vtkSMComparativeViewProxy Class Reference
view for comparative visualization/ film-strips. More...
#include <vtkSMComparativeViewProxy.h>
Inheritance diagram for vtkSMComparativeViewProxy:
Collaboration diagram for vtkSMComparativeViewProxy:
typedef vtkSMViewProxy Superclass
- Public Types inherited from vtkSMViewProxy
enum  { PrepareContextForRendering = vtkCommand::UserEvent + 1 }
typedef vtkSMProxy Superclass
void Update () override
 Updates the data pipelines for all visible representations. More...
void GetViews (vtkCollection *collection)
 Get all the internal views. More...
vtkSMViewProxy * GetRootView ()
 Returns the root view proxy. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
const char * GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) override
 Overridden to forward the call to the internal root view proxy. More...
vtkRenderWindow * GetRenderWindow () override
 Returns the render-window used by the root view, if any. More...
vtkRenderWindowInteractor * GetInteractor () override
 Returns the interactor. More...
void SetupInteractor (vtkRenderWindowInteractor *iren) override
 To avoid misuse of this method for comparative views, this method will raise an error. More...
bool MakeRenderWindowInteractor (bool quiet=false) override
 Overridden to call MakeRenderWindowInteractor() on each of the internal views. More...
- Public Member Functions inherited from vtkSMViewProxy
virtual void StillRender ()
 Renders the view using full resolution. More...
virtual void InteractiveRender ()
 Renders the view using lower resolution is possible. More...
virtual bool CanDisplayData (vtkSMSourceProxy *producer, int outputPort)
 Returns true if the view can display the data produced by the producer's port. More...
virtual vtkSMRepresentationProxy * CreateDefaultRepresentation (vtkSMProxy *, int)
 Create a default representation for the given source proxy. More...
virtual vtkSMRepresentationProxy * FindRepresentation (vtkSMSourceProxy *producer, int outputPort)
 Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * GetClientSideView ()
 Returns the client-side vtkView, if any. More...
int WriteImage (const char *filename, const char *writerName, int magnification=1)
 Saves a screenshot of the view to disk. More...
int WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY)
virtual bool HasDirtyRepresentation ()
 Return true any internal representation is dirty. More...
virtual void SetEnable (bool)
 Enable/Disable a view. More...
virtual bool GetEnable ()
virtual void EnableOn ()
virtual void EnableOff ()
vtkImageData * CaptureWindow (int magnification)
 Captures a image from this view. More...
vtkImageData * CaptureWindow (int magnificationX, int magnificationY)
 Returns true if the subsequent call to Update() will result in an actual update. More...
virtual bool HideOtherRepresentationsIfNeeded (vtkSMProxy *repr)
 Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
virtual void RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility)
 Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMComparativeViewProxy * New ()
static vtkSMComparativeViewProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMViewProxy
static vtkSMViewProxy * New ()
static vtkSMViewProxy * SafeDownCast (vtkObject *o)
static vtkSMViewProxy * FindView (vtkSMProxy *repr, const char *reggroup="views")
 Helper method to locate a view to which the representation has been added. More...
static void SetTransparentBackground (bool val)
 Sets whether screenshots have a transparent background. More...
static bool GetTransparentBackground ()
static bool HideOtherRepresentationsIfNeeded (vtkSMViewProxy *self, vtkSMProxy *repr)
static void RepresentationVisibilityChanged (vtkSMViewProxy *self, vtkSMProxy *repr, bool new_visibility)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMComparativeViewProxy ()
 ~vtkSMComparativeViewProxy () override
vtkImageData * CaptureWindowInternal (int magX, int magY) override
 Overridden to do the capturing of images from each of the internal views and then stitching them together. More...
void InvokeConfigureEvent ()
- Protected Member Functions inherited from vtkSMViewProxy
 vtkSMViewProxy ()
 ~vtkSMViewProxy () override
virtual void RenderForImageCapture ()
 This method is called whenever the view wants to render to during image capture. More...
virtual vtkTypeUInt32 PreRender (bool vtkNotUsed(interactive))
 This method is called before executing code that could cause a render on the underlying vtkPVView. More...
virtual void PostRender (bool vtkNotUsed(interactive))
virtual bool IsContextReadyForRendering ()
 Subclasses should override this method and return false if the rendering context is not ready for rendering at this moment. More...
 Called at the end of CreateVTKObjects(). More...
bool GetLocalProcessSupportsInteraction ()
 Convenience method to call vtkPVView::SafeDownCast(this->GetClientSideObject())->GetLocalProcessSupportsInteraction();. More...
virtual vtkSMDataDeliveryManagerProxy * GetDeliveryManager ()
 Provides access to the delivery manager proxy, if any. More...
virtual void SetDefaultRepresentationName (const char *)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMViewProxy
char * DefaultRepresentationName
bool Enable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMComparativeViewProxy is the view used to generate/view comparative visualizations/film-strips. vtkSMComparativeViewProxy works together with vtkPVComparativeView – the vtk-object for which this represents the proxy. vtkPVComparativeView is a client-side VTK object which literally uses the view and representation proxies to simulate the comparative view. Refer to vtkPVComparativeView for details.
Definition at line 24 of file vtkSMComparativeViewProxy.h.
Definition at line 28 of file vtkSMComparativeViewProxy.h.
◆ vtkSMComparativeViewProxy()
vtkSMComparativeViewProxy::vtkSMComparativeViewProxy ( )
◆ ~vtkSMComparativeViewProxy()
vtkSMComparativeViewProxy::~vtkSMComparativeViewProxy ( )
static vtkSMComparativeViewProxy* vtkSMComparativeViewProxy::New ( )
virtual const char* vtkSMComparativeViewProxy::GetClassName ( )
Reimplemented from vtkSMViewProxy.
static int vtkSMComparativeViewProxy::IsTypeOf ( const char *  type)
virtual int vtkSMComparativeViewProxy::IsA ( const char *  type)
static vtkSMComparativeViewProxy* vtkSMComparativeViewProxy::SafeDownCast ( vtkObject *  o)
void vtkSMComparativeViewProxy::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMComparativeViewProxy::Update ( )
◆ GetViews()
void vtkSMComparativeViewProxy::GetViews ( vtkCollection *  collection)
The views should only be used to be laid out by the GUI. It's not recommended to directly change the properties of the views.
◆ GetRootView()
vtkSMViewProxy* vtkSMComparativeViewProxy::GetRootView ( )
◆ MarkDirty()
void vtkSMComparativeViewProxy::MarkDirty ( vtkSMProxy *  modifiedProxy)
Dirty means this algorithm will execute during next update.
This all marks all consumers as dirty.
◆ GetRepresentationType()
const char* vtkSMComparativeViewProxy::GetRepresentationType ( vtkSMSourceProxy *  producer,
int  outputPort
◆ GetRenderWindow()
vtkRenderWindow* vtkSMComparativeViewProxy::GetRenderWindow ( )
inlineoverridevirtual
Definition at line 62 of file vtkSMComparativeViewProxy.h.
◆ GetInteractor()
vtkRenderWindowInteractor* vtkSMComparativeViewProxy::GetInteractor ( )
Note, that views may not use vtkRenderWindow at all in which case they will not have any interactor and will return nullptr. Default implementation returns nullptr.
Definition at line 66 of file vtkSMComparativeViewProxy.h.
◆ SetupInteractor()
void vtkSMComparativeViewProxy::SetupInteractor ( vtkRenderWindowInteractor *  iren)
Client code should set up interactor for each of the internal views explicitly.
◆ MakeRenderWindowInteractor()
bool vtkSMComparativeViewProxy::MakeRenderWindowInteractor ( bool  quiet = false)
◆ CaptureWindowInternal()
vtkImageData* vtkSMComparativeViewProxy::CaptureWindowInternal ( int  magX,
int  magY
overrideprotectedvirtual
◆ InvokeConfigureEvent()
void vtkSMComparativeViewProxy::InvokeConfigureEvent ( )
◆ CreateVTKObjects()
void vtkSMComparativeViewProxy::CreateVTKObjects ( )
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
