vtkSMExtractTriggerProxy Class Reference
trigger to control extract generation More...
#include <vtkSMExtractTriggerProxy.h>
Inheritance diagram for vtkSMExtractTriggerProxy:
Collaboration diagram for vtkSMExtractTriggerProxy:
typedef vtkSMProxy Superclass
virtual bool IsActivated (vtkSMExtractsController *controller)
 Returns true if the trigger conditions are satisfied. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMExtractTriggerProxy * New ()
static vtkSMExtractTriggerProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMExtractTriggerProxy ()
 ~vtkSMExtractTriggerProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMExtractTriggerProxy defines a trigger that is intended to use a control an extractor. Currently, this class directly implements a time-based trigger which relies on properties to indicate the start-time, end-time, and update frequency. Subclasses can be added to define new types of triggers.
Definition at line 22 of file vtkSMExtractTriggerProxy.h.
Definition at line 26 of file vtkSMExtractTriggerProxy.h.
◆ vtkSMExtractTriggerProxy()
vtkSMExtractTriggerProxy::vtkSMExtractTriggerProxy ( )
◆ ~vtkSMExtractTriggerProxy()
vtkSMExtractTriggerProxy::~vtkSMExtractTriggerProxy ( )
static vtkSMExtractTriggerProxy* vtkSMExtractTriggerProxy::New ( )
virtual const char* vtkSMExtractTriggerProxy::GetClassName ( )
static int vtkSMExtractTriggerProxy::IsTypeOf ( const char *  type)
virtual int vtkSMExtractTriggerProxy::IsA ( const char *  type)
static vtkSMExtractTriggerProxy* vtkSMExtractTriggerProxy::SafeDownCast ( vtkObject *  o)
void vtkSMExtractTriggerProxy::PrintSelf ( ostream &  os,
◆ IsActivated()
virtual bool vtkSMExtractTriggerProxy::IsActivated ( vtkSMExtractsController *  controller)
