vtkSMTextWidgetRepresentationProxy Class Reference
#include <vtkSMTextWidgetRepresentationProxy.h>
Inheritance diagram for vtkSMTextWidgetRepresentationProxy:
Collaboration diagram for vtkSMTextWidgetRepresentationProxy:
typedef vtkSMNewWidgetRepresentationProxy Superclass
- Public Types inherited from vtkSMNewWidgetRepresentationProxy
typedef vtkSMNewWidgetRepresentationProxyAbstract Superclass
- Public Types inherited from vtkSMNewWidgetRepresentationProxyAbstract
typedef vtkSMProxy Superclass
- Public Member Functions inherited from vtkSMNewWidgetRepresentationProxy
virtual vtkAbstractWidget * GetWidget ()
 Get the widget for the representation. More...
virtual vtkSMProxy * GetRepresentationProxy ()
 Get Representation Proxy. More...
- Public Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
bool LinkProperties (vtkSMProxy *controlledProxy, vtkSMPropertyGroup *controlledPropertyGroup)
 Called to link properties from a Widget to controlledProxy i.e. More...
bool UnlinkProperties (vtkSMProxy *controlledProxy)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMTextWidgetRepresentationProxy * New ()
static vtkSMTextWidgetRepresentationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMNewWidgetRepresentationProxy
static vtkSMNewWidgetRepresentationProxy * New ()
static vtkSMNewWidgetRepresentationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
static vtkSMNewWidgetRepresentationProxyAbstract * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMTextWidgetRepresentationProxy ()
 ~vtkSMTextWidgetRepresentationProxy () override
 Overridden from vtkSMProxy to call BeginCreateVTKObjects() and EndCreateVTKObjects(). More...
- Protected Member Functions inherited from vtkSMNewWidgetRepresentationProxy
 vtkSMNewWidgetRepresentationProxy ()
 ~vtkSMNewWidgetRepresentationProxy () override
void ExecuteEvent (unsigned long event) override
 Called every time the user interacts with the widget. More...
- Protected Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
 vtkSMNewWidgetRepresentationProxyAbstract ()
 ~vtkSMNewWidgetRepresentationProxyAbstract () override
void ProcessLinkedPropertyEvent (vtkSMProperty *caller, unsigned long event)
 Called everytime a controlled property's unchecked values change. More...
void SetupPropertiesLinks ()
 Setup all links between properties and informations. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMProxy * TextActorProxy
vtkSMProxy * TextPropertyProxy
- Protected Attributes inherited from vtkSMNewWidgetRepresentationProxy
vtkSMProxy * RepresentationProxy = nullptr
vtkSMProxy * WidgetProxy = nullptr
vtkAbstractWidget * Widget = nullptr
- Protected Attributes inherited from vtkSMNewWidgetRepresentationProxyAbstract
vtkNew< vtkSMWidgetObserver > Observer
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Friends
class vtkSMTextSourceRepresentationProxy
Definition at line 16 of file vtkSMTextWidgetRepresentationProxy.h.
Definition at line 21 of file vtkSMTextWidgetRepresentationProxy.h.
◆ vtkSMTextWidgetRepresentationProxy()
vtkSMTextWidgetRepresentationProxy::vtkSMTextWidgetRepresentationProxy ( )
◆ ~vtkSMTextWidgetRepresentationProxy()
vtkSMTextWidgetRepresentationProxy::~vtkSMTextWidgetRepresentationProxy ( )
static vtkSMTextWidgetRepresentationProxy* vtkSMTextWidgetRepresentationProxy::New ( )
virtual const char* vtkSMTextWidgetRepresentationProxy::GetClassName ( )
Reimplemented from vtkSMNewWidgetRepresentationProxy.
static int vtkSMTextWidgetRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMTextWidgetRepresentationProxy::IsA ( const char *  type)
static vtkSMTextWidgetRepresentationProxy* vtkSMTextWidgetRepresentationProxy::SafeDownCast ( vtkObject *  o)
void vtkSMTextWidgetRepresentationProxy::PrintSelf ( ostream &  os,
◆ CreateVTKObjects()
void vtkSMTextWidgetRepresentationProxy::CreateVTKObjects ( )
overrideprotectedvirtual
◆ vtkSMTextSourceRepresentationProxy
friend class vtkSMTextSourceRepresentationProxy
friend
Definition at line 33 of file vtkSMTextWidgetRepresentationProxy.h.
◆ TextActorProxy
vtkSMProxy* vtkSMTextWidgetRepresentationProxy::TextActorProxy
Definition at line 30 of file vtkSMTextWidgetRepresentationProxy.h.
◆ TextPropertyProxy
vtkSMProxy* vtkSMTextWidgetRepresentationProxy::TextPropertyProxy
Definition at line 31 of file vtkSMTextWidgetRepresentationProxy.h.
