vtkSMSpreadSheetViewProxy Class Reference
proxy for "SpreadSheetView" More...
#include <vtkSMSpreadSheetViewProxy.h>
Inheritance diagram for vtkSMSpreadSheetViewProxy:
Collaboration diagram for vtkSMSpreadSheetViewProxy:
typedef vtkSMViewProxy Superclass
- Public Types inherited from vtkSMViewProxy
enum  { PrepareContextForRendering = vtkCommand::UserEvent + 1 }
typedef vtkSMProxy Superclass
 Overridden to pass a unique identifier to vtkSpreadSheetView. More...
void RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility) override
 Overridden to update FieldAssociation property on the view to match the data type being shown. More...
- Public Member Functions inherited from vtkSMViewProxy
virtual void StillRender ()
 Renders the view using full resolution. More...
virtual void InteractiveRender ()
 Renders the view using lower resolution is possible. More...
virtual void Update ()
 Called vtkPVView::Update on the server-side. More...
virtual bool CanDisplayData (vtkSMSourceProxy *producer, int outputPort)
 Returns true if the view can display the data produced by the producer's port. More...
virtual vtkSMRepresentationProxy * CreateDefaultRepresentation (vtkSMProxy *, int)
 Create a default representation for the given source proxy. More...
virtual const char * GetRepresentationType (vtkSMSourceProxy *producer, int outputPort)
 Returns the xml name of the representation proxy to create to show the data produced in this view, if any. More...
virtual vtkSMRepresentationProxy * FindRepresentation (vtkSMSourceProxy *producer, int outputPort)
 Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * GetClientSideView ()
 Returns the client-side vtkView, if any. More...
int WriteImage (const char *filename, const char *writerName, int magnification=1)
 Saves a screenshot of the view to disk. More...
int WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY)
virtual bool HasDirtyRepresentation ()
 Return true any internal representation is dirty. More...
virtual vtkRenderWindow * GetRenderWindow ()
 Return the vtkRenderWindow used by this view, if any. More...
virtual vtkRenderWindowInteractor * GetInteractor ()
 Returns the interactor. More...
virtual void SetupInteractor (vtkRenderWindowInteractor *iren)
 A client process need to set the interactor to enable interactivity. More...
virtual bool MakeRenderWindowInteractor (bool quiet=false)
 Creates a default render window interactor for the vtkRenderWindow and sets it up on the local process if the local process supports interaction. More...
virtual void SetEnable (bool)
 Enable/Disable a view. More...
virtual bool GetEnable ()
virtual void EnableOn ()
virtual void EnableOff ()
vtkImageData * CaptureWindow (int magnification)
 Captures a image from this view. More...
vtkImageData * CaptureWindow (int magnificationX, int magnificationY)
 Returns true if the subsequent call to Update() will result in an actual update. More...
virtual bool HideOtherRepresentationsIfNeeded (vtkSMProxy *repr)
 Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMSpreadSheetViewProxy * New ()
static vtkSMSpreadSheetViewProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMViewProxy
static vtkSMViewProxy * New ()
static vtkSMViewProxy * SafeDownCast (vtkObject *o)
static vtkSMViewProxy * FindView (vtkSMProxy *repr, const char *reggroup="views")
 Helper method to locate a view to which the representation has been added. More...
static void SetTransparentBackground (bool val)
 Sets whether screenshots have a transparent background. More...
static bool GetTransparentBackground ()
static bool HideOtherRepresentationsIfNeeded (vtkSMViewProxy *self, vtkSMProxy *repr)
static void RepresentationVisibilityChanged (vtkSMViewProxy *self, vtkSMProxy *repr, bool new_visibility)
 Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMSpreadSheetViewProxy ()
 ~vtkSMSpreadSheetViewProxy () override
- Protected Member Functions inherited from vtkSMViewProxy
 vtkSMViewProxy ()
 ~vtkSMViewProxy () override
virtual vtkImageData * CaptureWindowInternal (int magnificationX, int magnificationY)
 Capture an image from the view's render window. More...
virtual void RenderForImageCapture ()
 This method is called whenever the view wants to render to during image capture. More...
virtual vtkTypeUInt32 PreRender (bool vtkNotUsed(interactive))
 This method is called before executing code that could cause a render on the underlying vtkPVView. More...
virtual void PostRender (bool vtkNotUsed(interactive))
virtual bool IsContextReadyForRendering ()
 Subclasses should override this method and return false if the rendering context is not ready for rendering at this moment. More...
 Called at the end of CreateVTKObjects(). More...
bool GetLocalProcessSupportsInteraction ()
 Convenience method to call vtkPVView::SafeDownCast(this->GetClientSideObject())->GetLocalProcessSupportsInteraction();. More...
virtual vtkSMDataDeliveryManagerProxy * GetDeliveryManager ()
 Provides access to the delivery manager proxy, if any. More...
virtual void SetDefaultRepresentationName (const char *)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMViewProxy
char * DefaultRepresentationName
bool Enable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMSpreadSheetRepresentationProxy extends vtkSMViewProxy to override a few methods that add extra logic specific to this view. Namely, we override RepresentationVisibilityChanged to ensure that the view picks a default attribute type suitable for the visible representation.
Definition at line 19 of file vtkSMSpreadSheetViewProxy.h.
Definition at line 23 of file vtkSMSpreadSheetViewProxy.h.
◆ vtkSMSpreadSheetViewProxy()
vtkSMSpreadSheetViewProxy::vtkSMSpreadSheetViewProxy ( )
◆ ~vtkSMSpreadSheetViewProxy()
vtkSMSpreadSheetViewProxy::~vtkSMSpreadSheetViewProxy ( )
static vtkSMSpreadSheetViewProxy* vtkSMSpreadSheetViewProxy::New ( )
virtual const char* vtkSMSpreadSheetViewProxy::GetClassName ( )
Reimplemented from vtkSMViewProxy.
static int vtkSMSpreadSheetViewProxy::IsTypeOf ( const char *  type)
virtual int vtkSMSpreadSheetViewProxy::IsA ( const char *  type)
static vtkSMSpreadSheetViewProxy* vtkSMSpreadSheetViewProxy::SafeDownCast ( vtkObject *  o)
void vtkSMSpreadSheetViewProxy::PrintSelf ( ostream &  os,
◆ CreateVTKObjects()
void vtkSMSpreadSheetViewProxy::CreateVTKObjects ( )
◆ RepresentationVisibilityChanged()
void vtkSMSpreadSheetViewProxy::RepresentationVisibilityChanged ( vtkSMProxy *  repr,
bool  new_visibility
