vtkSMCinemaVolumetricImageExtractWriterProxy Class Reference
image extractor for cinema-volumetric extracts More...
#include <vtkSMCinemaVolumetricImageExtractWriterProxy.h>
Inheritance diagram for vtkSMCinemaVolumetricImageExtractWriterProxy:
Collaboration diagram for vtkSMCinemaVolumetricImageExtractWriterProxy:
typedef vtkSMImageExtractWriterProxy Superclass
- Public Types inherited from vtkSMImageExtractWriterProxy
enum  CameraMode { Static = 0, PhiTheta = 1 }
typedef vtkSMExtractWriterProxy Superclass
- Public Types inherited from vtkSMExtractWriterProxy
typedef vtkSMProxy Superclass
- Public Member Functions inherited from vtkSMImageExtractWriterProxy
bool Write (vtkSMExtractsController *extractor) override
 Implementation for vtkSMExtractWriterProxy API. More...
bool CanExtract (vtkSMProxy *proxy) override
bool IsExtracting (vtkSMProxy *proxy) override
void SetInput (vtkSMProxy *proxy) override
vtkSMProxy * GetInput () override
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMCinemaVolumetricImageExtractWriterProxy * New ()
static vtkSMCinemaVolumetricImageExtractWriterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMImageExtractWriterProxy
static vtkSMImageExtractWriterProxy * New ()
static vtkSMImageExtractWriterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExtractWriterProxy
static vtkSMExtractWriterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMCinemaVolumetricImageExtractWriterProxy ()
 ~vtkSMCinemaVolumetricImageExtractWriterProxy () override
bool WriteInternal (vtkSMExtractsController *extractor, const SummaryParametersT &params=SummaryParametersT{}) override
 Called in Write(). More...
const char * GetShortName (const std::string &key) const override
 Used to convert a parameter name used in the SummaryParametersT to a shorter version suitable for use in filename. More...
- Protected Member Functions inherited from vtkSMImageExtractWriterProxy
 vtkSMImageExtractWriterProxy ()
 ~vtkSMImageExtractWriterProxy () override
bool WriteImage (vtkSMExtractsController *extractor, const SummaryParametersT &cameraParams=SummaryParametersT{})
 Save a single image. More...
- Protected Member Functions inherited from vtkSMExtractWriterProxy
 vtkSMExtractWriterProxy ()
 ~vtkSMExtractWriterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Types inherited from vtkSMImageExtractWriterProxy
using SummaryParametersT = vtkSMExtractsController::SummaryParametersT
- Static Protected Member Functions inherited from vtkSMExtractWriterProxy
static std::string GenerateExtractsFileName (const std::string &filename, const char *outDir)
 Adds the output directory to the filename, replaces, in case of need, the old string format, and returns the formatted string using vtkPVStringFormatter. More...
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMCinemaVolumetricImageExtractWriterProxy subclasses vtkSMImageExtractWriterProxy to add ability to export transfer functions for volumetric renderings.
Note
This is an experimental feature and may change without notice.
Definition at line 19 of file vtkSMCinemaVolumetricImageExtractWriterProxy.h.
◆ vtkSMCinemaVolumetricImageExtractWriterProxy()
vtkSMCinemaVolumetricImageExtractWriterProxy::vtkSMCinemaVolumetricImageExtractWriterProxy ( )
◆ ~vtkSMCinemaVolumetricImageExtractWriterProxy()
vtkSMCinemaVolumetricImageExtractWriterProxy::~vtkSMCinemaVolumetricImageExtractWriterProxy ( )
static vtkSMCinemaVolumetricImageExtractWriterProxy* vtkSMCinemaVolumetricImageExtractWriterProxy::New ( )
virtual const char* vtkSMCinemaVolumetricImageExtractWriterProxy::GetClassName ( )
Reimplemented from vtkSMImageExtractWriterProxy.
static int vtkSMCinemaVolumetricImageExtractWriterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMCinemaVolumetricImageExtractWriterProxy::IsA ( const char *  type)
static vtkSMCinemaVolumetricImageExtractWriterProxy* vtkSMCinemaVolumetricImageExtractWriterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMCinemaVolumetricImageExtractWriterProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSMExtractWriterProxy.
◆ WriteInternal()
bool vtkSMCinemaVolumetricImageExtractWriterProxy::WriteInternal ( vtkSMExtractsController *  extractor,
const SummaryParametersT &  params = SummaryParametersT{}
overrideprotectedvirtual
Called in Write().
Intended for subclasses to override to customize image generation
◆ GetShortName()
const char* vtkSMCinemaVolumetricImageExtractWriterProxy::GetShortName ( const std::string &  key) const
