRepresentationProxy::GetBlockColorArray ( const std::string &  blockSelector)
inline
Definition at line 382 of file vtkSMPVRepresentationProxy.h.
◆ GetBlocksColorArrays()
std::vector<std::pair<int, std::string> > vtkSMPVRepresentationProxy::GetBlocksColorArrays ( const std::vector< std::string > &  blockSelectors)
◆ GetBlockColorArrayAssociation()
int vtkSMPVRepresentationProxy::GetBlockColorArrayAssociation ( const std::string &  blockSelector)
inline
Definition at line 388 of file vtkSMPVRepresentationProxy.h.
◆ GetBlockColorArrayName()
std::string vtkSMPVRepresentationProxy::GetBlockColorArrayName ( const std::string &  blockSelector)
inline
Definition at line 392 of file vtkSMPVRepresentationProxy.h.
◆ SetBlockUseSeparateColorMap()
void vtkSMPVRepresentationProxy::SetBlockUseSeparateColorMap ( const std::string &  blockSelector,
bool  use
inline
Definition at line 402 of file vtkSMPVRepresentationProxy.h.
◆ SetBlocksUseSeparateColorMap()
void vtkSMPVRepresentationProxy::SetBlocksUseSeparateColorMap ( const std::vector< std::string > &  blockSelectors,
bool  use
◆ GetBlockUseSeparateColorMap()
bool vtkSMPVRepresentationProxy::GetBlockUseSeparateColorMap ( const std::string &  blockSelector)
inline
Definition at line 407 of file vtkSMPVRepresentationProxy.h.
◆ GetBlocksUseSeparateColorMaps()
std::vector<vtkTypeBool> vtkSMPVRepresentationProxy::GetBlocksUseSeparateColorMaps ( const std::vector< std::string > &  blockSelectors)
◆ CreateVTKObjects()
void vtkSMPVRepresentationProxy::CreateVTKObjects ( )
overrideprotectedvirtual
◆ OnPropertyUpdated()
void vtkSMPVRepresentationProxy::OnPropertyUpdated ( vtkObject *  ,
unsigned  long,
void *  calldata
◆ SetPropertyModifiedFlag()
void vtkSMPVRepresentationProxy::SetPropertyModifiedFlag ( const char *  name,
int  flag
◆ ReadXMLAttributes()
int vtkSMPVRepresentationProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
◆ LastLookupTable
vtkSmartPointer<vtkSMProxy> vtkSMPVRepresentationProxy::LastLookupTable
This is used in UpdateScalarBarRange to update the scalar bar range when turning off the coloring for this representation.
Definition at line 446 of file vtkSMPVRepresentationProxy.h.
◆ LastBlocksLookupTables
std::unordered_map<std::string, vtkSmartPointer<vtkSMProxy> > vtkSMPVRepresentationProxy::LastBlocksLookupTables
Definition at line 447 of file vtkSMPVRepresentationProxy.h.
