vtkSMLiveInsituLinkProxy Class Reference
Performs additional operation on the Live client. More...
#include <vtkSMLiveInsituLinkProxy.h>
Inheritance diagram for vtkSMLiveInsituLinkProxy:
Collaboration diagram for vtkSMLiveInsituLinkProxy:
typedef vtkSMProxy Superclass
bool HasExtract (const char *reg_group, const char *reg_name, int port_number)
 Overridden to handle server-notification messages. More...
void PushUpdatedStates ()
 Push updated states from the client to the server in aggregate (originally, when the simulation was paused, multiple partial updates were pushed, resulting in the connection between client and server to sever). More...
vtkSMSessionProxyManager * GetInsituProxyManager ()
 Provides access to the a dummy proxy manager representing the insitu visualization pipeline. More...
void SetInsituProxyManager (vtkSMSessionProxyManager *)
vtkSMProxy * CreateExtract (const char *reg_group, const char *reg_name, int port_number)
void RemoveExtract (vtkSMProxy *)
void LiveChanged ()
 Wakes up Insitu side if simulation is paused. More...
vtkIdType GetTimeStep ()
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMLiveInsituLinkProxy * New ()
static vtkSMLiveInsituLinkProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMLiveInsituLinkProxy ()
 ~vtkSMLiveInsituLinkProxy () override
void MarkStateDirty ()
void PushUpdatedState ()
 Pushes XML state to the server if needed. More...
void InsituConnected (const char *initialial_state)
void NextTimestepAvailable (vtkIdType timeStep)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSmartPointer< vtkSMSessionProxyManager > InsituProxyManager
vtkWeakPointer< vtkPVCatalystSessionCore > CatalystSessionCore
bool StateDirty
vtkIdType TimeStep
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Besides setting or getting parameters from its object (vtkSMLiveInsituLink) it receives paraview state from its object and applies it to the InsituProxyManager as well as sending modified paraview state to its object.
Definition at line 25 of file vtkSMLiveInsituLinkProxy.h.
Definition at line 29 of file vtkSMLiveInsituLinkProxy.h.
◆ vtkSMLiveInsituLinkProxy()
vtkSMLiveInsituLinkProxy::vtkSMLiveInsituLinkProxy ( )
◆ ~vtkSMLiveInsituLinkProxy()
vtkSMLiveInsituLinkProxy::~vtkSMLiveInsituLinkProxy ( )
static vtkSMLiveInsituLinkProxy* vtkSMLiveInsituLinkProxy::New ( )
virtual const char* vtkSMLiveInsituLinkProxy::GetClassName ( )
static int vtkSMLiveInsituLinkProxy::IsTypeOf ( const char *  type)
virtual int vtkSMLiveInsituLinkProxy::IsA ( const char *  type)
static vtkSMLiveInsituLinkProxy* vtkSMLiveInsituLinkProxy::SafeDownCast ( vtkObject *  o)
void vtkSMLiveInsituLinkProxy::PrintSelf ( ostream &  os,
◆ GetInsituProxyManager()
vtkSMSessionProxyManager* vtkSMLiveInsituLinkProxy::GetInsituProxyManager ( )
◆ SetInsituProxyManager()
void vtkSMLiveInsituLinkProxy::SetInsituProxyManager ( vtkSMSessionProxyManager *  )
◆ HasExtract()
bool vtkSMLiveInsituLinkProxy::HasExtract ( const char *  reg_group,
const char *  reg_name,
int  port_number
◆ CreateExtract()
vtkSMProxy* vtkSMLiveInsituLinkProxy::CreateExtract ( const char *  reg_group,
int  port_number
◆ RemoveExtract()
void vtkSMLiveInsituLinkProxy::RemoveExtract ( vtkSMProxy *  )
◆ LiveChanged()
void vtkSMLiveInsituLinkProxy::LiveChanged ( )
Handles correctly several calls on the LIVE side.
◆ GetTimeStep()
vtkIdType vtkSMLiveInsituLinkProxy::GetTimeStep ( )
inline
Definition at line 53 of file vtkSMLiveInsituLinkProxy.h.
◆ LoadState()
void vtkSMLiveInsituLinkProxy::LoadState ( const vtkSMMessage *  msg,
vtkSMProxyLocator *  locator
Reimplemented from vtkSMRemoteObject.
◆ PushUpdatedStates()
void vtkSMLiveInsituLinkProxy::PushUpdatedStates ( )
◆ CreateVTKObjects()
void vtkSMLiveInsituLinkProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
◆ MarkStateDirty()
void vtkSMLiveInsituLinkProxy::MarkStateDirty ( )
◆ PushUpdatedState()
void vtkSMLiveInsituLinkProxy::PushUpdatedState ( )
◆ InsituConnected()
void vtkSMLiveInsituLinkProxy::InsituConnected ( const char *  initialial_state)
◆ NextTimestepAvailable()
void vtkSMLiveInsituLinkProxy::NextTimestepAvailable ( vtkIdType  timeStep)
◆ InsituProxyManager
vtkSmartPointer<vtkSMSessionProxyManager> vtkSMLiveInsituLinkProxy::InsituProxyManager
Definition at line 86 of file vtkSMLiveInsituLinkProxy.h.
◆ CatalystSessionCore
vtkWeakPointer<vtkPVCatalystSessionCore> vtkSMLiveInsituLinkProxy::CatalystSessionCore
Definition at line 87 of file vtkSMLiveInsituLinkProxy.h.
◆ StateDirty
bool vtkSMLiveInsituLinkProxy::StateDirty
Definition at line 89 of file vtkSMLiveInsituLinkProxy.h.
◆ TimeStep
vtkIdType vtkSMLiveInsituLinkProxy::TimeStep
Definition at line 90 of file vtkSMLiveInsituLinkProxy.h.
