vtkSMTransferFunctionProxy Class Reference
vtkSMTransferFunctionProxy is the proxy used for "PVLookupTable", "ColorTransferFunction" and "PiecewiseFunction". More...
#include <vtkSMTransferFunctionProxy.h>
Inheritance diagram for vtkSMTransferFunctionProxy:
Collaboration diagram for vtkSMTransferFunctionProxy:
typedef vtkSMProxy Superclass
virtual bool RescaleTransferFunction (const double range[2], bool extend=false)
 Rescale the "RGBPoints" for the transfer function to match the new range. More...
virtual bool RescaleTransferFunction (double rangeMin, double rangeMax, bool extend=false)
virtual bool InvertTransferFunction ()
 Invert the transfer function. More...
virtual bool MapControlPointsToLogSpace (bool inverse=false)
 Remaps control points by normalizing in linear-space and then interpolating in log-space. More...
virtual bool MapControlPointsToLinearSpace ()
virtual bool ApplyPreset (const char *presetname, bool rescale=true)
virtual bool SaveColorMap (vtkPVXMLElement *xml)
 Save to ColorMap XML. More...
virtual bool IsScalarBarVisible (vtkSMProxy *view)
 Return true if the representation corresponding to the transfer function for the view is showing a Scalar-Bar (Color Legend). More...
virtual vtkSMProxy * FindScalarBarRepresentation (vtkSMProxy *view)
 Find and return the Scalar-Bar (Color Legend) representation corresponding to the transfer function for the view, if any. More...
virtual bool ComputeAvailableAnnotations (bool extend=false)
virtual bool ApplyColorMap (const char *text)
 Load a ColorMap XML. More...
virtual bool ApplyColorMap (vtkPVXMLElement *xml)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMTransferFunctionProxy * New ()
static vtkSMTransferFunctionProxy * SafeDownCast (vtkObject *o)
static bool InvertTransferFunction (vtkSMProxy *)
 Safely call InvertTransferFunction() after casting the proxy to the appropriate type. More...
static bool MapControlPointsToLinearSpace (vtkSMProxy *proxy)
 Safely call MapControlPointsToLinearSpace() after casting the proxy to the appropriate type. More...
static bool ApplyPreset (vtkSMProxy *proxy, const char *presetname, bool rescale=true)
static bool ComputeAvailableAnnotations (vtkSMProxy *proxy, bool extend=false)
static bool ConvertLegacyColorMapsToJSON (const char *inxmlfile, const char *outjsonfile)
 Converts legacy xml file to json. More...
static bool ExportTransferFunction (vtkSMTransferFunctionProxy *colorTransferFunction, vtkSMTransferFunctionProxy *opacityTransferFunction, const char *tfname, const char *filename, vtkTypeUInt32 location=0x10)
 Export a transfer function to a json file. More...
static bool RescaleTransferFunction (vtkSMProxy *proxy, double rangeMin, double rangeMax, bool extend=false)
 Safely call RescaleTransferFunction() after casting the proxy to appropriate type. More...
static bool RescaleTransferFunction (vtkSMProxy *proxy, const double range[2], bool extend=false)
static bool MapControlPointsToLogSpace (vtkSMProxy *proxy, bool inverse=false)
 Safely call MapControlPointsToLogSpace() after casting the proxy to the appropriate type. More...
static bool ApplyColorMap (vtkSMProxy *proxy, const char *text)
 Safely call ApplyColorMap(..) after casting the proxy to the appropriate type. More...
static bool ApplyColorMap (vtkSMProxy *proxy, vtkPVXMLElement *xml)
static bool SaveColorMap (vtkSMProxy *proxy, vtkPVXMLElement *xml)
static bool IsScalarBarVisible (vtkSMProxy *proxy, vtkSMProxy *view)
 Safely call IsScalarBarVisible(..) after casting the proxy to the appropriate type. More...
static vtkSMProxy * FindScalarBarRepresentation (vtkSMProxy *proxy, vtkSMProxy *view)
 Safely call FindScalarBarRepresentation(..) after casting the proxy to the appropriate type. More...
static Json::Value ConvertLegacyColorMapXMLToJSON (vtkPVXMLElement *xml)
 Method to convert legacy color map preset XML to JSON. More...
static Json::Value ConvertLegacyColorMapXMLToJSON (const char *xmlcontents)
static Json::Value ConvertMultipleLegacyColorMapXMLToJSON (vtkPVXMLElement *xml)
 Method to convert legacy "ColorMaps" preset XML to JSON. More...
static Json::Value ConvertMultipleLegacyColorMapXMLToJSON (const char *xmlcontents)
static Json::Value ConvertVisItColorMapXMLToJSON (vtkPVXMLElement *xml)
 Method to convert VisIt color map preset XML to JSON. More...
static Json::Value ConvertVisItColorMapXMLToJSON (const char *xmlcontents)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMTransferFunctionProxy ()=default
 ~vtkSMTransferFunctionProxy () override=default
void RestoreFromSiteSettingsOrXML (const char *arrayName)
 Attempt to reset transfer function to site settings. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
double LastRange [2] = { 0, 1 }
vtkSmartPointer< vtkTable > HistogramTableCache
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false)
 Locates all representations that are currently using this transfer function and then rescales the transfer function scalar range to exactly match the combined valid scalar ranges obtained from them all. More...
virtual bool RescaleTransferFunctionToDataRange (bool extend=false)
static bool ApplyPreset (vtkSMProxy *proxy, const Json::Value &value, bool rescale=true)
 Apply a preset. More...
virtual bool ApplyPreset (const Json::Value &value, bool rescale=true)
static Json::Value GetStateAsPreset (vtkSMProxy *proxy)
 Saves the transfer function state as a preset. More...
virtual Json::Value GetStateAsPreset ()
static bool UpdateScalarBarsComponentTitle (vtkSMProxy *proxy, vtkPVArrayInformation *arrayInfo)
 Update component titles for all scalar bars connected to this transfer function proxy. More...
virtual bool UpdateScalarBarsComponentTitle (vtkPVArrayInformation *arrayInfo)
static bool ComputeDataRange (vtkSMProxy *proxy, double range[2])
 Helper method used by RescaleTransferFunctionToDataRange() to compute range from all visible representations using the transfer function. More...
virtual bool ComputeDataRange (double range[2])
static vtkTable * ComputeDataHistogramTable (vtkSMProxy *proxy, int numberOfBins)
 Helper method used to compute a histogram with provided number of bins based on the data from all the visible representations using the transfer function. More...
virtual vtkTable * ComputeDataHistogramTable (int numberOfBins)
static vtkTable * GetHistogramTableCache (vtkSMProxy *proxy)
 Helper method used to recover the last histogram computed by ComputeDataHistogram Returns the histogram as a vtkTable if available, nullptr otherwise. More...
virtual vtkTable * GetHistogramTableCache ()
static void ResetPropertiesToDefaults (vtkSMProxy *proxy, const char *arrayName, bool preserve_range=false)
 Helper method to reset a transfer function proxy to its defaults. More...
virtual void ResetPropertiesToDefaults (const char *arrayName, bool preserve_range)
static bool GetRange (vtkSMProxy *proxy, double range[2])
 Returns current transfer function data range. More...
virtual bool GetRange (double range[2])
It provides utility API to update lookup-table ranges, invert transfer function, etc. that can be used from C++ as well as Python layers.
Definition at line 25 of file vtkSMTransferFunctionProxy.h.
Definition at line 29 of file vtkSMTransferFunctionProxy.h.
◆ vtkSMTransferFunctionProxy()
vtkSMTransferFunctionProxy::vtkSMTransferFunctionProxy ( )
protecteddefault
◆ ~vtkSMTransferFunctionProxy()
vtkSMTransferFunctionProxy::~vtkSMTransferFunctionProxy ( )
overrideprotecteddefault
static vtkSMTransferFunctionProxy* vtkSMTransferFunctionProxy::New ( )
virtual const char* vtkSMTransferFunctionProxy::GetClassName ( )
static int vtkSMTransferFunctionProxy::IsTypeOf ( const char *  type)
virtual int vtkSMTransferFunctionProxy::IsA ( const char *  type)
static vtkSMTransferFunctionProxy* vtkSMTransferFunctionProxy::SafeDownCast ( vtkObject *  o)
void vtkSMTransferFunctionProxy::PrintSelf ( ostream &  os,
◆ RescaleTransferFunction() [1/4]
virtual bool vtkSMTransferFunctionProxy::RescaleTransferFunction ( const double  range[2],
bool  extend = false
inlinevirtual
Returns true if rescale was successful. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range.
Definition at line 38 of file vtkSMTransferFunctionProxy.h.
◆ RescaleTransferFunction() [2/4]
virtual bool vtkSMTransferFunctionProxy::RescaleTransferFunction ( double  rangeMin,
double  rangeMax,
bool  extend = false
◆ RescaleTransferFunction() [3/4]
static bool vtkSMTransferFunctionProxy::RescaleTransferFunction ( vtkSMProxy *  proxy,
double  rangeMin,
double  rangeMax,
bool  extend = false
◆ RescaleTransferFunction() [4/4]
bool  extend = false
inlinestatic
Definition at line 51 of file vtkSMTransferFunctionProxy.h.
◆ RescaleTransferFunctionToDataRange() [1/2]
virtual bool vtkSMTransferFunctionProxy::RescaleTransferFunctionToDataRange ( bool  extend = false)
◆ RescaleTransferFunctionToDataRange() [2/2]
static bool vtkSMTransferFunctionProxy::RescaleTransferFunctionToDataRange ( vtkSMProxy *  proxy,
bool  extend = false
inlinestatic
Definition at line 64 of file vtkSMTransferFunctionProxy.h.
◆ InvertTransferFunction() [1/2]
virtual bool vtkSMTransferFunctionProxy::InvertTransferFunction ( )
Returns true if successful.
◆ InvertTransferFunction() [2/2]
static bool vtkSMTransferFunctionProxy::InvertTransferFunction ( vtkSMProxy *  )
◆ MapControlPointsToLogSpace() [1/2]
virtual bool vtkSMTransferFunctionProxy::MapControlPointsToLogSpace ( bool  inverse = false)
This is useful when converting the transfer function from linear- to log-mode. If inverse is true, the operation is reversed i.e. the control points are normalized in log-space and interpolated in linear-space, useful when converting from log- to linear-mode.
◆ MapControlPointsToLinearSpace() [1/2]
virtual bool vtkSMTransferFunctionProxy::MapControlPointsToLinearSpace ( )
inlinevirtual
Definition at line 90 of file vtkSMTransferFunctionProxy.h.
◆ MapControlPointsToLogSpace() [2/2]
static bool vtkSMTransferFunctionProxy::MapControlPointsToLogSpace ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 97 of file vtkSMTransferFunctionProxy.h.
◆ MapControlPointsToLinearSpace() [2/2]
static bool vtkSMTransferFunctionProxy::MapControlPointsToLinearSpace ( vtkSMProxy *  proxy)
inlinestatic
Definition at line 108 of file vtkSMTransferFunctionProxy.h.
◆ ApplyPreset() [1/4]
virtual bool vtkSMTransferFunctionProxy::ApplyPreset ( const Json::Value &  value,
bool  rescale = true
Apply a preset.
If rescale is true (default), then apply loading the preset, the transfer function range will be preserved (if originally valid). If not valid, or rescale is false, then the range provided by the preset is used. When using indexed color maps, the rescale implies loading of annotations since the "range" for indexed color maps is described by the annotations.
◆ ApplyPreset() [2/4]
static bool vtkSMTransferFunctionProxy::ApplyPreset ( vtkSMProxy *  proxy,
bool  rescale = true
inlinestatic
Apply a preset.
Definition at line 123 of file vtkSMTransferFunctionProxy.h.
◆ ApplyPreset() [3/4]
virtual bool vtkSMTransferFunctionProxy::ApplyPreset ( const char *  presetname,
bool  rescale = true
◆ ApplyPreset() [4/4]
bool  rescale = true
inlinestatic
Definition at line 131 of file vtkSMTransferFunctionProxy.h.
◆ GetStateAsPreset() [1/2]
virtual Json::Value vtkSMTransferFunctionProxy::GetStateAsPreset ( )
This is simply a subset of the state of the transfer function proxy.
◆ GetStateAsPreset() [2/2]
static Json::Value vtkSMTransferFunctionProxy::GetStateAsPreset ( vtkSMProxy *  proxy)
◆ ApplyColorMap() [1/4]
virtual bool vtkSMTransferFunctionProxy::ApplyColorMap ( const char *  text)
This will update a transfer function using the ColorMap XML. Currently, this is only supported for color transfer functions. Returns true on success.
◆ ApplyColorMap() [2/4]
virtual bool vtkSMTransferFunctionProxy::ApplyColorMap ( vtkPVXMLElement *  xml)
◆ ApplyColorMap() [3/4]
static bool vtkSMTransferFunctionProxy::ApplyColorMap ( vtkSMProxy *  proxy,
const char *  text
inlinestatic
Definition at line 161 of file vtkSMTransferFunctionProxy.h.
◆ ApplyColorMap() [4/4]
inlinestatic
Definition at line 173 of file vtkSMTransferFunctionProxy.h.
◆ SaveColorMap() [1/2]
virtual bool vtkSMTransferFunctionProxy::SaveColorMap ( vtkPVXMLElement *  xml)
◆ SaveColorMap() [2/2]
static bool vtkSMTransferFunctionProxy::SaveColorMap ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 191 of file vtkSMTransferFunctionProxy.h.
◆ IsScalarBarVisible() [1/2]
virtual bool vtkSMTransferFunctionProxy::IsScalarBarVisible ( vtkSMProxy *  view)
Otherwise return false.
◆ IsScalarBarVisible() [2/2]
static bool vtkSMTransferFunctionProxy::IsScalarBarVisible ( vtkSMProxy *  proxy,
vtkSMProxy *  view
inlinestatic
Definition at line 210 of file vtkSMTransferFunctionProxy.h.
◆ FindScalarBarRepresentation() [1/2]
virtual vtkSMProxy* vtkSMTransferFunctionProxy::FindScalarBarRepresentation ( vtkSMProxy *  view)
This returns the proxy if one exists, it won't create a new one.
◆ FindScalarBarRepresentation() [2/2]
static vtkSMProxy* vtkSMTransferFunctionProxy::FindScalarBarRepresentation ( vtkSMProxy *  proxy,
vtkSMProxy *  view
inlinestatic
Definition at line 229 of file vtkSMTransferFunctionProxy.h.
◆ UpdateScalarBarsComponentTitle() [1/2]
virtual bool vtkSMTransferFunctionProxy::UpdateScalarBarsComponentTitle ( vtkPVArrayInformation *  arrayInfo)
The arrayInfo is used to determine component names, if possible.
◆ UpdateScalarBarsComponentTitle() [2/2]
static bool vtkSMTransferFunctionProxy::UpdateScalarBarsComponentTitle ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 243 of file vtkSMTransferFunctionProxy.h.
◆ ComputeDataRange() [1/2]
virtual bool vtkSMTransferFunctionProxy::ComputeDataRange ( double  range[2])
Returns true if a valid range was determined.
◆ ComputeDataRange() [2/2]
static bool vtkSMTransferFunctionProxy::ComputeDataRange ( vtkSMProxy *  proxy,
double  range[2]
inlinestatic
Definition at line 257 of file vtkSMTransferFunctionProxy.h.
◆ ComputeDataHistogramTable() [1/2]
virtual vtkTable* vtkSMTransferFunctionProxy::ComputeDataHistogramTable ( int  numberOfBins)
If successful, returns the histogram as a vtkTable containing two columns of double, the first one being the indexes, the second one the number of values. If not, returns nullptr.
◆ ComputeDataHistogramTable() [2/2]
static vtkTable* vtkSMTransferFunctionProxy::ComputeDataHistogramTable ( vtkSMProxy *  proxy,
int  numberOfBins
inlinestatic
Definition at line 273 of file vtkSMTransferFunctionProxy.h.
◆ GetHistogramTableCache() [1/2]
virtual vtkTable* vtkSMTransferFunctionProxy::GetHistogramTableCache ( )
inlinevirtual
Definition at line 285 of file vtkSMTransferFunctionProxy.h.
◆ GetHistogramTableCache() [2/2]
static vtkTable* vtkSMTransferFunctionProxy::GetHistogramTableCache ( vtkSMProxy *  proxy)
inlinestatic
Definition at line 286 of file vtkSMTransferFunctionProxy.h.
◆ ComputeAvailableAnnotations() [1/2]
virtual bool vtkSMTransferFunctionProxy::ComputeAvailableAnnotations ( bool  extend = false)
◆ ComputeAvailableAnnotations() [2/2]
static bool vtkSMTransferFunctionProxy::ComputeAvailableAnnotations ( vtkSMProxy *  proxy,
bool  extend = false
inlinestatic
Definition at line 296 of file vtkSMTransferFunctionProxy.h.
◆ ResetPropertiesToDefaults() [1/2]
virtual void vtkSMTransferFunctionProxy::ResetPropertiesToDefaults ( const char *  arrayName,
bool  preserve_range
By passing in preserve_range, you can make this method preserve the current transfer function range.
◆ ResetPropertiesToDefaults() [2/2]
static void vtkSMTransferFunctionProxy::ResetPropertiesToDefaults ( vtkSMProxy *  proxy,
bool  preserve_range = false
inlinestatic
Definition at line 309 of file vtkSMTransferFunctionProxy.h.
◆ ConvertLegacyColorMapXMLToJSON() [1/2]
static Json::Value vtkSMTransferFunctionProxy::ConvertLegacyColorMapXMLToJSON ( vtkPVXMLElement *  xml)
Use this to convert a single ColorMap xml. To convert a collection of color maps, use ConvertMultipleLegacyColorMapXMLToJSON().
◆ ConvertLegacyColorMapXMLToJSON() [2/2]
static Json::Value vtkSMTransferFunctionProxy::ConvertLegacyColorMapXMLToJSON ( const char *  xmlcontents)
◆ ConvertMultipleLegacyColorMapXMLToJSON() [1/2]
static Json::Value vtkSMTransferFunctionProxy::ConvertMultipleLegacyColorMapXMLToJSON ( vtkPVXMLElement *  xml)
This converts all colormaps in the XML.
◆ ConvertMultipleLegacyColorMapXMLToJSON() [2/2]
static Json::Value vtkSMTransferFunctionProxy::ConvertMultipleLegacyColorMapXMLToJSON ( const char *  xmlcontents)
◆ ConvertLegacyColorMapsToJSON()
static bool vtkSMTransferFunctionProxy::ConvertLegacyColorMapsToJSON ( const char *  inxmlfile,
const char *  outjsonfile
◆ ConvertVisItColorMapXMLToJSON() [1/2]
static Json::Value vtkSMTransferFunctionProxy::ConvertVisItColorMapXMLToJSON ( vtkPVXMLElement *  xml)
◆ ConvertVisItColorMapXMLToJSON() [2/2]
static Json::Value vtkSMTransferFunctionProxy::ConvertVisItColorMapXMLToJSON ( const char *  xmlcontents)
◆ GetRange() [1/2]
virtual bool vtkSMTransferFunctionProxy::GetRange ( double  range[2])
Returns false is a valid range could not be determined.
◆ GetRange() [2/2]
static bool vtkSMTransferFunctionProxy::GetRange ( vtkSMProxy *  proxy,
double  range[2]
inlinestatic
Definition at line 359 of file vtkSMTransferFunctionProxy.h.
◆ ExportTransferFunction()
static bool vtkSMTransferFunctionProxy::ExportTransferFunction ( vtkSMTransferFunctionProxy *  colorTransferFunction,
vtkSMTransferFunctionProxy *  opacityTransferFunction,
const char *  tfname,
const char *  filename,
vtkTypeUInt32  location = 0x10
opacityTransferFunction can be nullptr but colorTransferFunction must not be nullptr. The tfname will be the preset name upon importing the transfer function back into ParaView.
◆ RestoreFromSiteSettingsOrXML()
void vtkSMTransferFunctionProxy::RestoreFromSiteSettingsOrXML ( const char *  arrayName)
If site settings are not available, then the application XML defaults are used.
◆ LastRange
double vtkSMTransferFunctionProxy::LastRange[2] = { 0, 1 }
Definition at line 389 of file vtkSMTransferFunctionProxy.h.
◆ HistogramTableCache
vtkSmartPointer<vtkTable> vtkSMTransferFunctionProxy::HistogramTableCache
Definition at line 394 of file vtkSMTransferFunctionProxy.h.
