Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | Static Protected Attributes | Friends | List of all members
vtkSMProxyProperty Class Reference
property representing pointer(s) to vtkObject(s) More...
#include <vtkSMProxyProperty.h>
Inheritance diagram for vtkSMProxyProperty:
Collaboration diagram for vtkSMProxyProperty:
class  vtkPPInternals
 This class is used by vtkSMProxyProperty to keep track of the proxies. More...
typedef vtkSMProperty Superclass
- Public Types inherited from vtkSMProperty
virtual void SetProxies (unsigned int numElements, vtkSMProxy *proxies[])
 Sets the value of the property to the list of proxies specified. More...
bool IsProxyAdded (vtkSMProxy *proxy)
 Returns if the given proxy is already added to the property. More...
virtual void RemoveAllUncheckedProxies ()
 Removes all unchecked proxies. More...
void ClearUncheckedElements () override
 Use this method to clear unchecked values set of this property. More...
unsigned int GetNumberOfProxies ()
 Returns the number of proxies. More...
unsigned int GetNumberOfUncheckedProxies ()
 Returns the number of unchecked proxies. More...
vtkSMProxy * GetProxy (unsigned int idx)
 Return a proxy. More...
vtkSMProxy * GetUncheckedProxy (unsigned int idx)
void Copy (vtkSMProperty *src) override
 Copy all property values. More...
void UpdateAllInputs () override
 Update all proxies referred by this property (if any). More...
bool IsValueDefault () override
 Returns true if the property's value is different from the default value. More...
void ResetToXMLDefaults () override
 For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
virtual void AddProxy (vtkSMProxy *proxy)
 Add/remove/set a proxy to the list of proxies. More...
virtual void SetProxy (unsigned int idx, vtkSMProxy *proxy)
virtual void RemoveProxy (vtkSMProxy *proxy)
virtual void RemoveAllProxies ()
virtual void AddUncheckedProxy (vtkSMProxy *proxy)
 Add an unchecked proxy. More...
virtual void SetUncheckedProxy (unsigned int idx, vtkSMProxy *proxy)
void SetNumberOfProxies (unsigned int count)
 Set the number of proxies. More...
void SetNumberOfUncheckedProxies (unsigned int count)
- Public Member Functions inherited from vtkSMProperty
int IsInDomains ()
 Returns true if all values are in all domains, false otherwise. More...
int IsInDomains (vtkSMDomain **domain)
 Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void UnRegister (vtkObjectBase *obj) override
 Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIterator * NewDomainIterator ()
 Creates, initializes and returns a new domain iterator. More...
vtkSMDomain * GetDomain (const char *name)
 Returns a domain give a name. More...
vtkSMDomain * FindDomain (const char *classname)
 Returns the first domain which is of the specified type. More...
template<class DomainType >
DomainType * FindDomain ()
 Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int GetNumberOfDomains ()
 Returns the number of domains this property has. More...
void AddDomain (const char *name, vtkSMDomain *dom)
 Properties can have one or more domains. More...
virtual void AddLinkedProperty (vtkSMProperty *targetProperty)
 Add a link to a property whose value should be synchronized with this property value. More...
virtual void RemoveLinkedProperty (vtkSMProperty *targetProperty)
 Remove a link to a property added with AddLinkedProperty() More...
virtual void RemoveFromSourceLink ()
 Remove a link from the source property. More...
void ResetToDefault ()
 Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
virtual bool ResetToDomainDefaults (bool use_unchecked_values=false)
 Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More...
vtkSMProxy * GetParent ()
 Get the proxy to which this property belongs. More...
virtual bool IsStateIgnored ()
bool HasDomainsWithRequiredProperties ()
 Returns true if the property has a domain with required properties. More...
virtual void SetCommand (const char *)
 The command name used to set the value on the server object. More...
virtual char * GetCommand ()
virtual void SetImmediateUpdate (int)
 If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int GetImmediateUpdate ()
virtual int GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int GetIgnoreSynchronization ()
 If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMProperty * GetInformationProperty ()
 Get the associated information property. More...
virtual void SetAnimateable (int)
 Get/Set if the property is animateable. More...
virtual int GetAnimateable ()
virtual void SetIsInternal (int)
 Get/Set if the property is internal to server manager. More...
virtual int GetIsInternal ()
virtual void SetNoCustomDefault (int)
 Set/Get whether the property should ignore custom default settings. More...
virtual int GetNoCustomDefault ()
virtual void SetPanelVisibility (const char *)
 Set/Get the panel visibility for the property. More...
virtual char * GetPanelVisibility ()
virtual void SetPanelVisibilityDefaultForRepresentation (const char *)
 Set/Get the panel visibility to default if the current representation type matches representation. More...
virtual char * GetPanelVisibilityDefaultForRepresentation ()
virtual void SetPanelWidget (const char *)
 Set/Get the name of the custom panel widget to use for the property. More...
virtual char * GetPanelWidget ()
virtual void SetDisableSubTrace (const char *)
 Set/Get the tracing of sub property of this property. More...
virtual char * GetDisableSubTrace ()
virtual char * GetXMLLabel ()
 The label assigned by the xml parser. More...
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual int GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
 The server manager configuration XML may define <Hints/> element for a property. More...
void Modified () override
 Overridden to support blocking of modified events. More...
static vtkSMProxyProperty * New ()
static vtkSMProxyProperty * SafeDownCast (vtkObject *o)
static void EnableProxyCreation ()
 When we load ProxyManager state we want Proxy/InputProperty to be able to create the corresponding missing proxy. More...
static void DisableProxyCreation ()
static bool CanCreateProxy ()
- Static Public Member Functions inherited from vtkSMProperty
static vtkSMProperty * New ()
static vtkSMProperty * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMProxyProperty ()
 ~vtkSMProxyProperty () override
void WriteTo (vtkSMMessage *msg) override
 Let the property write its content into the stream. More...
void ReadFrom (const vtkSMMessage *msg, int msg_offset, vtkSMProxyLocator *) override
 Let the property read and set its content from the stream. More...
int ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override
void SaveStateValues (vtkPVXMLElement *propertyElement) override
 Generic method used to generate XML state. More...
virtual vtkPVXMLElement * AddProxyElementState (vtkPVXMLElement *prop, unsigned int idx)
 Fill state property/proxy XML element with proxy info. More...
int LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override
 Updates state from an XML element. More...
void OnUpdateDataEvent ()
 Called when a producer fires the vtkCommand::UpdateDataEvent. More...
- Protected Member Functions inherited from vtkSMProperty
 vtkSMProperty ()
 ~vtkSMProperty () override
virtual void ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
 Internal. More...
void AddDependent (vtkSMDomain *dom)
 Internal. More...
void RemoveAllDependents ()
 Removes all dependents. More...
void UpdateDomains ()
 Calls Update() on all domains contained by the property as well as all dependent domains. More...
virtual void SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1)
 Save the property state in XML. More...
virtual void SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid)
 Save property domain. More...
virtual void SetInformationOnly (int)
virtual void SetIgnoreSynchronization (int)
void SetInformationProperty (vtkSMProperty *ip)
void SetDocumentation (vtkSMDocumentation *)
void SetParent (vtkSMProxy *proxy)
virtual void SetStateIgnored (bool)
virtual void StateIgnoredOn ()
virtual void StateIgnoredOff ()
bool SetBlockModifiedEvents (bool block)
 Block/unblock modified events, returns the current state of the block flag. More...
virtual bool GetPendingModifiedEvents ()
 Returns if any modified evetns are pending. More...
 vtkSMObject ()
 ~vtkSMObject () override
vtkPPInternals * PPInternals
- Protected Attributes inherited from vtkSMProperty
vtkPVXMLElement * Hints
char * Command
vtkSMPropertyInternals * PInternals
int ImmediateUpdate
int Animateable
int IsInternal
int NoCustomDefault
char * XMLName
char * XMLLabel
char * PanelVisibility
char * PanelVisibilityDefaultForRepresentation
char * PanelWidget
char * DisableSubTrace
vtkSMDomainIterator * DomainIterator
int InformationOnly
int IgnoreSynchronization
vtkSMInformationHelper * InformationHelper
vtkSMProperty * InformationProperty
int Repeatable
vtkWeakPointer< vtkSMProxy > Proxy
bool StateIgnored
vtkSMPropertyLink * Links
static bool CreateProxyAllowed
Friends
class vtkSMProxy
vtkSMProxyProperty is a concrete sub-class of vtkSMProperty representing pointer(s) to vtkObject(s) (through vtkSMProxy).
vtkSMProperty::UpdateDomains() is called by vtkSMProperty itself whenever its unchecked values are modified. In case of proxy-properties, the dependent domains typically tend to depend on the data information provided by the source-proxies added to the property. Thus, to ensure that the domains get updated if the data information changes, vtkSMProxyProperty ensures that vtkSMProperty::UpdateDomains() is called whenever any of the added proxies fires the vtkCommand::UpdateDataEvent (which is fired whenever the pipeline us updated through the ServerManager indicating that the data-information last used may have been invalidated).
Besides the standard set of attributes, the following XML attributes are supported:
Definition at line 57 of file vtkSMProxyProperty.h.
Definition at line 73 of file vtkSMProxyProperty.h.
◆ vtkSMProxyProperty()
vtkSMProxyProperty::vtkSMProxyProperty ( )
◆ ~vtkSMProxyProperty()
vtkSMProxyProperty::~vtkSMProxyProperty ( )
◆ EnableProxyCreation()
static void vtkSMProxyProperty::EnableProxyCreation ( )
Although when the goal is to load a state on any standard proxy, we do not want that proxy property be able to create new proxy based on some previous state.
◆ DisableProxyCreation()
static void vtkSMProxyProperty::DisableProxyCreation ( )
◆ CanCreateProxy()
static bool vtkSMProxyProperty::CanCreateProxy ( )
static vtkSMProxyProperty* vtkSMProxyProperty::New ( )
virtual const char* vtkSMProxyProperty::GetClassName ( )
Reimplemented from vtkSMProperty.
Reimplemented in vtkSMInputProperty.
static int vtkSMProxyProperty::IsTypeOf ( const char *  type)
virtual int vtkSMProxyProperty::IsA ( const char *  type)
static vtkSMProxyProperty* vtkSMProxyProperty::SafeDownCast ( vtkObject *  o)
void vtkSMProxyProperty::PrintSelf ( ostream &  os,
◆ AddProxy()
virtual void vtkSMProxyProperty::AddProxy ( vtkSMProxy *  proxy)
For SetProxy, the property automatically resizes to accommodate the index specified.
◆ SetProxy()
virtual void vtkSMProxyProperty::SetProxy ( unsigned int  idx,
vtkSMProxy *  proxy
◆ RemoveProxy()
virtual void vtkSMProxyProperty::RemoveProxy ( vtkSMProxy *  proxy)
◆ RemoveAllProxies()
virtual void vtkSMProxyProperty::RemoveAllProxies ( )
◆ SetProxies()
virtual void vtkSMProxyProperty::SetProxies ( unsigned int  numElements,
vtkSMProxy *  proxies[]
◆ IsProxyAdded()
bool vtkSMProxyProperty::IsProxyAdded ( vtkSMProxy *  proxy)
◆ AddUncheckedProxy()
virtual void vtkSMProxyProperty::AddUncheckedProxy ( vtkSMProxy *  proxy)
Does not modify the property. Unchecked proxies are used by domains when verifying whether a value is acceptable. To check if a value is in the domains, you can do the following:
* - RemoveAllUncheckedProxies()
* - AddUncheckedProxy(proxy)
* - IsInDomains()
◆ SetUncheckedProxy()
virtual void vtkSMProxyProperty::SetUncheckedProxy ( unsigned int  idx,
vtkSMProxy *  proxy
* - IsInDomains()
◆ RemoveAllUncheckedProxies()
virtual void vtkSMProxyProperty::RemoveAllUncheckedProxies ( )
◆ ClearUncheckedElements()
void vtkSMProxyProperty::ClearUncheckedElements ( )
inlineoverridevirtual
Definition at line 117 of file vtkSMProxyProperty.h.
◆ GetNumberOfProxies()
unsigned int vtkSMProxyProperty::GetNumberOfProxies ( )
◆ GetNumberOfUncheckedProxies()
unsigned int vtkSMProxyProperty::GetNumberOfUncheckedProxies ( )
◆ SetNumberOfProxies()
void vtkSMProxyProperty::SetNumberOfProxies ( unsigned int  count)
◆ SetNumberOfUncheckedProxies()
void vtkSMProxyProperty::SetNumberOfUncheckedProxies ( unsigned int  count)
◆ GetProxy()
vtkSMProxy* vtkSMProxyProperty::GetProxy ( unsigned int  idx)
Return a proxy.
No bounds check is performed.
◆ GetUncheckedProxy()
vtkSMProxy* vtkSMProxyProperty::GetUncheckedProxy ( unsigned int  idx)
Return a proxy.
◆ Copy()
void vtkSMProxyProperty::Copy ( vtkSMProperty *  src)
This method behaves differently for properties with vtkSMProxyListDomain and those without it. If the property has a vtkSMProxyListDomain, then the property is acting as an enumeration, giving user ability to pick one of the available proxies in the domain, hence a Copy request, will find an equivalent proxy on the target's domain and set that as the value of the target property.
◆ UpdateAllInputs()
void vtkSMProxyProperty::UpdateAllInputs ( )
◆ IsValueDefault()
bool vtkSMProxyProperty::IsValueDefault ( )
◆ ResetToXMLDefaults()
void vtkSMProxyProperty::ResetToXMLDefaults ( )
Simply clears the property.
◆ WriteTo()
void vtkSMProxyProperty::WriteTo ( vtkSMMessage *  msg)
overrideprotectedvirtual
◆ ReadFrom()
void vtkSMProxyProperty::ReadFrom ( const vtkSMMessage *  msg,
int  msg_offset,
vtkSMProxyLocator *
◆ ReadXMLAttributes()
int vtkSMProxyProperty::ReadXMLAttributes ( vtkSMProxy *  parent,
vtkPVXMLElement *  element
◆ SaveStateValues()
void vtkSMProxyProperty::SaveStateValues ( vtkPVXMLElement *  propertyElement)
◆ AddProxyElementState()
virtual vtkPVXMLElement* vtkSMProxyProperty::AddProxyElementState ( vtkPVXMLElement *  prop,
unsigned int  idx
protectedvirtual
Return the created proxy XML element that has been added as a child in the property definition. If prop == nullptr, you must Delete yourself the result otherwise prop is olding a reference to the proxy element
◆ LoadState()
int vtkSMProxyProperty::LoadState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  loader
Returns 0 on failure.
◆ OnUpdateDataEvent()
void vtkSMProxyProperty::OnUpdateDataEvent ( )
inlineprotected
We update all dependent domains since the data-information may have changed.
Definition at line 215 of file vtkSMProxyProperty.h.
◆ vtkSMProxy
friend class vtkSMProxy
friend
Definition at line 186 of file vtkSMProxyProperty.h.
◆ vtkPPInternals
friend class vtkPPInternals
friend
Definition at line 221 of file vtkSMProxyProperty.h.
◆ CreateProxyAllowed
bool vtkSMProxyProperty::CreateProxyAllowed
staticprotected
Definition at line 219 of file vtkSMProxyProperty.h.
◆ PPInternals
vtkPPInternals* vtkSMProxyProperty::PPInternals
Definition at line 223 of file vtkSMProxyProperty.h.
