vtkSMVRGrabTransformStyleProxy Class Reference
#include <vtkSMVRGrabTransformStyleProxy.h>
Inheritance diagram for vtkSMVRGrabTransformStyleProxy:
Collaboration diagram for vtkSMVRGrabTransformStyleProxy:
typedef vtkSMVRTrackStyleProxy Superclass
- Public Types inherited from vtkSMVRTrackStyleProxy
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 }
typedef vtkSMProxy Superclass
- Public Member Functions inherited from vtkSMVRTrackStyleProxy
int GetControlledPropertySize () override
virtual vtkSMProxy * GetControlledProxy ()
virtual bool Update ()
int GetNumberOfButtonRoles ()
std::string GetValuatorRole (const std::string &name)
void ClearAllRoles ()
virtual vtkPVXMLElement * SaveConfiguration ()
 Save state to xml. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRGrabTransformStyleProxy * New ()
static vtkSMVRGrabTransformStyleProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMVRTrackStyleProxy
static vtkSMVRTrackStyleProxy * New ()
static vtkSMVRTrackStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMVRGrabTransformStyleProxy ()
 ~vtkSMVRGrabTransformStyleProxy () override
void HandleButton (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
- Protected Member Functions inherited from vtkSMVRTrackStyleProxy
 vtkSMVRTrackStyleProxy ()
 ~vtkSMVRTrackStyleProxy () override
virtual void HandleValuator (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool EnableNavigate
bool IsInitialRecorded
vtkNew< vtkMatrix4x4 > SavedModelViewMatrix
vtkNew< vtkMatrix4x4 > SavedInverseWandMatrix
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
- Protected Types inherited from vtkSMVRInteractorStyleProxy
typedef std::map< std::string, std::string > StringMap
static std::vector< std::string > Tokenize (std::string input)
Definition at line 18 of file vtkSMVRGrabTransformStyleProxy.h.
Definition at line 23 of file vtkSMVRGrabTransformStyleProxy.h.
◆ vtkSMVRGrabTransformStyleProxy()
vtkSMVRGrabTransformStyleProxy::vtkSMVRGrabTransformStyleProxy ( )
◆ ~vtkSMVRGrabTransformStyleProxy()
vtkSMVRGrabTransformStyleProxy::~vtkSMVRGrabTransformStyleProxy ( )
static vtkSMVRGrabTransformStyleProxy* vtkSMVRGrabTransformStyleProxy::New ( )
virtual const char* vtkSMVRGrabTransformStyleProxy::GetClassName ( )
Reimplemented from vtkSMVRTrackStyleProxy.
static int vtkSMVRGrabTransformStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRGrabTransformStyleProxy::IsA ( const char *  type)
static vtkSMVRGrabTransformStyleProxy* vtkSMVRGrabTransformStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRGrabTransformStyleProxy::PrintSelf ( ostream &  os,
◆ HandleButton()
void vtkSMVRGrabTransformStyleProxy::HandleButton ( const vtkVREvent &  event)
overrideprotectedvirtual
◆ HandleTracker()
void vtkSMVRGrabTransformStyleProxy::HandleTracker ( const vtkVREvent &  event)
◆ EnableNavigate
bool vtkSMVRGrabTransformStyleProxy::EnableNavigate
Definition at line 33 of file vtkSMVRGrabTransformStyleProxy.h.
◆ IsInitialRecorded
bool vtkSMVRGrabTransformStyleProxy::IsInitialRecorded
Definition at line 34 of file vtkSMVRGrabTransformStyleProxy.h.
◆ SavedModelViewMatrix
vtkNew<vtkMatrix4x4> vtkSMVRGrabTransformStyleProxy::SavedModelViewMatrix
Definition at line 36 of file vtkSMVRGrabTransformStyleProxy.h.
◆ SavedInverseWandMatrix
vtkNew<vtkMatrix4x4> vtkSMVRGrabTransformStyleProxy::SavedInverseWandMatrix
Definition at line 37 of file vtkSMVRGrabTransformStyleProxy.h.
