Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | List of all members
vtkSMTransferFunction2DProxy Class Reference
vtkSMTransferFunction2DProxy is the proxy used for "TransferFunction2D". More...
#include <vtkSMTransferFunction2DProxy.h>
Inheritance diagram for vtkSMTransferFunction2DProxy:
Collaboration diagram for vtkSMTransferFunction2DProxy:
virtual bool RescaleTransferFunction (const double range[4], bool extend=false)
 Rescale the control boxes for the 2D transfer function to match the new range. More...
virtual bool RescaleTransferFunction (double rangeXMin, double rangeXMax, double rangeYMin, double rangeYMax, bool extend=false)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMTransferFunction2DProxy * New ()
 Instantiate the class. More...
static bool RescaleTransferFunction (vtkSMProxy *proxy, double rangeXMin, double rangeXMax, double rangeYMin, double rangeYMax, bool extend=false)
 Safely call RescaleTransferFunction() after casting the proxy to appropriate type. More...
static bool RescaleTransferFunction (vtkSMProxy *proxy, const double range[4], bool extend=false)
static vtkSMProxy * New ()
static vtkSMObject * New ()
static const int BOX_PROPERTY_SIZE = 8
 Expected tuple size of the boxes property of the proxy. More...
 vtkSMTransferFunction2DProxy ()=default
 ~vtkSMTransferFunction2DProxy () override=default
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSmartPointer< vtkImageData > Histogram2DCache
 Cache for the 2D histogram image. More...
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
typedef vtkSMProxy Superclass
 Standard methods for the VTK class. More...
static vtkSMTransferFunction2DProxy * SafeDownCast (vtkObject *o)
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false)
 Locates all representations that are currently using this transfer function and then rescales the transfer function scalar range to exactly match the combined valid scalar ranges obtained from them all. More...
virtual bool RescaleTransferFunctionToDataRange (bool extend=false)
static bool ComputeDataRange (vtkSMProxy *proxy, double range[4])
 Helper method used by RescaleTransferFunctionToDataRange() to compute range from all visible representations using the transfer function. More...
virtual bool ComputeDataRange (double range[4])
static vtkSmartPointer< vtkImageData > ComputeDataHistogram2D (vtkSMProxy *proxy, int numberOfBins)
 Helper method used to compute a 2D histogram image with provided number of bins based on the data from all the visible representations using the transfer function. More...
virtual vtkSmartPointer< vtkImageData > ComputeDataHistogram2D (int numberOfBins)
static vtkImageData * GetHistogram2DCache (vtkSMProxy *proxy)
 Helper method used to recover the last histogram computed by ComputeDataHistogram2D Returns the histogram as a vtkImageData if available, nullptr otherwise. More...
virtual vtkImageData * GetHistogram2DCache ()
static bool GetRange (vtkSMProxy *proxy, double range[4])
 Returns current transfer function data range. More...
virtual bool GetRange (double range[4])
vtkSMTransferFunction2DProxy provides the utility API to update 2D transfer function range, control boxes, etc.
Definition at line 24 of file vtkSMTransferFunction2DProxy.h.
Definition at line 36 of file vtkSMTransferFunction2DProxy.h.
◆ vtkSMTransferFunction2DProxy()
vtkSMTransferFunction2DProxy::vtkSMTransferFunction2DProxy ( )
protecteddefault
◆ ~vtkSMTransferFunction2DProxy()
vtkSMTransferFunction2DProxy::~vtkSMTransferFunction2DProxy ( )
overrideprotecteddefault
static vtkSMTransferFunction2DProxy* vtkSMTransferFunction2DProxy::New ( )
virtual const char* vtkSMTransferFunction2DProxy::GetClassName ( )
static int vtkSMTransferFunction2DProxy::IsTypeOf ( const char *  type)
virtual int vtkSMTransferFunction2DProxy::IsA ( const char *  type)
static vtkSMTransferFunction2DProxy* vtkSMTransferFunction2DProxy::SafeDownCast ( vtkObject *  o)
void vtkSMTransferFunction2DProxy::PrintSelf ( ostream &  os,
◆ RescaleTransferFunction() [1/4]
virtual bool vtkSMTransferFunction2DProxy::RescaleTransferFunction ( const double  range[4],
bool  extend = false
inlinevirtual
Returns true if rescale was successful. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range.
Definition at line 46 of file vtkSMTransferFunction2DProxy.h.
◆ RescaleTransferFunction() [2/4]
virtual bool vtkSMTransferFunction2DProxy::RescaleTransferFunction ( double  rangeXMin,
double  rangeXMax,
double  rangeYMin,
double  rangeYMax,
bool  extend = false
◆ RescaleTransferFunction() [3/4]
static bool vtkSMTransferFunction2DProxy::RescaleTransferFunction ( vtkSMProxy *  proxy,
double  rangeXMin,
double  rangeXMax,
double  rangeYMin,
double  rangeYMax,
bool  extend = false
◆ RescaleTransferFunction() [4/4]
bool  extend = false
inlinestatic
Definition at line 60 of file vtkSMTransferFunction2DProxy.h.
◆ RescaleTransferFunctionToDataRange() [1/2]
virtual bool vtkSMTransferFunction2DProxy::RescaleTransferFunctionToDataRange ( bool  extend = false)
◆ RescaleTransferFunctionToDataRange() [2/2]
static bool vtkSMTransferFunction2DProxy::RescaleTransferFunctionToDataRange ( vtkSMProxy *  proxy,
bool  extend = false
inlinestatic
Definition at line 74 of file vtkSMTransferFunction2DProxy.h.
◆ ComputeDataRange() [1/2]
virtual bool vtkSMTransferFunction2DProxy::ComputeDataRange ( double  range[4])
Returns true if a valid range was determined.
◆ ComputeDataRange() [2/2]
static bool vtkSMTransferFunction2DProxy::ComputeDataRange ( vtkSMProxy *  proxy,
double  range[4]
inlinestatic
Definition at line 88 of file vtkSMTransferFunction2DProxy.h.
◆ ComputeDataHistogram2D() [1/2]
virtual vtkSmartPointer<vtkImageData> vtkSMTransferFunction2DProxy::ComputeDataHistogram2D ( int  numberOfBins)
If successful, returns the histogram as a vtkImageData of type double. If not, returns nullptr.
◆ ComputeDataHistogram2D() [2/2]
static vtkSmartPointer<vtkImageData> vtkSMTransferFunction2DProxy::ComputeDataHistogram2D ( vtkSMProxy *  proxy,
int  numberOfBins
inlinestatic
Definition at line 103 of file vtkSMTransferFunction2DProxy.h.
◆ GetHistogram2DCache() [1/2]
virtual vtkImageData* vtkSMTransferFunction2DProxy::GetHistogram2DCache ( )
inlinevirtual
Definition at line 115 of file vtkSMTransferFunction2DProxy.h.
◆ GetHistogram2DCache() [2/2]
static vtkImageData* vtkSMTransferFunction2DProxy::GetHistogram2DCache ( vtkSMProxy *  proxy)
inlinestatic
Definition at line 116 of file vtkSMTransferFunction2DProxy.h.
◆ GetRange() [1/2]
virtual bool vtkSMTransferFunction2DProxy::GetRange ( double  range[4])
Returns false is a valid range could not be determined.
◆ GetRange() [2/2]
static bool vtkSMTransferFunction2DProxy::GetRange ( vtkSMProxy *  proxy,
double  range[4]
inlinestatic
Definition at line 129 of file vtkSMTransferFunction2DProxy.h.
◆ BOX_PROPERTY_SIZE
const int vtkSMTransferFunction2DProxy::BOX_PROPERTY_SIZE = 8
Internal use only.
Definition at line 140 of file vtkSMTransferFunction2DProxy.h.
◆ Histogram2DCache
vtkSmartPointer<vtkImageData> vtkSMTransferFunction2DProxy::Histogram2DCache
Definition at line 150 of file vtkSMTransferFunction2DProxy.h.
