vtkSMIntRangeDomain Class Reference
type specific extension to vtkSMRangeDomainTemplate for ints. More...
#include <vtkSMIntRangeDomain.h>
Inheritance diagram for vtkSMIntRangeDomain:
Collaboration diagram for vtkSMIntRangeDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
virtual int GetMinimum (unsigned int idx, int &exists)
 Return a min. More...
virtual int GetMaximum (unsigned int idx, int &exists)
 Return a max. More...
virtual int GetMinimumExists (unsigned int idx)
 Returns if minimum/maximum bound is set for the domain. More...
virtual int GetMaximumExists (unsigned int idx)
virtual int GetMinimum (unsigned int idx)
 Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
virtual int GetMaximum (unsigned int idx)
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMIntRangeDomain * New ()
static vtkSMIntRangeDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMIntRangeDomain ()
 ~vtkSMIntRangeDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMIntRangeDomain is a type specific extension to vtkSMRangeDomainTemplate for ints.
Definition at line 27 of file vtkSMIntRangeDomain.h.
Definition at line 34 of file vtkSMIntRangeDomain.h.
◆ vtkSMIntRangeDomain()
vtkSMIntRangeDomain::vtkSMIntRangeDomain ( )
◆ ~vtkSMIntRangeDomain()
vtkSMIntRangeDomain::~vtkSMIntRangeDomain ( )
static vtkSMIntRangeDomain* vtkSMIntRangeDomain::New ( )
virtual const char* vtkSMIntRangeDomain::GetClassName ( )
static int vtkSMIntRangeDomain::IsTypeOf ( const char *  type)
virtual int vtkSMIntRangeDomain::IsA ( const char *  type)
static vtkSMIntRangeDomain* vtkSMIntRangeDomain::SafeDownCast ( vtkObject *  o)
void vtkSMIntRangeDomain::PrintSelf ( ostream &  os,
Reimplemented in vtkSMTimeStepIndexDomain, and vtkSMViewResolutionDomain.
◆ GetMinimum() [1/2]
virtual int vtkSMIntRangeDomain::GetMinimum ( unsigned int  idx,
int &  exists
inlinevirtual
Return a min.
value if it exists. If the min. exists exists is set to 1. Otherwise, it is set to 0. An unspecified min. is equivalent to -inf
Definition at line 42 of file vtkSMIntRangeDomain.h.
◆ GetMaximum() [1/2]
virtual int vtkSMIntRangeDomain::GetMaximum ( unsigned int  idx,
int &  exists
inlinevirtual
Return a max.
value if it exists. If the max. exists exists is set to 1. Otherwise, it is set to 0. An unspecified max. is equivalent to +inf
Definition at line 52 of file vtkSMIntRangeDomain.h.
◆ GetMinimumExists()
virtual int vtkSMIntRangeDomain::GetMinimumExists ( unsigned int  idx)
inlinevirtual
Definition at line 60 of file vtkSMIntRangeDomain.h.
◆ GetMaximumExists()
virtual int vtkSMIntRangeDomain::GetMaximumExists ( unsigned int  idx)
inlinevirtual
Definition at line 64 of file vtkSMIntRangeDomain.h.
◆ GetMinimum() [2/2]
virtual int vtkSMIntRangeDomain::GetMinimum ( unsigned int  idx)
inlinevirtual
Use GetMaximumExists() GetMaximumExists() to make sure that the bound is set.
Definition at line 74 of file vtkSMIntRangeDomain.h.
◆ GetMaximum() [2/2]
virtual int vtkSMIntRangeDomain::GetMaximum ( unsigned int  idx)
inlinevirtual
Definition at line 75 of file vtkSMIntRangeDomain.h.
