vtkSMDataExtractWriterProxy Class Reference
extract writers to write datasets More...
#include <vtkSMDataExtractWriterProxy.h>
Inheritance diagram for vtkSMDataExtractWriterProxy:
Collaboration diagram for vtkSMDataExtractWriterProxy:
typedef vtkSMExtractWriterProxy Superclass
- Public Types inherited from vtkSMExtractWriterProxy
typedef vtkSMProxy Superclass
bool Write (vtkSMExtractsController *extractor) override
 Implementation for vtkSMExtractWriterProxy API. More...
bool CanExtract (vtkSMProxy *proxy) override
bool IsExtracting (vtkSMProxy *proxy) override
void SetInput (vtkSMProxy *proxy) override
vtkSMProxy * GetInput () override
- Public Member Functions inherited from vtkSMExtractWriterProxy
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMDataExtractWriterProxy * New ()
static vtkSMDataExtractWriterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExtractWriterProxy
static vtkSMExtractWriterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMDataExtractWriterProxy ()
 ~vtkSMDataExtractWriterProxy () override
- Protected Member Functions inherited from vtkSMExtractWriterProxy
 vtkSMExtractWriterProxy ()
 ~vtkSMExtractWriterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Static Protected Member Functions inherited from vtkSMExtractWriterProxy
static std::string GenerateExtractsFileName (const std::string &filename, const char *outDir)
 Adds the output directory to the filename, replaces, in case of need, the old string format, and returns the formatted string using vtkPVStringFormatter. More...
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMDataExtractWriterProxy is an extract writer intended to write extracts using ParaView writer proxies. The actual writer to use is defined a "Writer" subproxy.
Definition at line 17 of file vtkSMDataExtractWriterProxy.h.
Definition at line 21 of file vtkSMDataExtractWriterProxy.h.
◆ vtkSMDataExtractWriterProxy()
vtkSMDataExtractWriterProxy::vtkSMDataExtractWriterProxy ( )
◆ ~vtkSMDataExtractWriterProxy()
vtkSMDataExtractWriterProxy::~vtkSMDataExtractWriterProxy ( )
static vtkSMDataExtractWriterProxy* vtkSMDataExtractWriterProxy::New ( )
virtual const char* vtkSMDataExtractWriterProxy::GetClassName ( )
Reimplemented from vtkSMExtractWriterProxy.
static int vtkSMDataExtractWriterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMDataExtractWriterProxy::IsA ( const char *  type)
static vtkSMDataExtractWriterProxy* vtkSMDataExtractWriterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMDataExtractWriterProxy::PrintSelf ( ostream &  os,
◆ Write()
bool vtkSMDataExtractWriterProxy::Write ( vtkSMExtractsController *  extractor)
Implements vtkSMExtractWriterProxy.
◆ CanExtract()
bool vtkSMDataExtractWriterProxy::CanExtract ( vtkSMProxy *  proxy)
◆ IsExtracting()
bool vtkSMDataExtractWriterProxy::IsExtracting ( vtkSMProxy *  proxy)
◆ SetInput()
void vtkSMDataExtractWriterProxy::SetInput ( vtkSMProxy *  proxy)
◆ GetInput()
vtkSMProxy* vtkSMDataExtractWriterProxy::GetInput ( )
