Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | List of all members
vtkSMExtractWriterProxy Class Referenceabstract
abstract class defining extract writer proxy API More...
#include <vtkSMExtractWriterProxy.h>
Inheritance diagram for vtkSMExtractWriterProxy:
Collaboration diagram for vtkSMExtractWriterProxy:
typedef vtkSMProxy Superclass
virtual bool Write (vtkSMExtractsController *extractor)=0
 Generate the extract. More...
virtual bool CanExtract (vtkSMProxy *proxy)=0
 Returns true if the provided proxy can be extracted/written by this writer. More...
virtual bool IsExtracting (vtkSMProxy *proxy)=0
 Returns true this extract writer proxy is generating and extract from the provided proxy. More...
virtual void SetInput (vtkSMProxy *proxy)=0
 This is convenience method that gets called by vtkSMExtractsController to set the extract writer to extract the given proxy. More...
virtual vtkSMProxy * GetInput ()=0
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMExtractWriterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMExtractWriterProxy ()
 ~vtkSMExtractWriterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static std::string GenerateExtractsFileName (const std::string &filename, const char *outDir)
 Adds the output directory to the filename, replaces, in case of need, the old string format, and returns the formatted string using vtkPVStringFormatter. More...
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMExtractWriterProxy is an abstract class that defines the API for extract writer proxies. Such proxies are intended to generate extracts from a "producer". The producer may be any support proxy.
Definition at line 19 of file vtkSMExtractWriterProxy.h.
Definition at line 22 of file vtkSMExtractWriterProxy.h.
◆ vtkSMExtractWriterProxy()
vtkSMExtractWriterProxy::vtkSMExtractWriterProxy ( )
◆ ~vtkSMExtractWriterProxy()
vtkSMExtractWriterProxy::~vtkSMExtractWriterProxy ( )
virtual const char* vtkSMExtractWriterProxy::GetClassName ( )
static int vtkSMExtractWriterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMExtractWriterProxy::IsA ( const char *  type)
static vtkSMExtractWriterProxy* vtkSMExtractWriterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMExtractWriterProxy::PrintSelf ( ostream &  os,
◆ Write()
virtual bool vtkSMExtractWriterProxy::Write ( vtkSMExtractsController *  extractor)
pure virtual
◆ CanExtract()
virtual bool vtkSMExtractWriterProxy::CanExtract ( vtkSMProxy *  proxy)
pure virtual
Note that this method is generally called on a prototype proxy and hence the writer-proxy would not have been fully instantiated.
Implemented in vtkSMPlotlyJsonExtractWriterProxy, vtkSMImageExtractWriterProxy, and vtkSMDataExtractWriterProxy.
◆ IsExtracting()
virtual bool vtkSMExtractWriterProxy::IsExtracting ( vtkSMProxy *  proxy)
pure virtual
◆ SetInput()
virtual void vtkSMExtractWriterProxy::SetInput ( vtkSMProxy *  proxy)
pure virtual
◆ GetInput()
virtual vtkSMProxy* vtkSMExtractWriterProxy::GetInput ( )
pure virtual
◆ GenerateExtractsFileName()
static std::string vtkSMExtractWriterProxy::GenerateExtractsFileName ( const std::string &  filename,
const char *  outDir
staticprotected
