vtkSMPythonViewProxy Class Reference
Superclass for all view proxies. More...
#include <vtkSMPythonViewProxy.h>
Inheritance diagram for vtkSMPythonViewProxy:
Collaboration diagram for vtkSMPythonViewProxy:
typedef vtkSMViewProxy Superclass
- Public Types inherited from vtkSMViewProxy
enum  { PrepareContextForRendering = vtkCommand::UserEvent + 1 }
typedef vtkSMProxy Superclass
vtkRenderer * GetRenderer ()
 Returns the client-side renderer. More...
vtkRenderWindow * GetRenderWindow () override
 Returns the client-side render window. More...
vtkRenderWindowInteractor * GetInteractor () override
 Returns the interactor. More...
void SetupInteractor (vtkRenderWindowInteractor *iren) override
 A client process need to set the interactor to enable interactivity. More...
- Public Member Functions inherited from vtkSMViewProxy
virtual void StillRender ()
 Renders the view using full resolution. More...
virtual void InteractiveRender ()
 Renders the view using lower resolution is possible. More...
virtual void Update ()
 Called vtkPVView::Update on the server-side. More...
virtual bool CanDisplayData (vtkSMSourceProxy *producer, int outputPort)
 Returns true if the view can display the data produced by the producer's port. More...
virtual vtkSMRepresentationProxy * CreateDefaultRepresentation (vtkSMProxy *, int)
 Create a default representation for the given source proxy. More...
virtual const char * GetRepresentationType (vtkSMSourceProxy *producer, int outputPort)
 Returns the xml name of the representation proxy to create to show the data produced in this view, if any. More...
virtual vtkSMRepresentationProxy * FindRepresentation (vtkSMSourceProxy *producer, int outputPort)
 Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * GetClientSideView ()
 Returns the client-side vtkView, if any. More...
int WriteImage (const char *filename, const char *writerName, int magnification=1)
 Saves a screenshot of the view to disk. More...
int WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY)
virtual bool HasDirtyRepresentation ()
 Return true any internal representation is dirty. More...
virtual bool MakeRenderWindowInteractor (bool quiet=false)
 Creates a default render window interactor for the vtkRenderWindow and sets it up on the local process if the local process supports interaction. More...
virtual void SetEnable (bool)
 Enable/Disable a view. More...
virtual bool GetEnable ()
virtual void EnableOn ()
virtual void EnableOff ()
vtkImageData * CaptureWindow (int magnification)
 Captures a image from this view. More...
vtkImageData * CaptureWindow (int magnificationX, int magnificationY)
 Returns true if the subsequent call to Update() will result in an actual update. More...
virtual bool HideOtherRepresentationsIfNeeded (vtkSMProxy *repr)
 Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
virtual void RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility)
 Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMPythonViewProxy * New ()
static vtkSMPythonViewProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMViewProxy
static vtkSMViewProxy * New ()
static vtkSMViewProxy * SafeDownCast (vtkObject *o)
static vtkSMViewProxy * FindView (vtkSMProxy *repr, const char *reggroup="views")
 Helper method to locate a view to which the representation has been added. More...
static void SetTransparentBackground (bool val)
 Sets whether screenshots have a transparent background. More...
static bool GetTransparentBackground ()
static bool HideOtherRepresentationsIfNeeded (vtkSMViewProxy *self, vtkSMProxy *repr)
static void RepresentationVisibilityChanged (vtkSMViewProxy *self, vtkSMProxy *repr, bool new_visibility)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMPythonViewProxy ()
 ~vtkSMPythonViewProxy () override
vtkTypeUInt32 PreRender (bool interactive) override
 This view currently only supports rendering on client, even in tile-display mode. More...
vtkImageData * CaptureWindowInternal (int magX, int magY) override
 Subclasses should override this method to do the actual image capture. More...
- Protected Member Functions inherited from vtkSMViewProxy
 vtkSMViewProxy ()
 ~vtkSMViewProxy () override
virtual void RenderForImageCapture ()
 This method is called whenever the view wants to render to during image capture. More...
virtual vtkTypeUInt32 PreRender (bool vtkNotUsed(interactive))
 This method is called before executing code that could cause a render on the underlying vtkPVView. More...
virtual void PostRender (bool vtkNotUsed(interactive))
virtual bool IsContextReadyForRendering ()
 Subclasses should override this method and return false if the rendering context is not ready for rendering at this moment. More...
 Called at the end of CreateVTKObjects(). More...
bool GetLocalProcessSupportsInteraction ()
 Convenience method to call vtkPVView::SafeDownCast(this->GetClientSideObject())->GetLocalProcessSupportsInteraction();. More...
virtual vtkSMDataDeliveryManagerProxy * GetDeliveryManager ()
 Provides access to the delivery manager proxy, if any. More...
virtual void SetDefaultRepresentationName (const char *)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMViewProxy
char * DefaultRepresentationName
bool Enable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMPythonViewProxy is a view proxy for the vtkPythonView.
Definition at line 23 of file vtkSMPythonViewProxy.h.
Definition at line 27 of file vtkSMPythonViewProxy.h.
◆ vtkSMPythonViewProxy()
vtkSMPythonViewProxy::vtkSMPythonViewProxy ( )
◆ ~vtkSMPythonViewProxy()
vtkSMPythonViewProxy::~vtkSMPythonViewProxy ( )
static vtkSMPythonViewProxy* vtkSMPythonViewProxy::New ( )
virtual const char* vtkSMPythonViewProxy::GetClassName ( )
Reimplemented from vtkSMViewProxy.
static int vtkSMPythonViewProxy::IsTypeOf ( const char *  type)
virtual int vtkSMPythonViewProxy::IsA ( const char *  type)
static vtkSMPythonViewProxy* vtkSMPythonViewProxy::SafeDownCast ( vtkObject *  o)
void vtkSMPythonViewProxy::PrintSelf ( ostream &  os,
◆ GetRenderer()
vtkRenderer* vtkSMPythonViewProxy::GetRenderer ( )
◆ GetRenderWindow()
vtkRenderWindow* vtkSMPythonViewProxy::GetRenderWindow ( )
◆ GetInteractor()
vtkRenderWindowInteractor* vtkSMPythonViewProxy::GetInteractor ( )
Note, that views may not use vtkRenderWindow at all in which case they will not have any interactor and will return nullptr. Default implementation returns nullptr.
◆ SetupInteractor()
void vtkSMPythonViewProxy::SetupInteractor ( vtkRenderWindowInteractor *  iren)
Use this method to set the interactor and initialize it as needed by the RenderView. This include changing the interactor style as well as overriding VTK rendering to use the Proxy/ViewProxy API instead. Default implementation does nothing. Views that support interaction using vtkRenderWindowInteractor should override this method to set the interactor up.
◆ PreRender()
vtkTypeUInt32 vtkSMPythonViewProxy::PreRender ( bool  interactive)
Which means it will not show any results on the tile display.
◆ CaptureWindowInternal()
vtkImageData* vtkSMPythonViewProxy::CaptureWindowInternal ( int  magX,
int  magY
overrideprotectedvirtual
