Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqMoleculePropertyWidget Class Reference
Expose molecule mapper parameters to the user. More...
#include <pqMoleculePropertyWidget.h>
Inheritance diagram for pqMoleculePropertyWidget:
Collaboration diagram for pqMoleculePropertyWidget:
 pqMoleculePropertyWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parentObject=nullptr)
 ~pqMoleculePropertyWidget () override=default
void updateWidget (bool showing_advanced_properties) override
 Override to show/hide relevant widgets depending on the advanced properties status. More...
- Public Member Functions inherited from pqPropertyGroupWidget
 pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
vtkSMPropertyGroup * propertyGroup () const
void addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1)
void addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1)
void addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1)
void addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1)
char * panelVisibility () const override
 Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
void setPanelVisibility (const char *vis) override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void onPresetChanged (int)
 Apply selected preset to the proxy. More...
void resetPreset ()
 Reset the preset widget. More...
void updateBondWidgetsVisibility ()
 Show/hide widgets depending on the states of other widgets. More...
void updateAtomWidgetsVisibility ()
void updateAtomicRadiusWidgetsVisibility ()
void updateBondColorWidgetVisibility ()
void onScaleAtomFactorChanged (double scale)
 Update the atom/bond radius sliders bounds. More...
void onResetAtomFactorToggled ()
void onScaleBondRadiusChanged (double scale)
void onResetBondRadiusToggled ()
void setDocumentationAsTooltip (vtkSMProperty *prop, QWidget *widget)
 Set property documentation as widget tooltip. More...
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
- Signals inherited from pqPropertyGroupWidget
void changeFinished ()
void changeAvailable ()
void restartRequired ()
template<class T >
Some presets are defined for an easiest configuration.
Definition at line 19 of file pqMoleculePropertyWidget.h.
◆ pqMoleculePropertyWidget()
pqMoleculePropertyWidget::pqMoleculePropertyWidget ( vtkSMProxy *  smproxy,
QWidget *  parentObject = nullptr
◆ ~pqMoleculePropertyWidget()
pqMoleculePropertyWidget::~pqMoleculePropertyWidget ( )
overridedefault
◆ updateWidget()
void pqMoleculePropertyWidget::updateWidget ( bool  showing_advanced_properties)
Reimplemented from pqPropertyWidget.
◆ updateBondWidgetsVisibility
void pqMoleculePropertyWidget::updateBondWidgetsVisibility ( )
protectedslot
Handle advanced proprerties visibility.
◆ updateAtomWidgetsVisibility
void pqMoleculePropertyWidget::updateAtomWidgetsVisibility ( )
protectedslot
◆ updateAtomicRadiusWidgetsVisibility
void pqMoleculePropertyWidget::updateAtomicRadiusWidgetsVisibility ( )
protectedslot
◆ updateBondColorWidgetVisibility
void pqMoleculePropertyWidget::updateBondColorWidgetVisibility ( )
protectedslot
◆ onPresetChanged
void pqMoleculePropertyWidget::onPresetChanged ( int  )
protectedslot
◆ resetPreset
void pqMoleculePropertyWidget::resetPreset ( )
protectedslot
If a property has changed, preset widget should display '(no preset)'.
◆ onScaleAtomFactorChanged
void pqMoleculePropertyWidget::onScaleAtomFactorChanged ( double  scale)
protectedslot
◆ onResetAtomFactorToggled
void pqMoleculePropertyWidget::onResetAtomFactorToggled ( )
protectedslot
◆ onScaleBondRadiusChanged
void pqMoleculePropertyWidget::onScaleBondRadiusChanged ( double  scale)
protectedslot
◆ onResetBondRadiusToggled
void pqMoleculePropertyWidget::onResetBondRadiusToggled ( )
protectedslot
◆ setDocumentationAsTooltip()
void pqMoleculePropertyWidget::setDocumentationAsTooltip ( vtkSMProperty *  prop,
QWidget *  widget
