vtkPVRepresentationAnimationHelper Class Reference
helper proxy used to animate properties on the representations for any source. More...
#include <vtkPVRepresentationAnimationHelper.h>
Inheritance diagram for vtkPVRepresentationAnimationHelper:
Collaboration diagram for vtkPVRepresentationAnimationHelper:
typedef vtkSMProxy Superclass
void SetVisibility (int)
 Don't use directly. More...
void SetOpacity (double)
void SetSourceProxy (vtkSMProxy *proxy)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkPVRepresentationAnimationHelper * New ()
static vtkPVRepresentationAnimationHelper * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkPVRepresentationAnimationHelper ()
 ~vtkPVRepresentationAnimationHelper () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkWeakPointer< vtkSMProxy > SourceProxy
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkPVRepresentationAnimationHelper is helper proxy used to animate properties on the representations for any source. This makes is possible to set up an animation cue that will affect properties on all representations for a source without directly referring to the representation proxies.
Definition at line 21 of file vtkPVRepresentationAnimationHelper.h.
Definition at line 25 of file vtkPVRepresentationAnimationHelper.h.
◆ vtkPVRepresentationAnimationHelper()
vtkPVRepresentationAnimationHelper::vtkPVRepresentationAnimationHelper ( )
◆ ~vtkPVRepresentationAnimationHelper()
vtkPVRepresentationAnimationHelper::~vtkPVRepresentationAnimationHelper ( )
static vtkPVRepresentationAnimationHelper* vtkPVRepresentationAnimationHelper::New ( )
virtual const char* vtkPVRepresentationAnimationHelper::GetClassName ( )
static int vtkPVRepresentationAnimationHelper::IsTypeOf ( const char *  type)
virtual int vtkPVRepresentationAnimationHelper::IsA ( const char *  type)
static vtkPVRepresentationAnimationHelper* vtkPVRepresentationAnimationHelper::SafeDownCast ( vtkObject *  o)
void vtkPVRepresentationAnimationHelper::PrintSelf ( ostream &  os,
◆ SetVisibility()
void vtkPVRepresentationAnimationHelper::SetVisibility ( int  )
Don't use directly.
Use the corresponding properties instead.
◆ SetOpacity()
void vtkPVRepresentationAnimationHelper::SetOpacity ( double  )
Don't use directly.
◆ SetSourceProxy()
void vtkPVRepresentationAnimationHelper::SetSourceProxy ( vtkSMProxy *  proxy)
Don't use directly.
◆ SourceProxy
vtkWeakPointer<vtkSMProxy> vtkPVRepresentationAnimationHelper::SourceProxy
Definition at line 41 of file vtkPVRepresentationAnimationHelper.h.
