Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Protected Attributes | Properties | List of all members
pqInteractivePropertyWidgetAbstract Class Referenceabstract
pqInteractivePropertyWidgetAbstract is an abstract pqPropertyWidget subclass designed to serve as the superclass for all pqPropertyWidget types that have interactive widget, either in a chart or in a 3D view. More...
#include <pqInteractivePropertyWidgetAbstract.h>
Inheritance diagram for pqInteractivePropertyWidgetAbstract:
Collaboration diagram for pqInteractivePropertyWidgetAbstract:
Public Slots
virtual void setWidgetVisible (bool val)
 Toggle the interactive widget's visibility. More...
void setDataSource (vtkSMProxy *dataSource)
 DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More...
Signals
void widgetVisibilityToggled (bool)
 Fired whenever setWidgetVisible() changes the widget's visibility. More...
void widgetVisibilityUpdated (bool)
 Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
void startInteraction ()
 Fired by the underlying interactive widget representation proxy, for each respective events. More...
void interaction ()
void endInteraction ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidgetAbstract () override
void reset () override
 Overridden to call this->render() to ensure that the widget is redrawn. More...
void setView (pqView *view) override
 Overridden to show the widget proxy in the new view. More...
bool isWidgetVisible () const
 Returns the interactive widget's visibility. More...
vtkSMProxy * dataSource () const
 Returns the data source. More...
vtkBoundingBox dataBounds (bool visibleOnly=false) const
 Returns bounds from the dataSource, if possible. More...
vtkSMPropertyGroup * propertyGroup () const
 Returns the vtkSMPropertyGroup pass to the constructor. More...
void hideEvent (QHideEvent *) override
 Overriden in order to hide the VTK widget. More...
void showEvent (QShowEvent *) override
 Overriden in order to show the VTK widget. More...
void select () override
 In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
void deselect () override
void selectPort (int portIndex) final
 ~pqPropertyWidget () override
virtual void apply ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
Protected Slots
virtual void placeWidget ()=0
 Places the interactive widget using current data source information. More...
void render ()
 Safe call render on the view. More...
virtual void updateWidgetVisibility ()
 This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More...
virtual vtkSMNewWidgetRepresentationProxyAbstract * internalWidgetProxy ()=0
 Get the internal instance of the widget proxy. More...
void setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy)
 Setup all the links and events for the given widget and SM property group. More...
void setupUserObserver (vtkSMProxy *smproxy)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
bool VisibleState = true
bool WidgetVisibility = false
int LinkedPortIndex = -1
Properties
pqSMProxy dataSource
template<class T >
pqInteractivePropertyWidgetAbstract is intended to provide a Qt widget (along with an interactive widget in the active view) for controlling properties on the proxy identified by a vtkSMPropertyGroup passed to the constructor. Subclasses are free to determine which interactive widget to create and how to setup the UI for it.
Definition at line 30 of file pqInteractivePropertyWidgetAbstract.h.
◆ pqInteractivePropertyWidgetAbstract()
pqInteractivePropertyWidgetAbstract::pqInteractivePropertyWidgetAbstract ( const char *  widget_smgroup,
const char *  widget_smname,
vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqInteractivePropertyWidgetAbstract()
pqInteractivePropertyWidgetAbstract::~pqInteractivePropertyWidgetAbstract ( )
override
◆ reset()
void pqInteractivePropertyWidgetAbstract::reset ( )
Reimplemented from pqPropertyWidget.
◆ setView()
void pqInteractivePropertyWidgetAbstract::setView ( pqView *  view)
◆ isWidgetVisible()
bool pqInteractivePropertyWidgetAbstract::isWidgetVisible ( ) const
Note that the widget may still not be visible in the view if the pqPropertyWidget is not selected. An interactive widget may be visible in the view when this->isWidgetVisible() and this->isSelected() both return true and the view is of the right type.
◆ dataSource()
vtkSMProxy* pqInteractivePropertyWidgetAbstract::dataSource ( ) const
◆ select()
void pqInteractivePropertyWidgetAbstract::select ( )
selectPort(int) allows to make the selection only if the given port index is linked with the vtkSMPropertyGroup this interactive widget represents.
◆ deselect()
void pqInteractivePropertyWidgetAbstract::deselect ( )
◆ selectPort()
void pqInteractivePropertyWidgetAbstract::selectPort ( int  portIndex)
finalvirtual
◆ dataBounds()
vtkBoundingBox pqInteractivePropertyWidgetAbstract::dataBounds ( bool  visibleOnly = false) const
May return invalid bounds when no dataSource exists of hasn't been updated to produce valid data. If the input source is a vtkMultiBlockDataSet and "visibleOnly" is set to "true", this function returns the bounds of the visible blocks only.
◆ propertyGroup()
vtkSMPropertyGroup* pqInteractivePropertyWidgetAbstract::propertyGroup ( ) const
◆ hideEvent()
void pqInteractivePropertyWidgetAbstract::hideEvent ( QHideEvent *  )
override
◆ showEvent()
void pqInteractivePropertyWidgetAbstract::showEvent ( QShowEvent *  )
override
◆ setWidgetVisible
virtual void pqInteractivePropertyWidgetAbstract::setWidgetVisible ( bool  val)
virtualslot
This, along with pqPropertyWidget's selected state controls whether the widget proxy is visible in a view.
◆ setDataSource
void pqInteractivePropertyWidgetAbstract::setDataSource ( vtkSMProxy *  dataSource)
slot
the bounds to use for placing the widget or when re-centering the interactive widget.
◆ placeWidget
virtual void pqInteractivePropertyWidgetAbstract::placeWidget ( )
protectedpure virtualslot
◆ render
void pqInteractivePropertyWidgetAbstract::render ( )
protectedslot
◆ updateWidgetVisibility
virtual void pqInteractivePropertyWidgetAbstract::updateWidgetVisibility ( )
protectedvirtualslot
◆ widgetVisibilityToggled
void pqInteractivePropertyWidgetAbstract::widgetVisibilityToggled ( bool  )
signal
◆ widgetVisibilityUpdated
void pqInteractivePropertyWidgetAbstract::widgetVisibilityUpdated ( bool  )
signal
◆ startInteraction
void pqInteractivePropertyWidgetAbstract::startInteraction ( )
signal
◆ interaction
void pqInteractivePropertyWidgetAbstract::interaction ( )
signal
◆ endInteraction
void pqInteractivePropertyWidgetAbstract::endInteraction ( )
signal
◆ internalWidgetProxy()
virtual vtkSMNewWidgetRepresentationProxyAbstract* pqInteractivePropertyWidgetAbstract::internalWidgetProxy ( )
Subclasses should implement this function and handle the instance of their own widget, wich will be exposed internally via this function.
Implemented in pqInteractiveProperty2DWidget, and pqInteractivePropertyWidget.
◆ setupConnections()
void pqInteractivePropertyWidgetAbstract::setupConnections ( vtkSMNewWidgetRepresentationProxyAbstract *  widget,
vtkSMProxy *  smproxy
This should be call by subclasses in their constructor once their widget is initialized.
◆ setupUserObserver()
void pqInteractivePropertyWidgetAbstract::setupUserObserver ( vtkSMProxy *  smproxy)
◆ VisibleState
bool pqInteractivePropertyWidgetAbstract::VisibleState = true
Definition at line 172 of file pqInteractivePropertyWidgetAbstract.h.
◆ WidgetVisibility
bool pqInteractivePropertyWidgetAbstract::WidgetVisibility = false
Definition at line 173 of file pqInteractivePropertyWidgetAbstract.h.
◆ LinkedPortIndex
int pqInteractivePropertyWidgetAbstract::LinkedPortIndex = -1
Definition at line 174 of file pqInteractivePropertyWidgetAbstract.h.
Property Documentation
◆ dataSource
pqSMProxy pqInteractivePropertyWidgetAbstract::dataSource
readwrite
Definition at line 34 of file pqInteractivePropertyWidgetAbstract.h.
