vtkSMOutputPort Class Reference
reference for an output port of a vtkAlgorithm. More...
#include <vtkSMOutputPort.h>
Inheritance diagram for vtkSMOutputPort:
Collaboration diagram for vtkSMOutputPort:
typedef vtkSMProxy Superclass
virtual vtkPVDataInformation * GetDataInformation ()
 Returns data information. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual vtkPVTemporalDataInformation * GetTemporalDataInformation ()
 Returns data information collected over all timesteps provided by the pipeline. More...
virtual const char * GetDataClassName ()
 Returns the classname of the data object on this output port. More...
virtual vtkPVClassNameInformation * GetClassNameInformation ()
 Returns classname information. More...
virtual void InvalidateDataInformation ()
 Mark data information as invalid. More...
vtkSMSourceProxy * GetSourceProxy ()
 Provides access to the source proxy to which the output port belongs. More...
vtkPVDataInformation * GetSubsetDataInformation (const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVTemporalDataInformation * GetTemporalSubsetDataInformation (const char *selector, const char *assemblyName=nullptr)
 Get Temporal data information for a specific selector. More...
virtual int GetPortIndex ()
 Returns the index of the port the output is obtained from. More...
vtkSMSession * GetSession () override
 Overridden to forward to the source proxy. More...
vtkSMSessionProxyManager * GetSessionProxyManager () override
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMOutputPort * New ()
static vtkSMOutputPort * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMOutputPort ()
 ~vtkSMOutputPort () override
virtual void GatherClassNameInformation ()
 Get the classname of the dataset from server. More...
virtual void GatherDataInformation ()
 Get information about dataset from server. More...
virtual void GatherTemporalDataInformation ()
 Get temporal information from the server. More...
void SetSourceProxy (vtkSMSourceProxy *src)
void SetCompoundSourceProxy (vtkSMCompoundSourceProxy *src)
virtual void UpdatePipelineInternal (double time, bool doTime)
 An internal update pipeline method that subclasses may override. More...
virtual void SetPortIndex (int)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int PortIndex
vtkWeakPointer< vtkSMSourceProxy > SourceProxy
vtkWeakPointer< vtkSMCompoundSourceProxy > CompoundSourceProxy
vtkPVClassNameInformation * ClassNameInformation
int ClassNameInformationValid
vtkPVDataInformation * DataInformation
bool DataInformationValid
vtkPVTemporalDataInformation * TemporalDataInformation
bool TemporalDataInformationValid
std::map< std::string, std::map< int, vtkSmartPointer< vtkPVDataInformation > > > SubsetDataInformations
std::map< std::string, std::map< int, vtkSmartPointer< vtkPVTemporalDataInformation > > > TemporalSubsetDataInformations
std::map< int, vtkSmartPointer< vtkPVDataInformation > > RankDataInformations
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Friends
class vtkSMSourceProxy
class vtkSMCompoundSourceProxy
This object manages one output port of an algorithm. It is used internally by vtkSMSourceProxy to manage all of it's outputs.
Attention
Previously, vtkSMOutputPort used to be a vtkSMProxy subclass since it was indeed a Proxy for the output port. However that has now changed. This merely sits as a datastructure to manage ports specific things like data-information. However for backwards compatibility, to keep the impact minimal, we leave this as a sub-class of a Proxy with GlobalID=0 and Session=nullptr.
Definition at line 36 of file vtkSMOutputPort.h.
Definition at line 40 of file vtkSMOutputPort.h.
◆ vtkSMOutputPort()
vtkSMOutputPort::vtkSMOutputPort ( )
◆ ~vtkSMOutputPort()
vtkSMOutputPort::~vtkSMOutputPort ( )
static vtkSMOutputPort* vtkSMOutputPort::New ( )
virtual const char* vtkSMOutputPort::GetClassName ( )
static int vtkSMOutputPort::IsTypeOf ( const char *  type)
virtual int vtkSMOutputPort::IsA ( const char *  type)
static vtkSMOutputPort* vtkSMOutputPort::SafeDownCast ( vtkObject *  o)
void vtkSMOutputPort::PrintSelf ( ostream &  os,
◆ GetDataInformation()
virtual vtkPVDataInformation* vtkSMOutputPort::GetDataInformation ( )
If data information is marked invalid, calls GatherDataInformation. If data information is gathered then this fires the vtkCommand::UpdateInformationEvent event.
◆ GetRankDataInformation()
vtkPVDataInformation* vtkSMOutputPort::GetRankDataInformation ( int  rank)
◆ GetSubsetDataInformation() [1/2]
vtkPVDataInformation* vtkSMOutputPort::GetSubsetDataInformation ( const char *  selector,
const char *  assemblyName = nullptr
However, applications may require information about specific subset of blocks. In that case, one can use this API. Internally, the data information is cached per selector / assembly-name pair. That way, if the data information is not re-gathered unless changed.
  • selector the selector expression
  • assemblyName name of the assembly to use to apply the selector to determine the subset. If none specified, hierarchy is assumed.
◆ GetSubsetDataInformation() [2/2]
vtkPVDataInformation* vtkSMOutputPort::GetSubsetDataInformation ( unsigned int  compositeIndex)
It is only supported for multiblock datasets.
◆ GetTemporalDataInformation()
virtual vtkPVTemporalDataInformation* vtkSMOutputPort::GetTemporalDataInformation ( )
If the data information is not valid, this results iterating over the pipeline and hence can be slow. Use with caution.
◆ GetTemporalSubsetDataInformation()
vtkPVTemporalDataInformation* vtkSMOutputPort::GetTemporalSubsetDataInformation ( const char *  selector,
◆ GetDataClassName()
virtual const char* vtkSMOutputPort::GetDataClassName ( )
◆ GetClassNameInformation()
virtual vtkPVClassNameInformation* vtkSMOutputPort::GetClassNameInformation ( )
◆ InvalidateDataInformation()
virtual void vtkSMOutputPort::InvalidateDataInformation ( )
◆ GetPortIndex()
virtual int vtkSMOutputPort::GetPortIndex ( )
◆ GetSourceProxy()
vtkSMSourceProxy* vtkSMOutputPort::GetSourceProxy ( )
◆ GetSession()
vtkSMSession* vtkSMOutputPort::GetSession ( )
Reimplemented from vtkSMSessionObject.
◆ GetSessionProxyManager()
vtkSMSessionProxyManager* vtkSMOutputPort::GetSessionProxyManager ( )
◆ GatherClassNameInformation()
virtual void vtkSMOutputPort::GatherClassNameInformation ( )
protectedvirtual
◆ GatherDataInformation()
virtual void vtkSMOutputPort::GatherDataInformation ( )
protectedvirtual
Fires the vtkCommand::UpdateInformationEvent event.
◆ GatherTemporalDataInformation()
virtual void vtkSMOutputPort::GatherTemporalDataInformation ( )
protectedvirtual
◆ SetSourceProxy()
void vtkSMOutputPort::SetSourceProxy ( vtkSMSourceProxy *  src)
◆ SetCompoundSourceProxy()
void vtkSMOutputPort::SetCompoundSourceProxy ( vtkSMCompoundSourceProxy *  src)
◆ UpdatePipelineInternal()
virtual void vtkSMOutputPort::UpdatePipelineInternal ( double  time,
bool  doTime
protectedvirtual
◆ SetPortIndex()
virtual void vtkSMOutputPort::SetPortIndex ( int  )
protectedvirtual
◆ vtkSMSourceProxy
friend class vtkSMSourceProxy
friend
Definition at line 189 of file vtkSMOutputPort.h.
◆ vtkSMCompoundSourceProxy
friend class vtkSMCompoundSourceProxy
friend
Definition at line 190 of file vtkSMOutputPort.h.
◆ PortIndex
int vtkSMOutputPort::PortIndex
Definition at line 164 of file vtkSMOutputPort.h.
◆ SourceProxy
vtkWeakPointer<vtkSMSourceProxy> vtkSMOutputPort::SourceProxy
Definition at line 167 of file vtkSMOutputPort.h.
◆ CompoundSourceProxy
vtkWeakPointer<vtkSMCompoundSourceProxy> vtkSMOutputPort::CompoundSourceProxy
Definition at line 168 of file vtkSMOutputPort.h.
◆ ClassNameInformation
vtkPVClassNameInformation* vtkSMOutputPort::ClassNameInformation
Definition at line 170 of file vtkSMOutputPort.h.
◆ ClassNameInformationValid
int vtkSMOutputPort::ClassNameInformationValid
Definition at line 171 of file vtkSMOutputPort.h.
◆ DataInformation
vtkPVDataInformation* vtkSMOutputPort::DataInformation
Definition at line 173 of file vtkSMOutputPort.h.
◆ DataInformationValid
bool vtkSMOutputPort::DataInformationValid
Definition at line 174 of file vtkSMOutputPort.h.
◆ TemporalDataInformation
vtkPVTemporalDataInformation* vtkSMOutputPort::TemporalDataInformation
Definition at line 176 of file vtkSMOutputPort.h.
◆ TemporalDataInformationValid
bool vtkSMOutputPort::TemporalDataInformationValid
Definition at line 177 of file vtkSMOutputPort.h.
◆ SubsetDataInformations
std::map<std::string, std::map<int, vtkSmartPointer<vtkPVDataInformation> > > vtkSMOutputPort::SubsetDataInformations
Definition at line 180 of file vtkSMOutputPort.h.
◆ TemporalSubsetDataInformations
std::map<std::string, std::map<int, vtkSmartPointer<vtkPVTemporalDataInformation> > > vtkSMOutputPort::TemporalSubsetDataInformations
Definition at line 182 of file vtkSMOutputPort.h.
◆ RankDataInformations
std::map<int, vtkSmartPointer<vtkPVDataInformation> > vtkSMOutputPort::RankDataInformations
Definition at line 183 of file vtkSMOutputPort.h.
