Public Types | Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Member Functions | Properties | Friends | List of all members
pqPropertiesPanel Class Reference
pqPropertiesPanel is the default panel used by paraview to edit source properties and display properties for pipeline objects. More...
#include <pqPropertiesPanel.h>
Inherits QWidget.
enum  { SOURCE_PROPERTIES = 0x01, DISPLAY_PROPERTIES = 0x02, VIEW_PROPERTIES = 0x04, ALL_PROPERTIES = SOURCE_PROPERTIES | DISPLAY_PROPERTIES | VIEW_PROPERTIES }
Public Slots
void apply ()
 Apply the changes properties to the proxies. More...
void reset ()
 Reset the changes made. More...
void showHelp ()
 Shows the help dialog. More...
void propertiesRestoreDefaults ()
 Restores the application defaults for the source properties. More...
void propertiesSaveAsDefaults ()
 Saves the current property settings as default. More...
void displayRestoreDefaults ()
 Restores the application defaults for the display properties. More...
void displaySaveAsDefaults ()
 Saves the current display settings as default. More...
void viewRestoreDefaults ()
 Restores the application defaults for the view properties. More...
void viewSaveAsDefaults ()
 Saves the current view settings as default. More...
void setView (pqView *)
 Set the view currently managed by the panel, should be called automatically when the active view changes. More...
void setPipelineProxy (pqProxy *)
 Set the pqProxy to show properties for under the "Properties" section. More...
void setRepresentation (pqDataRepresentation *)
 Set the representation currently managed by the panel, should be called automatically when the active representation changes. More...
Signals
void applied ()
 This signal is emitted after the user clicks the apply button. More...
void applied (pqProxy *)
 This signal is emitted after a panel for a proxy is applied. More...
void viewChanged (pqView *)
void modified ()
void resetDone ()
void helpRequested (const QString &groupname, const QString &proxyType)
 This signal is emitted when the user clicks the help button. More...
void deleteRequested (pqProxy *source)
 This signal is emitted when the user clicks the delete button. More...
void applyEnableStateChanged ()
 This signal is emitted when the apply button's enable state changes. More...
 pqPropertiesPanel (QWidget *parent=nullptr)
 ~pqPropertiesPanel () override
pqView * view () const
 Returns the current view, if any. More...
void setPanelMode (int val)
 Get/Set the panel mode. More...
int panelMode () const
bool canApply ()
 Returns true if there are changes to be applied. More...
bool canReset ()
 Returns true if there are changes to be reset. More...
static void setAutoApply (bool enabled)
 Enable/disable auto-apply. More...
static bool autoApply ()
 Returns true if auto-apply is enabled. More...
static void setAutoApplyDelay (int delay)
 Sets the delay for auto-apply to delay (in msec). More...
static int autoApplyDelay ()
 Returns the delay for the auto-apply (in msec). More...
static int suggestedMargin ()
 methods used to obtain the recommended spacing and margins to be used for widgets. More...
static QMargins suggestedMargins ()
static int suggestedHorizontalSpacing ()
static int suggestedVerticalSpacing ()
void updatePropertiesPanel (pqProxy *source)
void updateDisplayPanel (pqDataRepresentation *repr)
void updateViewPanel (pqView *view)
Properties
int panelMode
Friends
class pqInternals
pqPropertiesPanel supports auto-generating widgets for properties of the proxy as well as a mechanism to provide custom widgets/panels for the proxy or its representations. pqPropertiesPanel uses pqProxyWidget to create and manage the widgets for the source and representation proxies.
pqPropertiesPanel comprises of 3 separate parts for showing the source properties, display properties and view properties. One can control which parts are shown by setting the panelMode property.
Definition at line 33 of file pqPropertiesPanel.h.
◆ anonymous enum
anonymous enum
Enumerator
SOURCE_PROPERTIES
DISPLAY_PROPERTIES
VIEW_PROPERTIES
ALL_PROPERTIES
Definition at line 81 of file pqPropertiesPanel.h.
◆ pqPropertiesPanel()
pqPropertiesPanel::pqPropertiesPanel ( QWidget *  parent = nullptr)
◆ ~pqPropertiesPanel()
pqPropertiesPanel::~pqPropertiesPanel ( )
override
◆ setAutoApply()
static void pqPropertiesPanel::setAutoApply ( bool  enabled)
◆ autoApply()
static bool pqPropertiesPanel::autoApply ( )
◆ setAutoApplyDelay()
static void pqPropertiesPanel::setAutoApplyDelay ( int  delay)
◆ autoApplyDelay()
static int pqPropertiesPanel::autoApplyDelay ( )
◆ view()
pqView* pqPropertiesPanel::view ( ) const
◆ suggestedMargin()
static int pqPropertiesPanel::suggestedMargin ( )
inlinestatic
Definition at line 76 of file pqPropertiesPanel.h.
◆ suggestedMargins()
static QMargins pqPropertiesPanel::suggestedMargins ( )
inlinestatic
Definition at line 77 of file pqPropertiesPanel.h.
◆ suggestedHorizontalSpacing()
static int pqPropertiesPanel::suggestedHorizontalSpacing ( )
inlinestatic
Definition at line 78 of file pqPropertiesPanel.h.
◆ suggestedVerticalSpacing()
static int pqPropertiesPanel::suggestedVerticalSpacing ( )
inlinestatic
Definition at line 79 of file pqPropertiesPanel.h.
◆ setPanelMode()
void pqPropertiesPanel::setPanelMode ( int  val)
◆ panelMode()
int pqPropertiesPanel::panelMode ( ) const
inline
Definition at line 93 of file pqPropertiesPanel.h.
◆ canApply()
bool pqPropertiesPanel::canApply ( )
◆ canReset()
bool pqPropertiesPanel::canReset ( )
◆ apply
void pqPropertiesPanel::apply ( )
slot
This is triggered when the user clicks the "Apply" button on the properties panel.
◆ reset
void pqPropertiesPanel::reset ( )
slot
This is triggered when the user clicks the "Reset" button on the properties panel.
◆ showHelp
void pqPropertiesPanel::showHelp ( )
slot
This is triggered when the user clicks the "?" button on the properties panel.
◆ propertiesRestoreDefaults
void pqPropertiesPanel::propertiesRestoreDefaults ( )
slot
This is triggered when the user clicks the button with the reload button next to the properties button.
◆ propertiesSaveAsDefaults
void pqPropertiesPanel::propertiesSaveAsDefaults ( )
slot
This is triggered when the user clicks the button with the save icon next to the properties button.
◆ displayRestoreDefaults
void pqPropertiesPanel::displayRestoreDefaults ( )
slot
This is triggered when the user clicks the button with the reload button next to the display button.
◆ displaySaveAsDefaults
void pqPropertiesPanel::displaySaveAsDefaults ( )
slot
This is triggered when the user clicks the button with the save icon next to the display button.
◆ viewRestoreDefaults
void pqPropertiesPanel::viewRestoreDefaults ( )
slot
This is triggered when the user clicks the button with the reload button next to the view button.
◆ viewSaveAsDefaults
void pqPropertiesPanel::viewSaveAsDefaults ( )
slot
This is triggered when the user clicks the button with the save icon next to the view button.
◆ setView
void pqPropertiesPanel::setView ( pqView *  )
slot
◆ setPipelineProxy
void pqPropertiesPanel::setPipelineProxy ( pqProxy *  )
slot
Typically, this is a pqPipelineSource (or subclass), pqOutputPort, or a pqExtractor.
◆ setRepresentation
void pqPropertiesPanel::setRepresentation ( pqDataRepresentation *  )
slot
◆ applied [1/2]
void pqPropertiesPanel::applied ( )
signal
◆ applied [2/2]
void pqPropertiesPanel::applied ( pqProxy *  )
signal
◆ viewChanged
void pqPropertiesPanel::viewChanged ( pqView *  )
signal
◆ modified
void pqPropertiesPanel::modified ( )
signal
◆ resetDone
void pqPropertiesPanel::resetDone ( )
signal
◆ helpRequested
void pqPropertiesPanel::helpRequested ( const QString &  groupname,
const QString &  proxyType
signal
◆ deleteRequested
void pqPropertiesPanel::deleteRequested ( pqProxy *  source)
signal
◆ applyEnableStateChanged
void pqPropertiesPanel::applyEnableStateChanged ( )
signal
This is intended for other controls that call apply on the panel so that they can be enabled/disabled correctly (i.e. menu items).
◆ updatePropertiesPanel()
void pqPropertiesPanel::updatePropertiesPanel ( pqProxy *  source)
◆ updateDisplayPanel()
void pqPropertiesPanel::updateDisplayPanel ( pqDataRepresentation *  repr)
◆ updateViewPanel()
void pqPropertiesPanel::updateViewPanel ( pqView *  view)
◆ pqInternals
friend class pqInternals
friend
Definition at line 290 of file pqPropertiesPanel.h.
Property Documentation
◆ panelMode
readwrite
Definition at line 36 of file pqPropertiesPanel.h.
