vtkSMVRStylusStyleProxy Class Reference
an interaction style to control translation and rotation with a stylus More...
#include <vtkSMVRStylusStyleProxy.h>
Inheritance diagram for vtkSMVRStylusStyleProxy:
Collaboration diagram for vtkSMVRStylusStyleProxy:
typedef vtkSMVRTrackStyleProxy Superclass
- Public Types inherited from vtkSMVRTrackStyleProxy
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 }
typedef vtkSMProxy Superclass
- Public Member Functions inherited from vtkSMVRTrackStyleProxy
int GetControlledPropertySize () override
virtual vtkSMProxy * GetControlledProxy ()
virtual bool Update ()
int GetNumberOfButtonRoles ()
std::string GetValuatorRole (const std::string &name)
void ClearAllRoles ()
virtual vtkPVXMLElement * SaveConfiguration ()
 Save state to xml. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRStylusStyleProxy * New ()
static vtkSMVRStylusStyleProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMVRTrackStyleProxy
static vtkSMVRTrackStyleProxy * New ()
static vtkSMVRTrackStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMVRStylusStyleProxy ()
 ~vtkSMVRStylusStyleProxy () override=default
void HandleButton (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
- Protected Member Functions inherited from vtkSMVRTrackStyleProxy
 vtkSMVRTrackStyleProxy ()
 ~vtkSMVRTrackStyleProxy () override
virtual void HandleValuator (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool EnableTranslate
bool EnableRotate
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
- Protected Types inherited from vtkSMVRInteractorStyleProxy
typedef std::map< std::string, std::string > StringMap
static std::vector< std::string > Tokenize (std::string input)
vtkSMVRStylusStyleProxy is an interaction style that uses the position of the stylus in screen space (for example the stylus of the zSpace) to modify a 4x4 matrix. Only the location of the stylus is used, the rotation has no effect. Only works with RenderView proxy.
Definition at line 21 of file vtkSMVRStylusStyleProxy.h.
Definition at line 26 of file vtkSMVRStylusStyleProxy.h.
◆ vtkSMVRStylusStyleProxy()
vtkSMVRStylusStyleProxy::vtkSMVRStylusStyleProxy ( )
◆ ~vtkSMVRStylusStyleProxy()
vtkSMVRStylusStyleProxy::~vtkSMVRStylusStyleProxy ( )
overrideprotecteddefault
static vtkSMVRStylusStyleProxy* vtkSMVRStylusStyleProxy::New ( )
virtual const char* vtkSMVRStylusStyleProxy::GetClassName ( )
Reimplemented from vtkSMVRTrackStyleProxy.
static int vtkSMVRStylusStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRStylusStyleProxy::IsA ( const char *  type)
static vtkSMVRStylusStyleProxy* vtkSMVRStylusStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRStylusStyleProxy::PrintSelf ( ostream &  os,
◆ HandleButton()
void vtkSMVRStylusStyleProxy::HandleButton ( const vtkVREvent &  event)
overrideprotectedvirtual
◆ HandleTracker()
void vtkSMVRStylusStyleProxy::HandleTracker ( const vtkVREvent &  event)
◆ EnableTranslate
bool vtkSMVRStylusStyleProxy::EnableTranslate
Definition at line 36 of file vtkSMVRStylusStyleProxy.h.
◆ EnableRotate
bool vtkSMVRStylusStyleProxy::EnableRotate
Definition at line 37 of file vtkSMVRStylusStyleProxy.h.
