vtkSMPluginLoaderProxy Class Reference
used to load a plugin remotely. More...
#include <vtkSMPluginLoaderProxy.h>
Inheritance diagram for vtkSMPluginLoaderProxy:
Collaboration diagram for vtkSMPluginLoaderProxy:
typedef vtkSMProxy Superclass
bool LoadPlugin (const char *filename)
 Loads the plugin. More...
bool LoadPluginByName (const char *name, bool acceptDelayed=true)
 Loads the plugin based on its name. More...
void LoadPluginConfigurationXMLFromString (const char *xmlcontents)
 Loads the configuration xml contents. More...
void LoadPluginConfigurationXML (const char *configurationFile)
 Loads a configuration xml file. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMPluginLoaderProxy * New ()
static vtkSMPluginLoaderProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMPluginLoaderProxy ()
 ~vtkSMPluginLoaderProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMPluginLoaderProxy is used to load a plugin on dataserver and renderserver processes. Simply call vtkSMPluginLoaderProxy::LoadPlugin() with the right path to load the plugin remotely.
Definition at line 18 of file vtkSMPluginLoaderProxy.h.
Definition at line 22 of file vtkSMPluginLoaderProxy.h.
◆ vtkSMPluginLoaderProxy()
vtkSMPluginLoaderProxy::vtkSMPluginLoaderProxy ( )
◆ ~vtkSMPluginLoaderProxy()
vtkSMPluginLoaderProxy::~vtkSMPluginLoaderProxy ( )
static vtkSMPluginLoaderProxy* vtkSMPluginLoaderProxy::New ( )
virtual const char* vtkSMPluginLoaderProxy::GetClassName ( )
static int vtkSMPluginLoaderProxy::IsTypeOf ( const char *  type)
virtual int vtkSMPluginLoaderProxy::IsA ( const char *  type)
static vtkSMPluginLoaderProxy* vtkSMPluginLoaderProxy::SafeDownCast ( vtkObject *  o)
void vtkSMPluginLoaderProxy::PrintSelf ( ostream &  os,
◆ LoadPlugin()
bool vtkSMPluginLoaderProxy::LoadPlugin ( const char *  filename)
Loads the plugin.
Returns true on success else false. To get the error string, call UpdatePropertyInformation() on this proxy and then look at the ErrorString property.
◆ LoadPluginByName()
bool vtkSMPluginLoaderProxy::LoadPluginByName ( const char *  name,
bool  acceptDelayed = true
◆ LoadPluginConfigurationXMLFromString()
void vtkSMPluginLoaderProxy::LoadPluginConfigurationXMLFromString ( const char *  xmlcontents)
Look at vtkPVPluginTracker::LoadPluginConfigurationXMLFromString() to see the details about the configuration xml.
◆ LoadPluginConfigurationXML()
void vtkSMPluginLoaderProxy::LoadPluginConfigurationXML ( const char *  configurationFile)
Look at vtkPVPluginTracker::LoadPluginConfigurationXML() to see the details about the configuration xml.
