vtkSMRemoteObject Class Reference
baseclass for all proxy-objects that have counter parts on server as well as client processes. More...
#include <vtkSMRemoteObject.h>
Inheritance diagram for vtkSMRemoteObject:
Collaboration diagram for vtkSMRemoteObject:
bool HasGlobalID ()
virtual const vtkSMMessage * GetFullState ()
virtual void EnableLocalPushOnly ()
virtual void DisableLocalPushOnly ()
virtual void SetLocation (vtkTypeUInt32)
virtual void PrototypeOn ()
virtual void PrototypeOff ()
bool IsPrototype ()
virtual void SetPrototype (bool)
virtual void LoadState (const vtkSMMessage *msg, vtkSMProxyLocator *locator)
static vtkSMObject * New ()
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Friends
class vtkSMStateHelper
class vtkSMStateLoader
Abstract class involved in ServerManager class hierarchy that has a corresponding SIObject which can be local or remote.
Definition at line 25 of file vtkSMRemoteObject.h.
Definition at line 32 of file vtkSMRemoteObject.h.
◆ vtkSMRemoteObject()
vtkSMRemoteObject::vtkSMRemoteObject ( )
◆ ~vtkSMRemoteObject()
vtkSMRemoteObject::~vtkSMRemoteObject ( )
Destructor.
virtual const char* vtkSMRemoteObject::GetClassName ( )
Reimplemented from vtkSMSessionObject.
Reimplemented in vtkSMProxy, vtkSMMultiplexerSourceProxy, vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMCollaborationManager, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMLoadStateOptionsProxy, vtkSMOutputPort, vtkSMPVRepresentationProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMCompoundSourceProxy, vtkSMSelfGeneratingSourceProxy, vtkSMSaveScreenshotProxy, vtkSMTransferFunction2DProxy, vtkSMDataDeliveryManagerProxy, vtkSMPipelineState, vtkSMProxySelectionModel, vtkSMRenderViewProxy, vtkSMSaveAnimationProxy, vtkSMImporterProxy, vtkSMContextViewProxy, vtkSMNewWidgetRepresentationProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMSaveAnimationExtractsProxy, vtkSMLiveInsituLinkProxy, vtkSMNewWidgetRepresentationProxyAbstract, vtkSMTransferFunctionProxy, vtkSMProxyDefinitionManager, vtkSMProxyLink, vtkSMComparativeViewProxy, vtkSMLink, vtkSMPlotlyJsonExtractWriterProxy, vtkSMRecolorableImageExtractWriterProxy, vtkSMViewLink, vtkSMPythonViewProxy, vtkSMVRInteractorStyleProxy, vtkSMVRStylusStyleProxy, vtkSMExtractTriggerProxy, vtkSMCameraLink, vtkSMComparativeAnimationCueProxy, vtkSMVRPythonInteractorStyleProxy, vtkPVRepresentationAnimationHelper, vtkSMCSVExporterProxy, vtkSMExporterProxy, vtkSMDataSourceProxy, vtkSMPropertyLink, vtkSMImageExtractWriterProxy, vtkSMNew2DWidgetRepresentationProxy, vtkSMSelectionLink, vtkSMVRMovePointStyleProxy, vtkSMMultiServerSourceProxy, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMVRGrabPointStyleProxy, vtkSMVRGrabTransformStyleProxy, vtkSMVRGrabWorldStyleProxy, vtkSMVRResetTransformStyleProxy, vtkSMVRSkeletonStyleProxy, vtkSMVRSpaceNavigatorGrabWorldStyleProxy, vtkSMVRTrackStyleProxy, vtkSMVRVirtualHandStyleProxy, vtkSMDirectoryProxy, vtkSMPWriterProxy, vtkSMContextItemWidgetProxy, vtkSMMaterialLibraryProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMRenderViewExporterProxy, vtkSMExtractWriterProxy, vtkSMPluginLoaderProxy, vtkSMPSWriterProxy, vtkSMDisplaySizedImplicitPlaneRepresentationProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMultiSliceViewProxy, vtkSMAnimationSceneProxy, vtkSMEnsembleDataReaderProxy, vtkSMDataExtractWriterProxy, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMGL2PSExporterProxy, vtkSMNullProxy, vtkSMTimeKeeperProxy, vtkSMVRControlSlicePositionStyleProxy, vtkSMOrthographicSliceViewProxy, and vtkSMVRControlSliceOrientationStyleProxy.
static int vtkSMRemoteObject::IsTypeOf ( const char *  type)
virtual int vtkSMRemoteObject::IsA ( const char *  type)
static vtkSMRemoteObject* vtkSMRemoteObject::SafeDownCast ( vtkObject *  o)
void vtkSMRemoteObject::PrintSelf ( ostream &  os,
◆ SetLocation()
virtual void vtkSMRemoteObject::SetLocation ( vtkTypeUInt32  )
Get/Set the location where the underlying VTK-objects are created.
The value can be constructed by or-ing vtkSMSession::ServerFlags
Reimplemented in vtkSMProxy.
◆ GetLocation()
virtual vtkTypeUInt32 vtkSMRemoteObject::GetLocation ( )
◆ SetSession()
void vtkSMRemoteObject::SetSession ( vtkSMSession *  )
Override the SetSession so if the object already have an ID we automatically register it to the associated session.
◆ GetGlobalID()
virtual vtkTypeUInt32 vtkSMRemoteObject::GetGlobalID ( )
Get the global unique id for this object.
If none is set and the session is valid, a new global id will be assigned automatically.
Reimplemented in vtkSMSourceProxy, vtkSMRepresentationProxy, and vtkSMCollaborationManager.
◆ GetGlobalIDAsString()
const char* vtkSMRemoteObject::GetGlobalIDAsString ( )
◆ HasGlobalID()
bool vtkSMRemoteObject::HasGlobalID ( )
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it.
◆ PrototypeOn()
virtual void vtkSMRemoteObject::PrototypeOn ( )
Allow user to set the remote object to be discard for Undo/Redo action.
By default, any remote object is Undoable.
◆ PrototypeOff()
virtual void vtkSMRemoteObject::PrototypeOff ( )
◆ IsPrototype()
bool vtkSMRemoteObject::IsPrototype ( )
inline
Definition at line 71 of file vtkSMRemoteObject.h.
◆ SetPrototype()
virtual void vtkSMRemoteObject::SetPrototype ( bool  )
◆ GetFullState()
virtual const vtkSMMessage* vtkSMRemoteObject::GetFullState ( )
inlinevirtual
This method return the full object state that can be used to create that object from scratch.
This method will be used to fill the undo stack. If not overridden this will return nullptr.
Reimplemented in vtkSMProxy, vtkSMCollaborationManager, vtkSMProxySelectionModel, vtkSMLink, and vtkSMPipelineState.
Definition at line 81 of file vtkSMRemoteObject.h.
◆ LoadState()
virtual void vtkSMRemoteObject::LoadState ( const vtkSMMessage *  msg,
vtkSMProxyLocator *  locator
inlinevirtual
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented in vtkSMProxy, vtkSMViewLayoutProxy, vtkSMProxyDefinitionManager, vtkSMCollaborationManager, vtkSMMultiplexerSourceProxy, vtkSMProxySelectionModel, vtkSMProxyLink, vtkSMPropertyLink, vtkSMLink, vtkSMCameraLink, vtkSMSelectionLink, vtkSMLiveInsituLinkProxy, vtkSMMultiServerSourceProxy, and vtkSMPipelineState.
Definition at line 91 of file vtkSMRemoteObject.h.
◆ EnableLocalPushOnly()
virtual void vtkSMRemoteObject::EnableLocalPushOnly ( )
Allow to switch off any push of state change to the server for that particular object.
This is used when we load a state based on a server notification. In that particular case, the server is already aware of that new state, so we keep those changes local.
◆ DisableLocalPushOnly()
virtual void vtkSMRemoteObject::DisableLocalPushOnly ( )
Enable the given remote object to communicate its state normally to the server location.
◆ IsLocalPushOnly()
virtual bool vtkSMRemoteObject::IsLocalPushOnly ( )
inlinevirtual
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast.
Definition at line 117 of file vtkSMRemoteObject.h.
◆ PushState()
void vtkSMRemoteObject::PushState ( vtkSMMessage *  msg)
Subclasses can call this method to send a message to its state object on the server processes specified.
◆ PullState()
bool vtkSMRemoteObject::PullState ( vtkSMMessage *  msg)
Subclasses can call this method to pull the state from the state-object on the server processes specified.
Returns true on successful fetch. The message is updated with the fetched state.
◆ SetGlobalID()
void vtkSMRemoteObject::SetGlobalID ( vtkTypeUInt32  guid)
Set the GlobalUniqueId.
◆ GetFilteredLocation()
vtkTypeUInt32 vtkSMRemoteObject::GetFilteredLocation ( )
◆ vtkSMStateHelper
friend class vtkSMStateHelper
friend
Definition at line 28 of file vtkSMRemoteObject.h.
◆ vtkSMStateLoader
friend class vtkSMStateLoader
friend
Definition at line 29 of file vtkSMRemoteObject.h.
◆ GlobalID
vtkTypeUInt32 vtkSMRemoteObject::GlobalID
Definition at line 153 of file vtkSMRemoteObject.h.
◆ Location
vtkTypeUInt32 vtkSMRemoteObject::Location
Definition at line 157 of file vtkSMRemoteObject.h.
◆ Prototype
bool vtkSMRemoteObject::Prototype
Definition at line 161 of file vtkSMRemoteObject.h.
◆ ClientOnlyLocationFlag
bool vtkSMRemoteObject::ClientOnlyLocationFlag
Definition at line 164 of file vtkSMRemoteObject.h.
