Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkSMSaveAnimationProxy Class Reference
proxy to save animation to images/video. More...
#include <vtkSMSaveAnimationProxy.h>
Inheritance diagram for vtkSMSaveAnimationProxy:
Collaboration diagram for vtkSMSaveAnimationProxy:
typedef vtkSMSaveScreenshotProxy Superclass
- Public Types inherited from vtkSMSaveScreenshotProxy
typedef vtkSMProxy Superclass
virtual bool WriteAnimation (const char *filename, vtkTypeUInt32 location=vtkPVSession::CLIENT)
 Save animation as images/video. More...
void UpdateDefaultsAndVisibilities (const char *filename) override
 Overridden to update visibility state of "FrameRate" property. More...
- Public Member Functions inherited from vtkSMSaveScreenshotProxy
bool WriteImage (const char *filename, vtkTypeUInt32 location=vtkPVSession::CLIENT, vtkPVXMLElement *stateXMLRoot=nullptr)
 Capture image. More...
vtkSmartPointer< vtkImageData > CaptureImage ()
 Capture the rendered image but doesn't save it out to any file. More...
std::string GetFileFormatFilters ()
 Convenience method to derive a QFileDialog friendly format string for extensions supported by this proxy. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMSaveAnimationProxy * New ()
static vtkSMSaveAnimationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMSaveScreenshotProxy
static vtkSMSaveScreenshotProxy * New ()
static vtkSMSaveScreenshotProxy * SafeDownCast (vtkObject *o)
static vtkSmartPointer< vtkImageData > CaptureImage (vtkSMViewProxy *view, const vtkVector2i &size)
 This method can be used to capture an image for a view for a specific resolution using default options. More...
static vtkSmartPointer< vtkImageData > CaptureImage (vtkSMViewLayoutProxy *view, const vtkVector2i &size)
 This method can be used to capture an image for a layout for a specific resolution using default options. More...
static vtkVector2i GetScaleFactorsAndSize (const vtkVector2i &targetSize, vtkVector2i &size, bool *approximate=nullptr)
 Compute scale factors and new size for target resolution. More...
static int ComputeMagnification (const vtkVector2i &targetSize, vtkVector2i &size)
 Compute a single magnification factor to reach targetSize using a box that fits within size. More...
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMSaveAnimationProxy ()
 ~vtkSMSaveAnimationProxy () override
virtual bool WriteAnimationInternal (const char *filename, vtkTypeUInt32 location=vtkPVSession::CLIENT)
 Write animation on local process. More...
bool Prepare () override
 Prepares for saving animation. More...
bool Cleanup () override
 This restores the state after saving the animation. More...
virtual bool EnforceSizeRestrictions (const char *filename)
 Change "ImageResolution" property as needed for the file format requested. More...
vtkSMViewLayoutProxy * GetLayout ()
vtkSMViewProxy * GetView ()
vtkSMSaveScreenshotProxy * GetScreenshotHelper ()
vtkSMProxy * GetAnimationScene ()
- Protected Member Functions inherited from vtkSMSaveScreenshotProxy
 vtkSMSaveScreenshotProxy ()
 ~vtkSMSaveScreenshotProxy () override
std::pair< vtkSmartPointer< vtkImageData >, vtkSmartPointer< vtkImageData > > CapturePreppedImages ()
 When StereoMode is set to VTK_STEREO_EMULATE, both eyes are captures. More...
vtkSMProxy * GetFormatProxy (const std::string &filename)
 Select the format proxy to match the given extension. More...
std::string GetStereoFileName (const std::string &filename, bool left)
 Adds a stereo filename suffix to the given filename. More...
virtual void SetUseFloatingPointBuffers (bool)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
Friends
class vtkSMSaveAnimationProxyNS::Friendship
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMSaveAnimationProxy is a proxy that helps with saving animation to images or video. The properties on this proxy provide various options that user can configure when saving animations. Once those properties are setup, one calls vtkSMSaveAnimationProxy::WriteAnimation` to save out the animation.
Definition at line 26 of file vtkSMSaveAnimationProxy.h.
Definition at line 30 of file vtkSMSaveAnimationProxy.h.
◆ vtkSMSaveAnimationProxy()
vtkSMSaveAnimationProxy::vtkSMSaveAnimationProxy ( )
◆ ~vtkSMSaveAnimationProxy()
vtkSMSaveAnimationProxy::~vtkSMSaveAnimationProxy ( )
static vtkSMSaveAnimationProxy* vtkSMSaveAnimationProxy::New ( )
virtual const char* vtkSMSaveAnimationProxy::GetClassName ( )
Reimplemented from vtkSMSaveScreenshotProxy.
static int vtkSMSaveAnimationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMSaveAnimationProxy::IsA ( const char *  type)
static vtkSMSaveAnimationProxy* vtkSMSaveAnimationProxy::SafeDownCast ( vtkObject *  o)
void vtkSMSaveAnimationProxy::PrintSelf ( ostream &  os,
◆ WriteAnimation()
virtual bool vtkSMSaveAnimationProxy::WriteAnimation ( const char *  filename,
vtkTypeUInt32  location = vtkPVSession::CLIENT
The properties on this proxy provide all the necessary information to save the animation.
◆ UpdateDefaultsAndVisibilities()
void vtkSMSaveAnimationProxy::UpdateDefaultsAndVisibilities ( const char *  filename)
◆ WriteAnimationInternal()
virtual bool vtkSMSaveAnimationProxy::WriteAnimationInternal ( const char *  filename,
protectedvirtual
◆ Prepare()
bool vtkSMSaveAnimationProxy::Prepare ( )
overrideprotectedvirtual
◆ Cleanup()
bool vtkSMSaveAnimationProxy::Cleanup ( )
◆ EnforceSizeRestrictions()
virtual bool vtkSMSaveAnimationProxy::EnforceSizeRestrictions ( const char *  filename)
protectedvirtual
Returns
true if changed, false otherwise.
◆ GetLayout()
vtkSMViewLayoutProxy* vtkSMSaveAnimationProxy::GetLayout ( )
◆ GetView()
vtkSMViewProxy* vtkSMSaveAnimationProxy::GetView ( )
◆ GetScreenshotHelper()
vtkSMSaveScreenshotProxy* vtkSMSaveAnimationProxy::GetScreenshotHelper ( )
◆ GetAnimationScene()
vtkSMProxy* vtkSMSaveAnimationProxy::GetAnimationScene ( )
◆ vtkSMSaveAnimationProxyNS::Friendship
friend class vtkSMSaveAnimationProxyNS::Friendship
friend
Definition at line 79 of file vtkSMSaveAnimationProxy.h.
