Signals | Public Member Functions | Protected Slots | List of all members
pqDoubleVectorPropertyWidget Class Reference
#include <pqDoubleVectorPropertyWidget.h>
Inheritance diagram for pqDoubleVectorPropertyWidget:
Collaboration diagram for pqDoubleVectorPropertyWidget:
Signals
void clearHighlight ()
 internal signal used to clear highlights from pqHighlightablePushButton. More...
void highlightResetButton ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqDoubleVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqDoubleVectorPropertyWidget () override
void apply () override
void reset () override
 ~pqPropertyWidget () override
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
virtual void resetButtonClicked ()
 called when the user clicks the "reset" button for a specific property. More...
void scaleHalf ()
void scaleTwice ()
void scale (double)
void resetToActiveDataBounds ()
 sets the value using active source's data bounds. More...
void resetToBounds (const double bds[6])
 sets the value to the specified bounds. More...
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 10 of file pqDoubleVectorPropertyWidget.h.
◆ pqDoubleVectorPropertyWidget()
pqDoubleVectorPropertyWidget::pqDoubleVectorPropertyWidget ( vtkSMProperty *  property,
vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqDoubleVectorPropertyWidget()
pqDoubleVectorPropertyWidget::~pqDoubleVectorPropertyWidget ( )
override
◆ apply()
void pqDoubleVectorPropertyWidget::apply ( )
Reimplemented from pqPropertyWidget.
◆ reset()
void pqDoubleVectorPropertyWidget::reset ( )
◆ clearHighlight
void pqDoubleVectorPropertyWidget::clearHighlight ( )
signal
◆ highlightResetButton
void pqDoubleVectorPropertyWidget::highlightResetButton ( )
signal
◆ resetButtonClicked
virtual void pqDoubleVectorPropertyWidget::resetButtonClicked ( )
protectedvirtualslot
◆ scaleHalf
void pqDoubleVectorPropertyWidget::scaleHalf ( )
protectedslot
◆ scaleTwice
void pqDoubleVectorPropertyWidget::scaleTwice ( )
protectedslot
◆ scale
void pqDoubleVectorPropertyWidget::scale ( double  )
protectedslot
◆ resetToActiveDataBounds
void pqDoubleVectorPropertyWidget::resetToActiveDataBounds ( )
protectedslot
◆ resetToBounds
void pqDoubleVectorPropertyWidget::resetToBounds ( const double  bds[6])
protectedslot
